Question about Panasonic Es2207p Ladies Close Curves Wet/dry Shaver Mauve 1-year Warranty
I have a panasonic es2207p ladies shaver i bought of amazon.com and it dont work in uk so what should i do? and if a stepdown is what i need should it be the 45watt or the 100watt, im sorry i bought i
Well ive been trying for months for help with this shaver as i cant get it to charge ive even looked for a uk charging stand to no evail i do have the usa plug but that dont charge it, ive looked for stepdowns but still dont know which one i need, please help!
5 Suggested Answers
  • 14 Answers
SOURCE: wet/dry Panasonic shaver stopped
My model is almost the same as your model ...
Problem: Model ES7037CMB - Over the past month the Panasonic shaver would turn on with 3-4 tries, but now will not turn on at all – the on-off switch must be bad after only 7 months of wet use. Before sending in I found this diagram:
Disassembly: Remove bottom Phillips screw & end cap, pop off each plastic side with fingernails (reinstall them from top 1st), remove 4 screws, remove 2 clips, take top off. Remove battery case and the on-off little, white plastic lever fell out. Slide off the white plastic/metal on-off slider & clean contacts with knife … my bottom contact was black & top was clean.
Assembly: Reinstall on-off slider (white plastic with metal contacts) by sliding back in grooves -- hardest part - place the on-off plastic lever on the battery back unit – I tried to put it on the case and could not get it to stay on. Slide the battery pack back in with the plug prongs in the holes in the end being careful not to drop the on-off lever. Test shaver. Stuff battery wires inside case – screw 4 screws and add 2 clips on, then final screw in the end after cap placed on. Easy once I knew how to put the on-off lever on the battery side – that was tricky. Total time was about 1 hour – next time it will be about 15 minutes. Works great! jgg 12-27-08. Think I will use it dry from now own since it had a lot of whiskers inside of it and maybe wash only the head as needed with baby shampoo.
Posted on Dec 27, 2008
  • 14 Answers
SOURCE: shaver will not hold a charge, panasonic es8003
Sounds like the switch is dirty and not lettingit run ... look at this video on how to clean the switch ... mine would not charge or run until I cleaned the on-off switch.
http://www.youtube.com/watch?v=9b7lf5hqjag
Posted on Apr 28, 2009
brector3
  • 1610 Answers
SOURCE: have Panasonic ES8093 shaver.charge indicator
this problem is usually from old batteries. batteries will typically lose much of their ability to hold a charge after 3-6 years and they will need to be replaced.
if you use your shaver wet or rinse it under water, I dont suggest that you repair it as you will not likely get it sealed back up well enough to prevent it from leaking.
Panasonic does allow the sale of their specialized shaver batteries to consumers. Therefore, you will need to use a compatible battery type. shaveroutlet.com sells a set here:
http://shaveroutlet.com/braun-battery-nimh-2-batteries-p-105.html
These are made for Braun shavers but will work because they have prongs on the ends to snap in place like your originals
Posted on Jan 16, 2010
Testimonial: "Thank you for your help Ivor J"
walesarumi
  • 6993 Answers
SOURCE: Battery in Panasonic ES8183 wet and dry shaver
A 12 months old wet and dry shaver must have a defective battery after such long period of use.
The battery cell is weak and unable to hold charge.
You sure need a battery replacement. It's not necessary you get a Panasonic battery replacement as long as its the same size, shape and watt. You can get another battery from any electronics accessories store within your vicinity.
All you need do is disassemble the shaver, remove the old battery, use it as a sample for the replacement so that you can get the same battery size, shape etc..
To disassemble the shaver, first, take the shaver outside and use a can of air to clean the shaver. Repeat this at various stages of the dis-assembly, being careful not to lose any parts!
Remove the two screws at the bottom (the end that plugs in to the charger) of the shaver, and remove the bottom cover. Keep track of the two small washers, and a small flat plastic piece, about 10mm square that fits inside of the cover - these keep the unit waterproof.
Open the shaver head, and remove the blade assembly from the white plastic vibrating arm by pulling on it - it will pop off. Undo the two screws on either side of the arm, keeping track of the two small washers under the plate - these will tend to stay in place and stick to the metal plate or the plastic underneath the plate.
Press on the mechanism from the end you first opened, and notice a gap opening up where at the other end, just below the head latch button and hinge. Gently pry open this crack, and work the case apart. Keep the large O-ring that seals the case, and make a note of its orientation so that you can assemble it the same way.
This has been too easy, I know, so there is one headache. I have not figured out how to remove the sliding trimmer assembly. Because of this, I found it was necessary to pry the large black U-shaped plastic clamp from the vibrating arm at the same time you pull the innards out of the case
By now you should have access to the battery, and proceed for the battery replacement.
I hope you understand the above.
Good luck.
Posted on Mar 01, 2011
How can a buy the power cord for a ES-LT41 shaver?
panasonic WESRT51K7658 adapter charging cord for men electric shaver panasonic es lt41 power cord replacement parts.
panasonic es lt41 charger power cord
Jan 14, 2015 | Panasonic Personal Care Es-lt41-k Shaver...
LOST DIRECTIIONS FOR RECHARGING PANASONIC WET/DRY WOMEN'S ELECTRIC RAZOR ES2207. Thanks!
You will find the instruction manual at shaveroutlet.com. See link below. When page opens, click the 'user manual' link near the 'add to cart' button
http://shaveroutlet.com/women-s/panasonic-es2207-close-curves-rechargeable-wet-and-dry-ladies-shaver.html
Aug 04, 2011 | Panasonic Health & Beauty
Have Panasonic ES8093 shaver.charge indicator never goes below 80%.Therefore never fully charges.
Jan 03, 2010 | Panasonic Health & Beauty
Need a new foil for model 5479 Braun electric shaver
This particular Braun shaver was made in both a US and European version. They are similar, but take slightly different cutter blocks and foil screens, sooooooo
If you bought your shaver in the US, then you can get a replacement foil here for around $8.00 or you can find another supplier of your choosing.
http://www.ecrater.com/product.php?pid=4997848
If you bought your shaver in the UK, then a replacement is available on Amazon.com (UK site) for quite a bit more in British pounds.
http://www.amazon.co.uk/Braun-Replacement-Foil-Cutter-System1-2-3/dp/B0000X5HPK
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Braun Health & Beauty
I'm in the UK bought my
This trimmer is only made to be used with 110V, we do not have this model in 240V. There is no way to stop the noise. If you would like to purchase a unit made for 240V please call 1-800-558-9441 and speak with one of the Andis customer service reps.
Thank you for purchasing Andis.
Dec 01, 2007 | Andis Outliner II Hair Trimmer
Panasonic Es2207p Ladies Close Curves Wet/dry Shaver Mauve 1-year Warranty Logo
148 people viewed this question
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
