Question about Dryers
I have a Kenmore DWJR-ELE-2406028-FM54 your plug is 4 pin, but I have on my wall of 3 pin. You can change the 4-pin plug for one of 3 pin, and how. Or is there another solution
Problems with the plug
    Top Expert:
  • Dryers Master
  • 9,472 Answers
Take a look at this video.
Posted on Oct 29, 2012
  • 57 Answers
SOURCE: My 2006 Kenmore electric dryer stopped running.
if you take the back off of your dryer and look for a little white thermo fuse with 2 wires on it if you unhook the wires and plug them together than start the dryer if it starts shut it off and replace the fuse and clean your venting
Posted on Mar 01, 2009
vickygomar
  • 460 Answers
SOURCE: Kenmore electric dryer Mod. 100.66662501, type
Assuming that the fuses you speak of are the external pair, and not the internal motor or timer resets:
Check the fuse holder for corrosion on the plates. Often the fuse is not properly seated because of this build-up and therefore has an intermittent connection. This will cause the fuse to either heat up, or overload; ultimately failing.
To remedy this, turn OFF the breaker, or main switch if necessary, and fix a wooden dowel with a piece of emery cloth (or sand paper) on the end. Remove any visible black corrosion from the contact plates.
Finish with a spray of WD40 to protect the plates and fuse end.
Replace the fuse, ensuring that it's tight, reinstate power and try again.
Was this  helpful?
Posted on May 13, 2009
erpaalai
  • 999 Answers
SOURCE: It appears the heating element went out on our
Yes it is fairly easy to replace from the back. First verify it is the element and not the thermal fuse or a loss of one leg of the 240VAC circuit.
Eric
Posted on Jul 07, 2009
SOURCE: Where do you find a heating element for a Kenmore
partsdirect.com They will have every part on it.
Posted on Nov 10, 2009
  • 44 Answers
SOURCE: whirlpool Electric dryer
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Posted on Mar 17, 2010
I have a Whirlpool DWJR-ELE-2406028-FM54 and when I open the door (while machine is running), the drum keeps turning. How do i remedy this?
sounds like the door switch is broken,good thing it broke in the running position or the dryer wouldn't start.that isn't a good model number either,open the door look around the opening where you put the clothes in and you should see a tag with the model number,you'll need that to order the door switch.the dwjr comes up but not the rest if this is a ge dryer.
Feb 05, 2018 | Whirlpool Dryers
What is the capacity of a Kenmore dryer model 110 62622100
The dryer should hold what the washer will hold especially if there a matched set this one looks like a super cap. hope this helps
Feb 18, 2015 | Kenmore Dryers
MOTOR WONT RUN ON A KENMORE DWJR-ELE-2406028-FM54
Seems like you have a bad door switch , you should have continuity when the door is shut and OL when door is open . If switch is fine you may have a sock jammed in the blower wheel .
GOOD LUCK
APPLIANCES R'EN
Dec 06, 2013 | Dryers
Kenmore electric dryer DWJR-ELE-2406028-FM54 Model 110.64632300. when we close the door the start button doesnt work until we close it 5 or 6 times. Help.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Kenmore 64722 Electric Dryer
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
Mar 17, 2010 | Whirlpool Dryers
Where do you find a heating element for a Kenmore Model #110.66662500. Serial: MT0203728 Type: DWJR-ELE-2406028-FM54
Grainger.com is easy or you can look thru the yellow pages for a local appliance repair store, for parts.
Nov 10, 2009 | Kenmore 62602 Electric Dryer
It appears the heating element went out on our older Kenmore dryer - Type DWJR ELE 2406028 FM54. mod 110.62622101. Is this an easy fix?
Eric
Jul 06, 2009 | Dryers
My 2006 Kenmore electric dryer stopped running. We checked the plug and the breakers and don't see the problem. The codes on it are DWJR-ELE-2406028-FM54; 110.66652500. We can't find the owners manual. Any...
Mar 01, 2009 | Kenmore 659 Electric Dryer
Dryer runs no heat
Sounds to me you either blew the fuse or tripped the circuit for the heating element. Try replacing the fuse or resetting the breaker before trying any repairs.
Jan 09, 2009 | Kenmore 64602 Electric Dryer
Dryer don't blow hot air, everything else runs ok.
you need to check the heating element and the thermal fuse to see if they are blown.
Dec 19, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
139 people viewed this question
Top Dryers Experts
