Question about AEG Washing Machines
ERROR C3 Machine has stopped, showing message "Error code C3, PNC 91400130400, & s no 01170438
2 Suggested Answers
  • 3230 Answers
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
Posted on May 06, 2009
When you push foot pedal c3 comes up and beeps 3 times
Don't know what machine you have, but this may help:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwigsLfzlJbKAhVB7WMKHYHZAHwQFggdMAA&url=http%3A%2F%2Fwww.singerco.com%2Fpdf%2FFC_Plug_In_Instructions.pdf&usg=AFQjCNEqPAnJbHodHAqfFC95mKH913qZVA&cad=rja
Singer One Instruction Manual Helpful Messages
Error code & would not sew after 2 uses.
4/19/2012
Customer review by DeZooMT
1.0 stars by DeZooMT
Got this as a Christmas gift. Have used it twice since then for little things. Seemed to be fine. Decorative stitches worked and the straight stitches turned out good too. But didn't last. Just took it out to use on a bigger project and it just stopped sewing. The foot pedal wouldn't work at all. The back stitch button would sew though. If you tapped the pedal aggressively at times it would delay and then jump forward 3 stitches and then display the C3 error code saying the foot pedal was disconnected, which it clearly wasn't. Tried the Singer CS line. Was caller number 20, was on hold for 40 mins when I finally got down to caller number 4. All of a sudden the operator hung up the call and stated "their offices are now closed." I was furious. Needles to say, it went back to WalMart and I won't be buying another one.
Jan 06, 2016 | Sewing Machines
Error (2)
Please tell about your printer model & brand.
Jun 12, 2013 | Office Equipment & Supplies
My printer Konica Minolta stopped working and showed me an error code F-26-6
The printer stops working & showed me an error code F-26-1
www.fixya.com/.../t16683015-printer_stops_working_amp_showed_me
Feb 20, 2013 - the printer stops working & showed me an error code F-26-1 , How can I repair it ? I think it s relating to a - Konica Minolta 26NA53040 7130 ...
Konica Minolta 26NA53040... Repair Questions - Fixya
www.fixya.com/.../p4700437-konica_minolta_26na53040_7130_7025_...
Konica Minolta 26NA53040 7130 7025 7020 Oem Lower Fixing Roller Assy New ... Theprinter stops working & showed me an error code F-26-1 , How can I ...
Feb 20, 2013 | Konica Minolta 26NA53040 7130 7025 7020...
Whirlpool AWOD6727 washing machine displaying error code "F23". Help please?!?!
Could be a slow drain time issue. Excess wear makes it drain slow.
Mar 17, 2017 | Whirlpool Washing Machines
Solution for C3 error code on Hitachi washing machine SF100-HJ
Hitachi Sf95kj washing machine. It shows C3 error. What does it mean?
Jul 07, 2012 | Washing Machines
My Washing machine Brand : AEG and model : 84740 update and problem is when switched on its showing error message C3. And blinking 3 light as well one is 1400 light , and other 2 is washing program
Quote 'German made AEG washing machines (update) C3 indicates float switch fault' unquote.
Sorry- looks like a service call is required ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jun 28, 2011 | AEG Washing Machines
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
Dec 29, 2010 | AEG Dishwashers
Good Luck!!
Dec 10, 2007 | AEG L86800 Front Load Washer
Zanussi LS9 Dishwash error message
c3 means that the temperature of the water inside the tank is higher than 60 degrees celcious.may be you have already connect the dishwasher with to much hot water or the rele inside the pcb is stuck.
waiting for answer
Nov 16, 2007 | Zanussi 29 in. LS14 Free-standing...
AEG Dishwasher FAVORIT 3A Error Message C3
If you open a sidepanel and look at the bottom of the machine you see a brown device with a piece of white foam,this is the leak prevention system.
Push foam down and the error code should be cleared.
Make sure you there's no water left on the bottom of machine
Oct 24, 2007 | AEG Dishwashers
Washing Machines Logo
16 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
