Question about LG 37LG50 37 in. LCD HDTV
Flashes message no program information
Flashes of messages: "no program information", "component 2...", etc. Flashes can last from 30 sec to 1 hr, then stop for the remainer of the day most of the time. Very random.
2 Suggested Answers
SOURCE: LG 42LC2DR
I have pulled apart my LG LCD tv and discovered the power supply has a blown capacitor and a fried ic on the other side of the board. Ok off to the all knowing, all seeing, internet to find a replacement one. However, it seams everyone is out of stock of PSU: 6709900017A YP4201 Rev 3, PCBs. Has LG provided an alternative? Perhaps because of a persistent failure of this board. If so, does anyone know what that P/N might be? Would be very helpful to know it. Thanks Rick W.
Posted on Jun 08, 2011
"online" light flashes, but labels don't print
Check that you are using the correct escape characters.
in printerparameter check that you are on auto
else check in the driver you are using esc LF Nul or {'} characters.
last if in serial mode check the communication parameters
default 9600,n,8,1 (no partity 1 stop bit, 8 data bits)
Jul 30, 2012 | Toshiba TEC B-572 Printer
Delete recieved messages
The top bar of what application program? What program is missing the delete message button? Is it your email? If so, what is your email client (yahoo, gmail, etc.)
May 23, 2012 | Computers & Internet
I just installed cyberlink powerproducer 2 gold (2-8-11) on my comp.(medion 64 bit vista) when first attempted an installation,an error message opened stating "this program is intended for windows 98...
can u send me a .iso of program?... I can't found that anywhere... u can write me in lgchot<at>hotmail(dot)com thank you very much for help me... luc
Feb 08, 2011 | CyberLink PowerProducer 2 for PC
Wii has started turning itself on with blue light displaying.
If your Wii does not actually turn on, as in you could see it on the TV if you had your TV on, then you either got a message on your message board from Nintendo informing you about new Channels, Updates, etc, if it flashes slowly, then gives 2 quick flickers then it is a system update.
Hope this answers your question! ~Flascher
Jul 16, 2009 | Nintendo Wii Console
When I start my car, it is running rough, must keep on full throttle or it quit running.will not idle at all.
Do you know how to retrieve fault codes by cycling key, on, off, on,off, on, and leave in on position & count flashes from check engine light. 2 flashes , pause, 2 more flashes, is code 22. 3 flashes, pause 3 more, is code 33 etc.... Get back to us with those codes if any. By the way code 55 means end of message.
Jun 04, 2009 | 1992 Plymouth Acclaim
Loss of power
Have you cycled key to see if there are any trouble codes stored?
On,off,on,off,on. Leave in on position (not start) and count any flashes from check engine light. 2 flashes,short pause, and 2 more flashes =22. 3 flashes, pause, 3 more is code 33. etc when you get code 55, that's end of message.Let us know if anything comes up.
Apr 04, 2009 | 1995 Dodge Intrepid
Program garage door opener.
press the two outside buttons at the same time. Hold while message reads "clearing codes"
Once you get a cleared message. hold the button that you want to program as your remote and press it down. The light will flash slowly. Take your remote in your other hand and hold it about 3 inches from your review mirror as close to the windsheild as possible. You must do this as soon as you press your designated button on the panel. Hold until your green light starts flashing fast. Once it flashes fast it means you have programmed your button properly.
Suggestions - do not do this in front of your garage as you remote will make you door go up and down the whole time. Also - make sure your batteries are new in your remote so you get a good signal to your button. Last thing - if one remote does not work after a couple of tries - use another remote.
Mar 25, 2009 | 2005 Cadillac Escalade
Change ringer tone
Message/Ringer Lamp: The Message/
Ringer lamp informs you visually that you
have a message or a call.
When you receive a call, the lamp
flashes depending on the ringing pattern.
When the ringing pattern is set to Single
(Slow flash), Double (Moderate flash), or
Triple (Rapid flash) in your PBX, the lamp
flashes. When the other ringing patterns
are set in your PBX, the lamp may not
flash. (e.g., S-Double, Call Waiting
Tone1).
When someone has left you a message,
the lamp is lit continuously.
Please note that the above indicates that ring patterns are set in the the PBX. These are issues that require a real person to sit at the main system and program the features that users need. I hope you have an I.T. person that knows your phone system. If you don't, you'll have to find a communications company in your area that can program your system. Thanks for using Fixya.
Jan 19, 2009 | Panasonic KX-T7730 Corded Phone
Conair digital answering system
TAD2012 Quick Reference Guide
To Install
1. Open the battery door with a ballpoint pen. Install one 9-volt alkaline battery (not included)
and replace cover.
2. Plug the telephone line cord (connected to the back of the TAD2012) into the modular wall
jack.
3. Plug AC adapter into standard 120-volt outlet. Plug your phone directly into an outlet, not into
an extension cord.
Answering System Operation
Recording Your Personal Greeting
1. Press and hold down the GREETING control.
2. After the beep, speak towards the front of the base; you have 30 seconds.
3. When finished, release button. Your unit will play back your greeting and
reset to answer incoming calls.
4. Adjust volume control on the side of the unit to set the speaker to the desired level.
Select the Number of Rings
Choose 2,4 or TS (Toll Saver), which programs the number of rings that you want before your unit answers.
To Play Back Your Messages
1. When the message indicator flashes, you have received messages.
2. To hear your messages, press and release the PLAY control. Your unit will automatically
reset after messages are played.
To Save Your Messages
After the last message and 2 beep tones, press the STOP/SAVE control.
IN CASE OF POWER FAILURE OR IF ANSWERING SYSTEM IS NOT OPERATING PROPERLY
If a power failure occurs or the plug comes out of the wall, your unit will shut down until the power is restored. One 9-volt battery must be installed to retain your personal greeting message and incoming messages during the power failure. Occasionally outside factors, such as power surges, may adversely affect the unit. If the unit is not operating properly or if the light continues to flash once power is restored, try these steps:
1. Unplug the AC adapter from the power outlet.
2. Remove the 9-volt battery. Replace with a fresh 9-volt battery.
3. Plug AC adapter back into power outlet.
4. When your unit is initially plugged in, it will check its memory for approximately 3 seconds.
Three deep tones will be heard if you attempt to record a greeting message before this
period.
5. Record a new greeting message.
Indicator Status: Message indicator is consistently flashing slowly.
Reason: No greeting message has been recorded.
Action: Record your greeting.
Indicator Status: Message indicator flashes rapidly.
Reason: A 9-volt alkaline battery (not included) has not been installed or needs to be replaced.
Action: Install a fresh 9-volt alkaline battery. (Battery provides power failure backup. Unit is functional without it).
Indicator Status: Message indicator flashes to indicate number of messages received,
and then repeats.
Reason: Messages have been received.
Action: Press PLAY control to hear your messages.
Indicator Status: Message indicator is lit solid.
Reason: System is in Answer Mode.
Action: No action required. Unit is ready to receive calls.
Conairphone™ Consumer Hotline
Questions? Call the Conairphone™ Consumer Hotline, toll-free, 1-800-366-0937.
Hotline Hours: Monday-Friday 8:30 a.m. - 9:00 p.m. (EST)
Saturday 8:30 a.m. - 12:30 p.m. (EST)
7475 North Glen Harbor Blvd.
Glendale, AZ 85307
Nov 08, 2007 | Conair TAD 2014 Answering Machine
LG 37LG50 37 in. LCD HDTV Logo
51 people viewed this question
Computer Repairing
Computer Repairing
