Question about McCulloch Power Mac 310/320/330/340 Chain Saw Manual Package Owners, Shop, Parts
User manuel chain saw power mac 320 - McCulloch Power Mac 310/320/330/340 Chain Saw Manual Package Owners, Shop, Parts
5 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: I have a McCulloch chain saw- pro mac - 610- the
This saw? Be kind to your elders.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/564ff25e56449e8c88256c2f001cd723?OpenDocument
The IPLs I’ve found for your saw don't show this detail. I suggest you try here:
ArboristSite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9 (free to join)
There is a McCulloch thread. Your saw is held in high regard. I’m quite sure some of the members will be willing to post some close up photos of the set up on their saws. HTH
Lou
Posted on Sep 28, 2009
dontbother10
  • 2220 Answers
SOURCE: I have Mcculloch Mac 10 10 chain saw year unknown
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Posted on Oct 08, 2009
dontbother10
  • 2220 Answers
SOURCE: Re-install chain
Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Look carefully at the picture and your chain, it can be mounted backward; they do not cut when backward.
Posted on Dec 04, 2009
dontbother10
  • 2220 Answers
SOURCE: how to install the throttle cable on a power mac
Join here:
ArboristSite Chainsaw thread (free to join)
Post your question here:
http://www.arboristsite.com/search.php?searchid=3577542
Someone will help.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 29, 2010
Mccullach power mac 320 chain saw rev to high on idel
Either the idle is set to high or you have an air leak at the base gasket on the cylinder.
Jun 06, 2017 | Garden
Tip
McCulloch Chain Saw IPL (Illustrated Parts Listing)
Looking for a McCulloch Illustrated Parts Listing (IPL), Try this:
McCulloch Illustrated Parts Lists:
IPLs (exploded parts lists) are fairly simple, on the underside of McCulloch saws is a small black and yellow tag; the upper number (“Power Mac 320” 600021H or -8 if European) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H or -8). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Utilize the IPL number you just created here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
There are many suppliers of McCulloch parts, some with a better selection than this one. Once you have identified your part try an Internet search for "McCulloch YourPartNumber"
Lou
on Dec 02, 2009 | Garden
McCulloch electric pole chain saw manual model 1510
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! HTH
Lou
Please stress to phone person it is an electric.
Dec 28, 2009 | McCulloch 10" Electric Pole / Chain Saw
Mcculloch eager ****** no oil going to chain
The oiler pumps on Macs are the usual suspect, try this:
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
Build an IPL number like this:
McCulloch Manual
If you can not find parts please repost with the IPL number and I will share my secret Mac parts source.
Lou
Dec 03, 2009 | Drills
Trying to find side cover and pull rope for a 18 inch mcculloch chain saw mark
You need to create "YourIPLNumber" to utilize the supplier at the bottom.
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple. On the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I’ve found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operator’s Manuals: are much more difficult. I’ve dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it!
This is the best supply of Mac parts I have found .
M & D Mower
http://www.m-and-d.com/parts.html
This is a little complicated so I’m going in small steps.
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “YourIPLNumber” HTH
Lou
Nov 24, 2009 | Garden
Where is the release to the blade on a 380 powermac
An IPL for a Power Mac 380 can be found here:
http://www.ordertree.com/modelinfo/MCC/11-600141F-Power-MAC-380AS-%282-Bar-Bolt%29-10%2F84-to-02%2F86-IPL-218024-R1/139.11-600141F-Power-MAC-380AS-%282-Bar-Bolt%29-10%2F84-to-02%2F86-IPL-218024-R1.1.59.1.html
on this IPL (may not be your saw)
Item 1 (2 each on this saw) are bar retaining nuts (loosen to adjust bar and chain; remove nuts and clutch cover (chain brake released (brake pulled aft then released)) to remove bar).
Item 140 is the tension adjuster, loosen it some before attempting to remove the bar.
Remove the chain; then remove the bar.
use this to find the correct IPL for your saw.
McCulloch Manuals
Find "YourIPLNumber" here:
McCulloch IPLs
HTH & Good Luck
Lou
Nov 21, 2009 | McCulloch Garden
Where can I get owners manual to download so I can print
McCulloch Manuals
Operator’s Manuals: are much more difficult. I’ve dialed this number many times (Contact us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! Ive had the greatest success here:
Beg for manuals thread (ArboristSite) (free to join)
http://www.arboristsite.com/showthread.php?t=72322
You are looking for a electric chainsaw manual and I doubt you can find it here but I am occasionally wrrrrr. HTH
Lou
Nov 15, 2009 | Remington Electric Chain Saw
User guide
Found my direction booklet.
Thanks
Feb 22, 2008 | VillaWare 320 Power Grinder Food Processor
McCulloch Power Mac 310/320/330/340 Chain Saw Manual Package Owners, Shop, Parts Logo
97 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
