Question about Bosch 1.1 Mm Chain & Bar Set For Ake 40 / Ake 40-17S / Ake 40-18S Chainsaws
Clutch slipping on bosch ake 30 elec chainsaw
4 Suggested Answers
  • 120 Answers
SOURCE: The chain has come off my bosch ake 40-19e
first loosen the bolts that hold the bar in place. then find then loosen the adjustment screw. Once it is loose, the chain will go back on the bar. Then tighten the chain so there is only about 1/8" movement. (You will want to tighten the bolt so they are snug, when you are tighting the chain) Once that is complete re-tighten the bolts completely.
Posted on Jun 20, 2009
dontbother10
  • 2220 Answers
SOURCE: NEED INSTRUCTION MANUEL
I found your saw here:
http://www.bosch.com/content/language2/html/3381.htm
it's 230v and a european model. I went to the United Kingdom and downloaded an operators manual for it here:
http://www.bosch-pt.co.uk/boptocs2-uk/modules/oragetblob.dll/42970.pdf?db=boptocs&item=OCSHEIMWPDF.m$d$lobvalues&id=42970,4248,20&filename=AKE35-18S.pdf
SURPRISE it's not in english. GL
Lou
I recommend you NOT attept to wire it for 120VAC operation.
Posted on Sep 15, 2009
  • 10 Answers
SOURCE: what oil for ake 30 chainsaw
for gettin speed
Posted on Feb 25, 2012
Motor turns but chain does not rotate
Ok, so if the clutch is turning and everything with the engine is functioning properly, then it can only be the chain or the chainsaw sprocket. Have you replaced the chain just recently? I'm only asking because even though it may be the right length, there are chains that have different sized drive links. Very seldom do the sprockets wear, but I have seen alot of times where someone buys a new chain and the drive links are either too big to sit properly into the sprocket or they're too small...
Obviously your chain brake is off correct?....
Oct 10, 2015 | Bosch AKE 35-19 S Electric Chainsaw
Does the chain AKE 40/19 fit chainsaw AKE 40/17
no it's gonna be two inches longer . you might be able to change chain and bar between saws ? i never done that might work , but would be down on power with larger bar 4 sure , but still would cut wood , just dont enter it in any races
Mar 01, 2015 | Bosch Garden
Whats the difference Bosch 1.1 mm chain for AKE 40 / AKE 40-17S / AKE 40-18S / AKE 40-19S Chainsaws
None that I can find. All are .375" low profile, 57 drive links, Gauge of .043". I have only seen .375" (3/8") LP with semi chisel style cutters.
Feb 12, 2015 | Bosch Garden
My Bosch chainsaw is very temperamental. It try's to start but usually won't kick in until I have given it a few thus. Even then every time I stop the saw it will not start again. The battery is full...
My brother used to sell chainsaws to fire departments.His rule was always do two things first: 1) Get new gas -- it doesn't matter how old you think your gas is. 2) Replace the spark plug -- again, it doesn't matter how new you think it is. He says that this solves 90% of all starting problems.
Jan 12, 2014 | Bosch AKE 30 LI Cordless 36V Chainsaw with...
Replace fuse
There will be a micro switch on the hand guard, so make sure the hand guard is pulled fulley back toward the top hanle, now try again.
Feb 23, 2013 | Bosch AKE 30 LI 36 V Cordless Chainsaw...
I have a bosch ake 4o Chainsaw I live in Crete what no oil do I use, I cannot get bosch biodegradeable oil Here
sae 30 will be ok in the oil tank to lubricate the chain, most manufacturers will recommend bio oil as we live in a green age, mineral chain oil has a non fling addative so as the oil lubricates the bottom of the bar where most cutting is done and not just fly off the end of the bar.
Nov 22, 2012 | Garden
Bosch ake 40 will not cut properly
I do not mean this as an insult but since I have seen it before I have to ask if you put the chain on backwards?
Other then that I know that if you hit dirt, even with a new chain, it will dull it quicker then anything else.
Aug 23, 2012 | Bosch AKE 40-19 S Electric Chainsaw
Chain stops when offered to the wood to cut
either a bad clutch or a bad gear in the drive head
Aug 19, 2012 | Bosch AKE 35 SDS Electric Chainsaw
Bosch 1.1 Mm Chain & Bar Set For Ake 40 / Ake 40-17S / Ake 40-18S Chainsaws Logo
64 people viewed this question
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Are you a Bosch Garden Expert? Answer questions, earn points and help others
