Question about Samsung NP-N110 Netbook
Can't exit out the bios setup screen
I was trying to use pcloginnow but the screen froze and it won't let me do anything
2 Suggested Answers
SOURCE: bd-p1500 won't turn on. It
Need code and remote instuctions?
Posted on Aug 19, 2011
Resized c drive, now windows won't start. How can I reinstall windows from windows disc
Hi Terrez,
  1. To reinstall windows from Windows disk Insert the disk in the drive, restart the computer and enter the BIOS setup.
  2. In BIOS setup, make the DVD Drive the first-starting device.
  3. Save and exit BIOS setup.
  4. Now the computer continues the restart. Look at the screen. When a message appears, you have only a few seconds to hit any key on the keyboard in orter to start the computer from the disk.
  5. From there, Windows setup will continue.
Feb 24, 2013 | Acer Aspire 3680-2682 Notebook
Black screen won't boot up
1.) unplug system
2.) remove side panel
3.) remove the battery from on the main board
4.) press and hold the power button for 30 seconds
5.) replace battery, plug in system
6.) turn on
7.) enter the bios by pressing the enter setup key displayed
8.) restore default settings, save and exit. (optimized settings work great)
Dec 26, 2012 | Acer Veriton Z290G 185 320GB
Mercury mother bord not loding satup manu with all f key and 'del' stop in start screen
1) Look at the bottom of the Mercury logo screen when it comes up.
2) Memorize or write down the -> enter BIOS Setup, or enter CMOS Setup key.
3) Restart the computer.
Let it go to Windows, then Start > Turn Off Computer > Restart.
Won't go to Windows? Hold down the CTRL and ALT and DELete keys AT THE SAME TIME. This will restart your computer.
AS SOON AS the monitor screen goes blank, (Windows is restarting), tap on the enter BIOS Setup key repeatedly.
Tap in 2 second intervals.
Hear a series of beeps? They are Stuck Key Error Code beeps, and you are causing them. Ignore the beeps.
Computer is off?
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup (CMOS Setup) key.
The enter BIOS Setup window goes by F-A-S-T. The above method/s will get you into BIOS Setup.
Regards, joecoolvette
Nov 05, 2012 | Computers & Internet
I turned on the computer and the screen stayed blank
Hi
Turn the computer on while pressing F1 several times as it loads.
Did it load?
Now try same procedure but press F8 instead.This opens the BIOS setup page.Don't change anything but 'save changes and exit'.
Feb 29, 2012 | Toshiba Satellite P105-S6197 Laptop
I have a Toshiba Tecra M7 that won't boot and up until this morning nothing worked. This is what I've done so far this morning WHEN it does decide to boot. 1. Power up computer from off with ESC...
Your hard drive may have gone south. Remove it and check with diagnostic software. Bad sectors in critical areas of operating system data will do this.
Apr 01, 2017 | Toshiba Tecra M7 Tablet PC
Restored to factory default cd/rom dvd drive not installed driver not found
This is likely a BIOS problem.
If you restored factory defaults, the BIOS may have reset to a default configuration as well, one that may not include a setup for your CD drive. Assuming this is what happened, here are some steps to try to get it working again. Note that the pictures are from my computer, and what you will actually see will depend on yours, but it will often be similar.
1. Shut down your system if turned on.
2. Immediately after turning on your computer, look for instructions for 'Setup' or 'Configuration'. There will be the name of a key to press; often this is one of the F keys, such as F2, F5, or F12, or the DEL or ESC key. It varies from computer to computer. You must press the setup key before the screen advances. If you miss the prompt, simply reset your computer and try again. This will open the BIOS menu. hyblademin.png
3. Look for 'Drive Settings', 'Drive Configuration', or otherwise a block of settings referring to "Primary," "Secondary," "Master," and "Slave" drives, and use the keyboard to navigate the menus to get there. Be sure you read the instructions at the bottom of the screen so that you know which buttons to press. hyblademin_0.png
4. Again paying attention to the controls at the bottom of the screen, make sure each drive is set to AUTO. If that setting isn't available, try setting either the Primary or Secondary (whichever one shows no drive) to CD or CD/DVD.
5. Press the ESC button or see the instructions at the bottom of the screen to learn how to exit your BIOS. Make sure you select Save/Exit from the list of choices. If you accidentally change any other setting, simply choose Exit (do not save), and you will be put back at the boot screen. You may then try again.
I hope this helps. Good luck!
May 04, 2011 | E-Machines emachines (emachinees) CD-ROM...
I was try and already load in the windows xp setup screen (blue setup screen) but after I press F8 to agree with continous then show me like a caution page you need to exit setup, the descripiton is like...
Hello
1. On POST (Powerup). enter BIOS by pressing F2
2. Tab along to the second option "Main"
3. Goto last option "SATA mode" & press enter.
4. From the small selection display select "IDE mode"
5. Save & exit the BIOS. This will then set the SATA mode for XP to be recognise.
Now try install XP.....DO NOT set this back to SATA Mode after you install the XP as it will NOT boot.
Nov 04, 2010 | Acer Aspire 5720-6661 Notebook PC
How do I reset bios on HP laptop?
To restore the BIOS default setting, open the BIOS Setup screen as follows:
(i) Turn off the computer and wait five seconds.
(ii) Turn on the computer.
(iii) When the first screen displays:
(a) Immediately press the F10 key if your computer was built in 2006 or later (came with Vista).
(b) Press the F1 key if your computer was built before 2006 (XP or earlier). Press the key once every second until a BIOS Setup utility screen opens.
NOTE: On some Compaq Presario computers (before 2002), press the F10 key at the logo screen.
(iv) After the Setup Utility screen opens, press F9 key to select and load the BIOS Setup Defaults .
(v) Press F10 to Save and Exit .
(vi) Using the arrow keys select Yes and then press Enter when asked Exit Saving Changes?.
Sep 20, 2009 | Computers & Internet
Samsung NP-N110 Netbook Logo
99 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
