Question about Roper RES7646KQ Electric Dryer
Defy dryer, not heating
Hi I have a defy autodry, front loading dryer, which is not drying, but otherwise working. how and what and where do i check for or change the heating element? or what to do. I live in Malawi Africa and there are no service providers available.
    Problem Solver:
  • 16 Answers
Check that you have 220v first. Your dryer will work on 110V but will not dry. You need to check all thermostats with a ohm meter (be sure to unplug dryer), they should be 2 ohms or less. Set ohm meter to 1x. If they are good go to heating element (your ohm meter should be on 1X as wel. You need to check to make sure you have continuity (however, this does not mean that it is not bad). You need to take it out and visually inspect it to make sure it has no breaks in the coil. If it does you can buy a rewire kit for runder 30 bucks for most models.
Posted on Jan 06, 2009
Defy autodry trouble shooting
Check the door latch. If that is faulty, the machine just remains in limbo until replaced. If you close the door and try and select a program and it wont proceed, normally means door latch is faulty.
Jul 03, 2014 | Washing Machines
Defy autodry tumble dryer
This will be bearing noise, the front of the drum uses a felt strip as a bearing and this can wear causing a metal on metal grinding sound, or it could be the rear bearing. You need to dismantle it to investigate further.
Mar 06, 2012 | Cell Phones
Defy autodry, comes on timer works but will not tumble
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 15, 2011 | Dryers
I've bought a Defy Autodry tumble dryer, but the black "rubber" on the door keeps coming out, which then pushes the door open, and the machine then automatically stopped. Can i just replace...
A TUBE OF CONTACT CEMENT WORKS WONDERS ON THE SEALING RUBBER - JUST FOLLOW THE INSTRUCTIONS ON THE TUBE . IF ITS GOOD ENOUGH FOR DOOR SEALS IN THE AUTOMOTIVE INDUSTRY ITS GOOD ENOUGH TO HOLD YOUR DOOR SEAL IN PLACE - GOOD LUCK.
Jul 26, 2011 | Dryers
Where can i find a maneul on a defy 721
Check in this two links:
- Defy AutoDry
- Defy AutoMaid
Both in PDF format.
Apr 25, 2011 | Ovens
DEFY AUTODRY WIRING DIAGRAM
disconnect dry and in the back of dryer in top left hand corner is your diagram, looking from back of dryer, just remove the 6 screws from the top panel at the back of the dryer Good Luck Tim
Dec 26, 2010 | Dryers
No manual for Defy Kombomaid - cant get dryer to work
The dial to the left operates the dryer. Select amount of drying time, push same start button as for washing machine and voila! Also you can go directly from wash mode to dry mode without machine pausing. Select your wash cylcle, your drying time and push start.
Apr 14, 2009 | Dryers
Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Sep 07, 2007 | Whirlpool GEQ9858J Dryer
Roper RES7646KQ Electric Dryer Logo
1,041 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
