Panasonic plasma TH-42PA60A Having display problems. Pulling apart to clean out dust. Gone from bits of red through blacks to how it is in video now. Some times it comes good for a few seconds. Have
Try making adjustments to the VA on the power supply and adjusting voltage on the SC (Y-Sustain) board
Posted on Oct 28, 2012
  • 3 Answers
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
what is a UPS?? mines doing it too
Posted on Oct 05, 2008
  • 61 Answers
SOURCE: Power light blinking 2 times
2 blinks means the unit is having problem with 12 volt supply.
while power on you can check 12DC on power supply before shutdown.if the voltage is constant before shut down I would recommend to replace D board.
Posted on Oct 09, 2008
SOURCE: red light flashes 10 times - Panasonic TH-42PX6U
hey there! i finally figured it out!! If you have a computer hooked up with the HDMI cable in the back of the TV and the computer is either on screen saver mood or sleep mood then it is trying to make the television go to sleep aswell. So the only way you can have a computer hooked up to the TV is if you use the front HDMI hook up. pretty weird but thats what was wrong with mine. Hopefully that was the problem :):)
Posted on Nov 25, 2008
tvservice306
  • 458 Answers
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Posted on Nov 10, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Posted on May 10, 2010
Panasonic tv 42 inches plasma model no TH-42PX80EA one red blink light
One blink code indicates main board issue (ALSO can be a BAD panel)
Here is YouTube Link:
https://www.youtube.com/watch?v=HUxD72qoays
Mar 30, 2018 | Panasonic Televison & Video
Panasonic TH-42PA60A Part number
If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 24, 2016 | Televison & Video
Problem with plasma display on Panasonic TH-50PH9UK television
there is an x-buffer and a y-buffer. by disconnecting these and noticing if the picture changes you will be able to identify if it is on of these boards or if it is the screen itself. Youtube also has a lot of helpful videos. hope this helps
Jan 21, 2015 | Panasonic TH-50PH9UK 50 in. Plasma...
Pananasonic TH-42PA60A
This is a television, not a camera. If you repost this query in a forum dealing with home electronic entertainment equipment, you may stand a better chance of getting a helpful reply.
May 02, 2017 | Cameras
Panasonic plasma TH-42PA60A screen is black and won't display the menu or picture. It still has sound though. The batteries in the remote have been checked.
It will need to be checked and boards replaced to know which if any are causing this trouble--I presume it happens on all inputs including the rear ones.
Nov 02, 2012 | Televison & Video
When you use a input the screen fuzzes red. It's a Panasonic Plasma TV TH-42PZ85U. It was made in 2008. Started when i was playing a game. It did it a few times and now its permanent. On the Video Inp
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 19, 2017 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Panasonic TH-42PD25 The picture is black with
Make sure if your using the video input jacks, that the yellow is plugged into Video 1 and the same with the audio.Red & White. If your using Component, they are color coded- Red Blue & Green along with the Audio In -Red & White. It sounds like you have the video in the wrong jack.
Oct 28, 2009 | Panasonic TH-42PD25U/P 42 in. Plasma EDTV
My panasonic th-50pz800u won't power up. The power lights blinks 10 times then pause 10 times then blinks a again?
A red light blinking 10 times means that a video board has gone bad. Contact Panasonic to see if they will help you out.
Jan 04, 2009 | Panasonic Viera TH-50PZ800U Plasma TV
VERTICAL LINE ON TH-42PX70B
there is nothing you can do.the display  panel is defective and you must replace it
Oct 28, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
