Question about Fisher Price Doodle Pro Glow
What kind of markers can be used with the doodle pro glow I can't find replacements anywhere
Magnetic issue with magna doodle
You might have gotten a bad magna doodle you might have to call the company and get anew from them.
Dec 30, 2012 | Mattel Fisher Price Magna Doodle (PC)
97cc baja doodle bug won't start
Assuming that the engine can be turned over with the starter, the most likely culprit is it's not getting enough fuel, especially if it's been sitting for 6 months or more. AT YOUR OWN RISK, remove the air duct after the air cleaner and pour a shot-glass full OR LESS of gas directly into the carburetor or throttle body. It should start and at least run briefly. If it does, then add at least 3-5 gallons to the fuel tank. If you've run out of gas, then adding just one gallon is not enough. Today's fuel-injection systems have pressurized fuel lines which need at least a gallon just to fill all the pumps and filters between the tank and the engine. Good Luck, TechJoel
Nov 04, 2012 | Cars & Trucks
Keep blowing fuse for running lights on trunk, fender marker lights, tail light and front turn signal running lights. can't find bare wire anywhere.
Not necessarily a bare wire. Could just be a slight broken spot in the insulation. Check the wiring inside the rear fender. Sometimes the tire gets into the wiring harness and chews things up a bit. This usually happens on lowered bikes.
Jun 23, 2012 | 2007 Harley Davidson FLHTCU Ultra Classic...
Doodle penguin instructions
Doodle Penguin instructions available for download here: http://reast.net/?p=185
Jan 27, 2012 | Crayola Toys
The paintballs just fall straigt out of the gun or shots like 5 at a time
The part that is bad Tippmann calls a "ball latch". It's a small orange rubber part that keeps the ball in place before the marker is fired. The parts is inexpensive it is common in most paintball stores or can be found online at www.tippmannparts.com
I highly recommend taking this paintball marker to a local pro shop to have the part replaced. You can service this marker at home but is not easy to put together if you have experience working on then, they have a few springs under tention that make it tough to put back together. If you are interested in doing the repair yourself I highly recommend doing it on on a clean floor in a clean room so when you disassemble it it will be easier to find the springs that could shoot out.
One thing that will make it easier is to leave the feedneck on. It will keep one less spring from jumping out at you, just a tip from a pro. I also highly recommend not using a spray lubricant and to only use oils in you tippmann made for paintball guns.
Sep 19, 2011 | Tippmann 98 Custom Act Paintball Gun
How could i know if my friends are on line even they are in invisible mode
The easiest way to know is to use the "Doodle Environment", once you are logged in, double-click the user who might be hiding and from the IM window, click "Environment" and then "Doodle", if your friend is online hiding there as invisible, then the Doodle environment will load and you can play with the doodle, but if he/she isn't online, you'll see "Waiting for your buddy to load Doodle" message on the page.
Hope this helps,
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 23, 2010 | Yahoo Messenger
On/off sound
hi
What sounds like? Like a frying pan? a high voltage sparking? or what?
Thanks!
Dec 27, 2008 | Curtis CM32020S 32" TV
Fisher Price Doodle Pro Glow Logo
182 people viewed this question
Top Fisher Price Computers & Internet Experts
Danny Kuhlmann
ray gallant
Tom Chichester
Are you a Fisher Price Computer and Internet Expert? Answer questions, earn points and help others
