Slow pc My computer is running very slow. I believe I need to remove some programs, but I do not know which ones to delete.
    Problem Solver:
  • 34 Answers
Just go to the control panel and add/remove programs here you'll find list of programs installed on your PC.
Uninstall the programs those you don't use.
you may also want to remove features of WINDOWS which can be done from the next tab.
you may try increasing the PC's speed by
- defragmenting the HDD
- removing startup programs
- increasing amount of RAM on your system.
if you have old system, try older versions of softwares if you don't use the newer version of the softwares.
Please do rate the solution
Posted on Jan 03, 2009
    Genius:
  • 1,913 Answers
Remove all temp files from omputer.
type in run "chkdsk /r"
then press "y"
then restrt the computer.
then it fixes error on harddisk.
My system is running slow
Slow computer If you have a virus program installed, it is most likely is running a scan on your hard disk. It can slow down your computer especially if you have a large hard drive. After scanning is completed then the computer will be faster.
To make your computer (hard disk) lean and mean, uninstall any programs you do not use.
Also you need to maintain your hard disk by running Disk Cleanup this will remove old temp files and old compressed files etc.
This will reduce the number of files the virus scanner has to scan. Plus running Defrag. this makes your files contiguous so the system can access files off the hard drive quicker because it does not work as hard.. Disk Cleanup and Defrag should be carried out at least once a month.
If you have 512Mb of RAM installed then installing more RAM will speed up your computer. After installing your graphics card, you may need to disable the built-in graphics card in the BIOS for the new graphics card to work properly.
Apr 22, 2013 | Computers & Internet
COMPUTOR SLOW RUNNING
control panel-add and remove program(check if you got more then one antiwires on the computer, if yes then remove it)
%temp% in run window, delet all temp files from it
(if any pop up comes in while deleting it..just press skip)
remove unwanted program or games or anything which you know but dont use it any more from the computer(add and remove program)
try your connection in windows browser(try www.google.com inside the run window and see if its any faster, if it is then could be you browser, reset would help)
Jan 06, 2013 | Acer Computers & Internet
My computer is running so slow need help please
Registry Fragmentation Registry is accessed by almostall the installed programs and your operating system itself. Why is computerslow and freezing has to do with the fragmented registry data. You have todownload a PC Optimizer software that includes Registry Defragmenter tool suchas Reginout to perform system maintenance tasks. b> Too Many Programs areInstalled Installing too many programs makeyour computer slow and freezing. You have to uninstall the unwanted programs. 1. Click Start ' Control Panel.
2. Click Programs ' Uninstall a Program.
3. Select a program to remove.
4. Click Uninstall button.
5. Follow the wizard.
6. Reboot the computer after completion. b> Insufficient RAM Sometimes computer runs slow andstarts freezing due to an insufficient RAM. You have to install additional RAMsif required. b> Lack of Proper Configurations You will feel that your computeris slow and freezing if you haven't set Windows for best performance. 1. Right click My Computer.
2. Select Properties.
3. Click Advanced System Settings.
4. Click Advanced tab.
5. Click Settings button under Performance frame.
6. Select the option Adjust for best performance.
7. Click Apply ' OK ' OK. b> Junk Registry Keys Storing junk entries in theregistry makes your computer slow and freezing. You have to delete such junkentries using a Registry Cleaner and PC Optimizer software.
Feb 25, 2011 | Microsoft Windows XP Professional SP2
My computer too slow always get the not responding reply.
Eliminate Viruses and Spyware
Step 1
Run your antivirus program. There may be something slowing your computer that you can remove. It is a good idea to run your antivirus program every week.
Step 2
Remove spyware. Run a good spyware tool at least twice a month.
Step 3
Use a pop-up blocker, if you have one. Check your antivirus program.
Dispose of the Extras
Step 1
Delete your document files for anything you no longer need. Saved pictures, audio and video files in particular can slow your computer.
Step 2
Remove unwanted programs from the Control Panel area. Old toolbars or games the kids downloaded off the Internet are a good place to start. Look for software you no longer use, such as the old printer you threw out last year.
Step 3
Clean out your email. Old messages are a constant drain on your computer's resources. Go through every folder, deleting everything you do not need. Leave no mail! Finish by emptying the Deleted Items folder.
Step 4
Turn off unnecessary programs. Check your taskbar for icons that show running programs. Disable anything you are not currently using.
Run Maintenance
Step 1
Run the Disk Cleanup tool located in your Control Panel. (Windows only. For other operating systems, please check the Resources section below.) This will remove temporary files, cookies and unnecessary components to speed up your computer.
Step 2
Defragment your computer. Defragging takes some time, but will speed your computer significantly. You can find the tool in your Control Panel. Run it monthly.
Step 3
Check for disk errors. Sometimes corrupted files slow down your computer. To find and fix these files, Go to My Computer and right-click on C drive. Choose Properties, then Tools.
Nov 22, 2010 | Computers & Internet
Running very slow. Takes a long time to boot up and slow to respond to programs on this computer. I've deleted many programs I rarely use as a result, but it still is too slow for my satisfaction. I bought...
there is many issues that can cause pcs and laptops to run slow removing programs probably wont help that much you need a cleaner program like ccleaner or auslogics boostspeed which is a good one! www.ccleaner.com or www.auslogics.com/en/software/boost-speed
Jun 29, 2009 | Dell Inspiron 710m Notebook
Slow and constent ly having to {restore } refresh screen back up
why you are getting this issue is norton internet security as wellas trend micro both of them are firewalls so better you can keep one firewall so better remove the trend micro.
Mar 14, 2009 | Gateway GT5056 PC Desktop
Speed
Actually there are many reasons why your computer will boot up slow. I can only give you some tips.
Click start>run>type msconfig. On the startup tab uncheck any program that you don't need on startup.
Delete Prefetch files. Prefetch files are being created by windows when you open a program so thaht the next time you open the program it will pull up faster. But having too much prefetch helps slow your computer down on startup because it loads on startup. to delete go to start>run> type prefetch. delete all that you will see there.
For trojan problems the best way to remove them is by running a scan of updated antivurus program. If you don't have one. try SuperAntispyware. it worked for me. =)
Oct 09, 2008 | Microsoft Office Professional 2007 Full...
Computer Speed
ok what do you mean by slow the computer running slow or the internet?
Jul 14, 2008 | Computers & Internet
Computer runs slow
it doesnt have to do ( AOL or McAFEE ) causing your computer to run slow . let me ask you a couple of question so I can pin point your problem .
1 do you downloads photos & music to your pc?
2 do you surf a lot thru the internet ?
3 do you perform the DISK CLEANUP ? if not , one of the main problem to have a PC to run slow is the MEMORY CAPACITY of your PC . let me know so I can show you some steps to improve your PC . thanks and hope it helps
Apr 19, 2008 | E-Machines eMachines Desktop PC
Slow performance of pc
hi,you will have to increase the RAM size to whatever u can afford,, thats the only issue as of now.. let me know
Jan 10, 2008 | Acer AL1912B 19" LCD Monitor
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
