Question about Ricoh Aficio 2022 All-In-One Laser Printer
Error code SC 548 on Ricoh Aficio 2022copier. Need to reset m/c
2 Suggested Answers
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
What's your question? I HAVE AFICIO 2022 COPIER AND ITS GIVING ME THREE ERROR CODES SC548, SC792, SC870 WHAT COULD BE THE PROBLEM AND HOW CAN I SOUGHT IT OUT
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point !
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
http://copierliquidationcenter.com/Copier_Repair_Service/index.php?topic=44.0
for Error sc792 see
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/35515-ricoh-aficio-2022-a.html
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
My copier Ricoh Aficio 1515mf is writing call for service
You must specify the error, displayed in lcd, something like Sc322 or sc 548, etc..
That will tell the technician witch part to look,laser, fusion,optics etc. Penzance are right! Go on, post it!
Feb 13, 2015 | Ricoh Aficio 1515MF Digital Copier 15cpm....
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Code shows SC 548 how do I clear this
SC548: Fusing unit installation error - Definition - [A]
The machine cannot detect the fusing unit when the front cover and right cover
are closed.
- Possible causes -· Fusing unit is not installed
· Poor fusing unit connection
check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion,
this sc 548 usually happens when paper jam occurs and user does not properly fit the fuser... also not fiitted properly due to some foreign object in between fusing belt and the sensor...
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps. if this doesnt solve ur problem then try contacting ur ricoh service tech
good luck
Aug 09, 2009 | Ricoh Aficio CL3500N Laser Printer
I have a Savin 9955DP/9965DP copier with a funtional service code SC548-00 is there anything i can do to fix the problem?
The SC 548 error usually occcurs in the fuser section when it ahas been reset incorrectly the drive and gears are not locking properly or the sensor has not registered the fuser correctly I would look in these areas check the seating of the fuser you can reset this in the modes with 5-810 sc reset then turn off.
Jun 24, 2009 | Ricoh Aficio 450 Copier
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
I have a ricoh 1027 but it does work codes sc 548
You have a problem with your fuser - either an overheat, or lack of heat. Can only be reset by technician in a service mode, once it is fixed
Feb 19, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
Ricoh Aficio 2022 All-In-One Laser Printer Logo
279 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
