Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
What i need check n is thz common?
Only used once n wont turn on doesnt smell burnt . . . . .
  • Craftsman Master
  • 14,363 Answers
Make sure drain plug is close,oil is good and pressure settings are correct.I have one,never had a problem.
Posted on Oct 28, 2012
Wont shift out of first,and speed ometer wont work
check tranny fluid,if it is low,,add some,if it smells burnt,your tranny is shot,common problem with voyagers
Apr 01, 2015 | 2002 Chrysler Voyager
My trans wont go in any gear and smells like its burning it smokes to.makes a weird whining noise when started
Doesnt sound good. Check your transmission fluid. If it is dark instead of pink or red, it is burnt. It will also smell burnt if you smell it. if its burnt the trans is probably toast. The only thing you can do is service the transmission by changing the filter and all of the fluid and see how it goes. Im not saying that this will work but this is the only thing you can do before officially pronouncing it DOA. Sorry..
Mar 26, 2011 | Ford Focus Cars & Trucks
My amp stopped working after 2 days from the day bought it. It stayed on standby for a while, about ten to fifteen minutes, but once I switched it on it started humming and making crack and pop noises.I...
Take it back for warranty replacement or repair since you only had it for 2 days. Since there is burnt smell this could be very serious problem. Probably a fuse blew due to any of several problems.
The pilot light runs off a rectified output of the power transformer but it is fused. There are three sopplies from the transformer and any of those could have a short and blow the main fuse or their individual fuses.
Take it in as I stated as this is NOT DIY repair. There are high voltages in this unit and if one is not adept at electronics you probably would not be able to repair it anyway.
Nov 29, 2010 | Peavey ValveKing VK112 50W Combo Amplifier
I have the same problem but nothing has worked! There's a bit of a burnt smell inside the unit but it powers up ok - well to the point of the annoying 'eject' sounds, and the more frustrating problem of...
This is commonly a 'capstan motor' the part that drives the tape. This causes no eject, sometimes a burnt smell and blown internal fuses.
The motor needs replacing, possibly a fuse and a check for why it has a burnt smell.
May 04, 2010 | Canon MV800i Mini DV Digital Camcorder
The engine wont turn over when i try to start the
I would guess , if the engine wont turn over, the starter is kaput, burnt out
Apr 08, 2010 | 1992 Pontiac Bonneville
Van quit moving all at once fluid clean no burnt
P0743 Torque Converter Clutch Circuit Electrical
P0750 Shift Solenoid A Malfunction
P0760 Shift Solenoid C Malfunction
check all the ground wires on the harness look for broken wires or a plug pulled out
Mar 24, 2010 | 2004 Ford Freestar
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
43 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
