Question about General Electric Washing Machines
General Electric washing machine makes lights in house dim on and off.
When machine goes into agistate mode it dims the house lights.
4 Suggested Answers
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
venexcsd
  • 1185 Answers
SOURCE: I have a Kenmore 90 series top load washing
Get a repairman in to check for a damaged drive train on the washer and an electrician in to check the wiring in your house
Switching a high power electric shower on can cause some voltage drop which in turn causes the lights to dim for a short period.
But having a washer stalling on wash doing it sounds as if you have some major issues with the house wiring.
Posted on May 29, 2009
  • 26 Answers
SOURCE: during the wash cycle often the lights throughout
My husband says.... get an electrician in there FAST. If its dimming all the lights in the house it probably isnt your washer it is probably a problem with the connection in your wall.
Posted on Sep 26, 2009
Help my washing. Machine lights up but it's dimmed light not as bright as normal will not start
Could be a bad circuit breaker or outlet. You need to check the outlet with a voltmeter. If it is ok then i would think the washing machine internal power supply is going out.
Jul 06, 2016 | Washing Machines
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
diy.stackexchange.com/.../lights-lowering-in-the-kitchen-when-turning-o...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
blog.1000bulbs.com/what-is-causing-my-house-lights-to-dim/
Dec 21, 2015 | Microwave Ovens
Electric trips out when machine switched on
ok, it may be best not to use that machine until you have upgraded it to its proper breaker. From what you said, the lights in the house experience a voltage drop when the machine is on. This can only mean one thing, they are on the same breaker. The breaker will have 4 inputs, where to two outer ones will provide the 240 volts needed by your machine. If you have a multimeter or voltmeter, check the outlets for the 240v range for the washer, and 120v for the outlets in the vacinity and any other rooms where the lights may dim. the possibility still reamins that the house is just old and the wiring is bad. then that would be a rather expensive fix. Idealy you want your washer and dryer on a breaker together, but seperate from everything else. A high quality breaker goes for $20, cheap ones are $8. Also, when touching the breaker, make sure it is flipped to the off possition, i have personaly felt the grasp of those connectors many times and believe me, it will wake you up.
Jun 04, 2010 | Hotpoint Aquarius WD640 Front Load...
During the wash cycle often the lights throughout the house dim and brighten continuously, there is a clicking sound coming from the machine, what is the sorce of the problem.
Sep 26, 2009 | Washing Machines
I have a Kenmore 90 series top load washing machine, when it goes into the wash cycle, the aggitator functions , but jerks and makes a clicking sound. Also, causes the lights to blink in the house. I...
May 29, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 topload washer agitation cycle noisy and high current
Sounds like a motor problem drawing to many amps dimming lights. Check drain pump to see if pump has obstruction in it causing resistance. Run machine while pump is off to see if light dim.
May 29, 2009 | Kenmore 24032\24036 Top Load Washer
GE frontloader electric dryer is causing an electrical surge
Check the connectors and lugs on the powercord ,wire and breaker box
Apr 07, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
Agitator
try putting a new coupler in it
Mar 19, 2008 | Kenmore 20722
PS Comes up on Display
has a bad motor start winding thats why your lights dim change motor
Dec 03, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Washing Machines Logo
35 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
