Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Can it be put on a timer so it won't come on so often
  • 5,245 Answers
Yes.
If spa plugs into ordinary outlet, then choose heavy-duty outdoor timer. Use P1261 with GFCI or P1121 without GFCI.
If outlet already has GFCI, do not use two GFCIs
http://waterheatertimer.org/pdf/Intermatic-P1100-series-sell-sheet.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#P1261
If spa is hard-wired, then install T101 for 120volt, or T104 for 240Volt
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#T100-series
Posted on Oct 29, 2012
I have power & the timer still works.... But the
check and make sure both breakers in fuse box are still on if they are then look for abstruction where door closes
Sep 08, 2012 | Dryers
Won't stop, have to manually open door
Sounds like a bad timer. Your dryer is a Whirlpool product.so a replacement timer should be easy to locate. If the timer is advancing but the dryer won't stop, the problem could be the control unit. Run another load of clothes and take notice of the timer's position. If it doesn't run out, then it's very likely the timer. The video below shows step by step instructions for replacing the timer unit.
Mar 30, 2012 | Estate TEDS740JQ Electric Dryer
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
Whirlpool Cabrio dryer temperature won't get hot? What causes this problem?
Runs but will not heat
1.loose wiring----check terminals & wiring
2.defective centrifugal switch in motor---replace switch ( check linkage to motor)
3.defective timer---replace
4.open heat element---replace heat element
5..defective operating thermostat---test thermostat, replace if defective
6.fan or it's pulley loose on shaft---tighten set screw
7.incorrect heat or timer settings---reset timer
8.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
9.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 25, 2011 | Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
I have a intermatic T104m pool timer. The clock works but it doesn't shut off. I have to flip the breaker to shut it down. The manual override switch flips back and forth but nothing happens. ...
If you are flipping it off manually and it still won't shut off then the contacts are burnt together internally.
This means that you need to change this timer out....
If you switch it with the same timer you will not need to change the whole box... the old board will snap out and the new board will just snap in the old box, making the change out much more simple.
heatman101
Aug 15, 2011 | Intermatic T104M 208-277Volt 40-amp Timer...
How do I turn off the delay timer? When I set it up, the timer automatically sets it on a 3 hour delay. I have moved the up & down arrows but it won't set at 00:00 unless I unplug it. Then I set...
No offense intended but you need to step away and read the instruction manual step-by-step. One point I can make: The three hours you're seeing in the display when you first plug the unit in are simply telling you how long the default white bread mode is going to take to complete. It's merely a counter that counts down so at any time you glance over at the machine you'll know how much longer it's going to be before the bread is finished. The digital display has NOTHING to do with the delay timer until you start pressing delay timer arrows.
Hope this helps!
Jun 20, 2011 | Breadman TR777C Bread Maker
Had to change battery. Since I did this the day will scroll several times and will not let me set the day, nor the time, nor the mode. Is my unit toast ?? As it was working till I changed the battery.
Most digital timers suggest resetting as last-step effort to restore functionality.
This particular timer is reset by removing battery.
Try removing battery again. Otherwise it seems the timer has gone bad.
HB88RC is discontinued product.
Replacement is heavy-duty Intermatic HB800RCL 2-outlet or HB800RCH 1-outlet timer.
http://www.smarthome.com/25078/Intermatic-HB800RCL-Heavy-Duty-Digital-Appliance-Timer/p.aspx
http://www.smarthome.com/48715/Intermatic-HB800RCH-Outdoor-Digital-Timer/p.aspx
Less expensive and less reliable timer Woods 59403 with 1-outlet has quite a few 'timer won't work' questions on fixya.
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
Jun 19, 2011 | Intermatic HB88RC - 7-Day Programmable...
I have a t40404r. one timer has been unused. i attempted to wire it up this week. the manuel switch works when i flip it to on but the timer/wheel/motor will not work. i have two 110 wires attached to...
If it was me the first thing I would do is to verify that you have the proper voltage to the timer that you are hooking up. I would also take the timer that is working and replace it with the one that isn't and see what happens. This may tell you that the timer is bad. I would put the working timer in the place you are trying to put your new one. This can tell you if your power supply is right. Hope this helps. Thank you
May 16, 2011 | Intermatic 125 Amp Control Center T40404R...
I am trying to charge my cars battery but I am not sure where to put the 3 way switch.
Best solution is to use the Auto mode, since the unit will monitor the battery, and automatically switch to trickle charge when the battery is full. In the Auto mode, it won't overcharge the battery.
Feb 28, 2011 | Schumacher 10 Amp Fully Automatic/Manual...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
114 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
