Question about Canon EOS 20Da Digital Camera
Canon 20da The picture remaining couter flashes after a photo is taken even when the camera is turned off
When you open and close the cf compartment it stops. The pins look ok and i have tried different cards
ginko
  • 19396 Answers
SOURCE: Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Nope, this is not card anymore.
As you know CF is card failure, sometimes this cause to start error 99 , that is lens error , even if there is no problem with the lens.
This happens because the built in software in the camera can get messed up after an error CF.
You fix the problem calling Canon, they will guide through upgrading the firmware in your camera.
First ensure that you are using the camera menu and command to format the new card, and that new cards are properly inserted into the machine.
Call Canon support to get a firmware upgrade.
Posted on Feb 13, 2009
JoeO700
  • 80 Answers
SOURCE: White streaks on all photos but not video
Your camera has a defective CCD imager. Please return the camera prepaid to Canon in New Jersey, they are replacing the CCD at no charge to the customer. This is a known issue and is resolved by many of the manufacturers using the Sony CCD element in their cameras at no charge. Good Luck my friend. Joe Weibel customelectronics.org
Posted on Feb 28, 2007
t00nz
  • 4738 Answers
SOURCE: Canon powershot S230 Camera will not take picture now
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 16, 2007
mcomijohns
  • 477 Answers
SOURCE: Canon 10d digital camera Err 02
Most likey your problem is the cf card reader when ever the camera was made they could have not heated up the board all the way causing a cold solderjoint after time this joint becomes week and gets disconnected on the back side no visual damage is seen causing you the error you are getting. best thing to do is take it to a repair shop and have them fix it or the manufacture should repair it for free because there is no fisical damage.
Posted on Jan 16, 2009
SOURCE: Canon EOS 20D shutter error
Hello - I figured it out. I had the exact same problem. The shutter failed and it had to be fixed by Canon. Apparently that happens after the shutter fires so many times (like a click-count on a printer). I just got my camera back and it's doing awesome now.
Posted on Apr 08, 2009
Canon rebel T1i won't take a photo and gives message busy
Try formatting your card in your computer and then in the camera. If problem persists then try another memory card. You need to determine if it is a card or a camera problem
May 12, 2014 | Canon Cameras
I have canon g1 3.3 i turn on and it flashes letters CF what does that mean
Strange problem this one. Could mean insert a Compactflash (CF) card or that the CF card is full of maybe even Custom Functions are set. A photo of the display would help me better to solve the problem.
Apr 09, 2013 | Canon PowerShot G1 Digital Camera 3.3MP
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
I have a Kodak Easyshare model dx5430 digital camera (5mp). It has worked like a champ for years. Last night I was at an event when the image display went dark at picture 31. All preceding photos were able...
May 01, 2010 | Canon PowerShot A75 Digital Camera
Not capturing pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 12, 2010 | Canon PowerShot A530 Digital Camera
HELP 350d still not turning on/screen not working
Hmmm... doesn't sound too good does it? Have you tried another CF card? I know you said it doesn't work even without a card but...
Also one last thing to try is to tkae out both batteries, the main one and the slim watch style backup battery that sits right next to the main one under the cover labelled CR2016. Leave them both out for an hour and see what happens. NOTE this will probably reset your camera to factory defaults and may reset the photo numbering counter back to zero. Worth a try?
Feb 10, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT unable to access compact flash card
check all the pins in the CF socket in the camera are there, or are not bent, repair is expensive if broken
Jan 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Shutter opened but won't close
Switching off the camera from the main ON/OFF swit5ch should close the shutter. If it doesn;t, try removing the battery or the CF card. It is possible to manually increase the shutter speed even in bright sunny conditions.
Jan 09, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Extreme Difficulties With My Canon
Problem #1
this is not a problem.. if you leave the camera in the ON setting for long enough.. it goes to sleep ... in order to conserve battery life.. you need to keep some of the buttons pressed for a bit for it to wake up... e.g. keep the picture taking button depressed for 5 secs.
Problem #2
If you were checking the pictures after just shooting them then its probably a CF card problem. You can also get the same error .. i.e. corrupted files from the cameras perspective.. if you use a CF card reader and try to change the pictures on the card.
You should try to connect the CF card that has those pictures to a computer it might be able to open them.. .
Otherwise try another CF card.
Nov 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Photo recognition
try using a CF card reader ... when you hook the CF card reader to the PC .. it will open up the cf card as a drive.. you can download the pics by copy and paste...
reformat the card after that
Nov 28, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon EOS 20Da Digital Camera Logo
37 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
