Question about Maytag Washing Machines
Maytag npetune washer leaks at the pump outlet and drain hose. I see the leak even when the pour some water in the washer
My maytag neptune MAH5500BWW leaks at the pump discharge and the hose connection. I pulled the hose out and inspected could not find anything wrong. Put it back with some teflon tape on the barbed section of the pump discharge and still leaks. I just poured some water in the washer to test and leaks out all of it . Not sure what is wrong , cant find anything wrong with the hose and can't see any cracks on the pump - please help
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Is it the tub to pump or pump to drain section?
Posted on Oct 29, 2012
SOURCE: maytag neptune mah5500bww leaking water
Here is the solution I found that worked for me, there is a small drain hole at the bottom of the boot that is connected to a drain hose. Remove the hose and clean out to make sure that it has not become plagged. replace hose and reattach boot. Mine stoped leaking imediately.
Posted on Aug 20, 2008
SOURCE: Kenmore 80 series leaking
well you can try filling the outer tub separately.with what you mentioned, the problem is certainly not with the drain hose or the pump. fill the tub separately with some water and if the leak is seen then the problem is certainly with the outer tub corrosion or crack on it.
Posted on Dec 13, 2008
onthejob5130
  • 640 Answers
SOURCE: water leak from bottom
defective pump...onthejob
Posted on Jan 17, 2009
SOURCE: We have a Maytag Neptune
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Posted on Jun 04, 2009
  • 20 Answers
SOURCE: maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Posted on Jun 20, 2009
The pipes froze and busted in my garage which cause water to burst in my Maytag Neptune front loader washer Now the water won't drain Please help
That machine has an electric water pump, The first thing I must ask is has it completely thawed out? There is a rubber hose that goes from the tub to the pump, if the water in the hose is still frozen in the hose or in the drain hose, it will not empty itself.Also the water water level switch is in the top of that hose. Another possibility, is the pump or the water level switch could be damaged. You can access the pump by taking the front panel off. That is not hard to do, requires removal of the door and a couple of other screws.
Mar 07, 2015 | Maytag Neptune MAH5500B Front Load Washer
Washer runs its corse but water will not strain
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jan 11, 2013 | Maytag Neptune Washer
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Leak
You have 3 areas to check. Drain hose, water pump and hot/cold water valves. Any of those 3 areas can be the cause. Most often leaks are caused by loose hoses, but neptunes use a plastic water pump that can clog and lose bearing water seals as well. Try the easy options first, then if those solutions don't point to the cause, remove the front cover and check the water pump for moisture.
Mar 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500BWW is giving an "nd" error. The washer will not drain water. All I here is a hum.
Remove water pump, check for thongs, baby socks and sometimes hair pins or even screws can obstruct the water pump.
Simply remove the pump and remove the obstruction that is keeping it from draining.
Let me know how that works out.
http://www.pdxappliance.com
Feb 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
MASHER MAH5500BWW WONT DRAIN
this unit has a electric drain moter open the machine front . under the tub remove the drain hose and look for the a blockage if none present replace the whole drain pump assembly
Jul 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leaks from weap hole in bottom of the plastic housing
The Maytag's have always had problems with those front door boots leaking and not draining thus leaving a bad mildew smell. What the problem probably is is that the hose that connects to the weap hole is cracked and needs replacing. I would suggest just replacing the entire boot along with the hose. The boot is a pain to replace though, it might take a tech to get it done for you. Let me know if you have any other questions and let me know if this information was helpful. Good luck.
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune washer
check arround the rubber bellows that the door seals aginst, maybe a hole in it, could be a pump leak drain hose leak
a lot of could bees i know but one of these
Apr 09, 2008 | Maytag MAH6500 Neptune Front Loading...
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune mah5500bww leaking water
Feb 22, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
