Question about Westinghouse L2046NV Monitor
Westinghouse lcd L2046nv i dont know what
My name's cheesey795, i'm still not sure what to do or replace. i dont want to throw it away if fixing it is going to be cheaper than a new one. ya know?! if u can help me with my problem, i sure would appreciate it, thanks :)
    An user who is expert in 3 categories / brands.
  • Westinghouse Master
  • 848 Answers
This trouble maybe power supply or inverter boards is defective. first you can test the voltage of the multr,and then check which part is defective.From can find those parts if you have any question,please let us know,we sincerely hope we can help you! you can also check this boards whether suit you:DAC 19M005DF 295302800 Westinghouse 27 D015677 Power Supply Backlight...
Posted on Nov 11, 2014
How to open a L2046NV
Jest push electric swche next push rimort buten
Apr 20, 2012 | Westinghouse L2046NV Monitor
Goes blinky
Hey there.
I have recently written a tip on the Flickering/unstable LCD/CRT monitor screen problem. I suggest you give it a read and let me know how it goes.
You can see my tip here:
Enjoy my tip.
Sep 23, 2011 | Westinghouse L2046NV Monitor
I have a Westinghouse L2046NV Monitor and it does not come on. The monitor has gotten worse over time. I have removed the power board and found the six capacitors to the right are all bulging and 3 of them...
You may want to get the capacitor kit, but you need to get the board number used in your monitor version.
Eample of the kit:
I will not use RadioShack caps, since they are not low ESR type which is required for switching power supply, they will not last if you use generic electrolytic caps.
You should remove one cap at a time so you can see what the value is for each cap.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 18, 2011 | Westinghouse L2046NV Monitor
How do you open a Westinghouse L2046NV monitor? I tried removed the two screws on the back and it still won't come apart? Please help!
Stand removed? Try lifting up the front bezel and then use thin screw driver to separate the front bezel from the back, but watch out for any attached to the front bezel. see exaples here:
Basic LCD monitor troubleshooting guide:
Failed TV, Monitors, Caps :
Capacitor kits: he can make you a set of caps for you.
Oct 30, 2010 | Westinghouse L2046NV Monitor
Turned on the monitor this morning and it would not come on. Several tries, no luck. The 'on' light flashes green/red together. Bought 12/07. Can you help? (I've borrowed a friend's monitor to contact...
If you are to DIY repair, please read below so you will at least know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
May 01, 2010 | Westinghouse L2046NV Monitor
Westinghouse 22 lcd monitor. faint click and went
More likely the filter caps failed and may have taken out the inverter fuse and the MOSFET in the inverter circuits also. yoo need to open it up and inspect the inside, see example of failed monitors due to bad caps:
Mar 09, 2010 | Westinghouse L2046NV Monitor
How do I reset my Westinghouse L2046NV monitor -- this monitor will turn on and light up and the picture will come on but then go off after 1 or 2 seconds -- any ideas ?
Hello, reseting your monitor will not solve the problem, what you need to do is replace the inverter board, if you would like to know price and availability for this model please send a request to, they will let you know if they have the board, how mutch it is, and they will also troubleshoot with you over the phone at no charge to make sure that is what you need.
Dec 15, 2009 | Westinghouse L2046NV Monitor
I need a parts for a Westinghouse LCD Monitor. Model number is L2046NV
What parts do you need?
You can get service, parts and DIY info from LCD Parts - click on this link to their WEB site : -
Oct 21, 2009 | Westinghouse L2046NV Monitor
Faint No Image / Backlight Out on Monitor Westinghouse L2046NV
Open up the unit. You should replace the damaged/bulged caps on it. You should also check the two MOSFETs before the transformers on the inverter section. If that does not do it, there's one SMD fuse beneath the card that normally blows when the MOSFETS fail. You should either replace it r bridge it with solder.
May 30, 2009 | Westinghouse L2046NV Monitor
Westinghouse L2046NV Monitor Logo
160 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
