Electrical Supplies Logo
I lost the spring for my coleman powermate 5500 generator where do I buy another ??
5 Related Answers
J. Bradshaw
  • 121 Answers
  • Posted on Jun 20, 2009
SOURCE: i have a coleman powermate generator with a robin
Normally that is a 5 HP motor
protek480
Craig Butler
  • 1730 Answers
  • Posted on Aug 01, 2009
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sheldon Dedek
  • 912 Answers
  • Posted on Jun 12, 2010
SOURCE: Coleman Powermate Maxa5000 ER Plus Generator
Unfortunately, a service manual is not going to be easy to find. You may be able to order from Powermate, but you may want to save your money and spend it on consumables.
I am guessing that you are looking for a service manual for the engine itself? Good Luck on that one as well, as Tecumseh has folded. Post the engine model# and other information found on the tag, somebody (perhaps myself) may have the manual you need and send it to you via email.
Parts for the engine itself are likely to be hard to find, consider an engine replacement. It likely will be cheaper.
Sheldon Dedek
  • 912 Answers
SOURCE: I have a Coleman Powermate 5500 Generator. It is
This engine was not built with quiet in mind, it was built to be cheap. upgrading the exhaust is your best bet and likely the cheapest. Talk to a small engine shop about the possibility of using a muffler from an ATV.
Super Trap makes a fantastic muffler, if it will fit your application (most do). A link has been provided at the end. When you are looking at the various options, you will notice that a rating in db units. Reducing noise by 3db is half the original noise level.
if you can, go with the SuperTrapp. If still noisy (probably won't be), then add on the resonator as well. Downside to using aftermarket is that you will have an exhaust stack / system that sticks out the side of the generator. Upside is that you will be able to think quietly about how much the exhaust sticks out.
And no, I don't have any connection with Jack's, they are just the first hit that came up. Now that you know that something is available, you can do more research on it.
http://www.jackssmallengines.com/Quietmuf_index.html
Sheldon Dedek
  • 912 Answers
SOURCE: coleman powermate generator model #pm0545003
http://www.powermate.com/contact.php
1helpful
I need to know the procedure in starting a Coleman Generator 5500/6875 11.0 hp Tecumseh. I just purchased it and the previous owner lost the manual for instructions. Please help me. Dolly
I'm not familiar with this particular generator but starting most of these is pretty much the same.
Turn all switches to the generator OFF locate the Carbuerator and put the choke on if it has a small bulb pump it a few times, now here is a trick I use I buy a can of starter fluid and spray a quick spray close to the air intake or air filter. This should work.
Coleman Powermate 5500 runs rough
vent in gas cap.
fuel filter.
dirt or gum in the carb.???
6helpful
2answers
Top Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
