My toshiba 40xv551d lcd tv wont turn on and there no power going to it but the fuse is fine
4 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: poloroid lcd model tlx-04011c wont turn on,,red
Most likely the TV has a power supply related problem. It can still have a problem without blowing the fuse. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Posted on Jul 05, 2009
aymantn
  • 109 Answers
SOURCE: lg 32 lcd tv will not turn on checked fuse in plug
eBook about LCD repair
Posted on Mar 17, 2010
freetek
  • 5568 Answers
SOURCE: my toshiba 40xv551d lcd tv
You might try pulling the AC plug overnight in case it is simply a 'lockup' of an IC. If it still will not turn on, it is likely that the main power supply has failed and must be repaired or replaced.
Posted on Mar 07, 2011
Why won't it turn on?
Fairly new TV will not turn on. - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions/Fairly...TV-will-not-turn-on/.../27334...
Feb 29, 2012 - My Toshiba 32dt2u1 television that I got this past Christmas will not turn on at all. I press the power button and it nothing happens. The green. Tv no power: Model 50L1350U
Jun 20, 2014
My laptop won't turn on!!!
Feb 19, 2014
40RV525U Toshiba LCD TV won't turn on.
Nov 22, 2011
55HT1U turns on by itself, wont stay off
Sep 19, 2011
More results from forums.toshiba.com
Questions & Answers for LCD TVs - Toshiba
answers.toshiba.com/answers/0293/category/...tvs.../questions.htm?...
Is my TV compatible with netflix? ... How do I reset my 32C120U tv so I can perform another channel scan? .... My tv won't turn on with remote or manually.
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
Jan 08, 2016 | Toshiba Televison & Video
Toshiba television won't turn on after power flicker
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
My flat screen tv cuts off and on while the power but is on what should i try before i buy a new one .... I have a ...
Toshiba TV power outage - AllExperts
en.allexperts.com > ... > TV/VCR/Stereo Troubleshooting
Feb 3, 2011 - TV/VCR/Stereo Troubleshooting/Toshiba TV power outage - no power... we had a power outage (they're calling rolling blackouts due to power grid ... but I admit I'm now afraid to turn it off for fear it won't come back on again.
Toshiba 32c120u LCD TV won't turn on - Tom's Guide
www.tomsguide.com/answers/id.../toshiba-32c120u-lcd-turn.html
May 27, 2015 - My toshiba tv is flashing but won't turn on with remote or power botton on tv itself ... dang this worked for me but after a minute it stoped working.
Dec 28, 2015 | Toshiba 58L7350U 58" 3D 1080p LED-LCD TV -...
TOSHIBA 55SL412U wont turn on
If fuse should blow up, surely there should be a resown for that. You must first check out the reason, and then insert an other fuse of same rating. If you wish to get some details, http://electronicshelponline.blogspot.com/ Pull up older posts. Check for damaged component/s at its main power supply regulator board.
Dec 22, 2013 | Toshiba 55SL412U LCD TV
My toshiba 32av500u tv wont turn on
Video display card could be bad but I wouldn't rule out the power supply just yet. It breaks off in several directions and the lead going to the display driver could be bad. Put a meter on it to see.
Nov 18, 2012 | Toshiba 40E210U 40 in. LCD TV
Toshiba REGZA 40E200U 40 LCD TV wont turn on after it was working fine the night before.
Your TV needs servicing, Most likely you have a power supply related issue. Do you have any experience with electronics repair?
Sep 01, 2012 | Toshiba REGZA 40E200U 40" LCD TV
My toshiba 40xv551d lcd tv will not switch on.please help.
Mar 07, 2011 | Televison & Video
My Toshiba 27af44 wont turn on it has power Ive checked the fuse but it wont turn on
There are several, not very expensive, parts in the power supply that may have failed; some of them worth under a dollar. One does need some technical knowledge and two basic instruments to locate the failed part(s) however so the labor charge will be many times the parts cost.
I do recommend you have it repaired because when you decide to buy a flat-panel (LCD, plasma) type set, it will not likely last as long as your Toshiba has. The newer sets are being slapped together in China. I hope you have a surviving independent TV service shop in your area.
Jun 26, 2009 | Toshiba 27AF44 27" TV
After power surge my tv (toshiba 52') will not power on
after a power surge if you dont have in on a surge protector it probably fried the main board in the tv so it wont work anymore..woudl probably be cheaper to buy a new tv than to try to repair the one you have now
Dec 15, 2008 | Toshiba 57H93 57" Rear Projection HDTV
Toshiba 42HP66 Picture fades in when turned on. After taking off the back  panel noticed the Zsus board had a bad fuse on the 180V Side. After replacing  the fuse the tv wont power on and the power supply...
To start, the module with the blown fuse will have to be replaced. The rest of the boards will have to be verified to know which other ones may have been the cause of the failure.
You will have to give the set out for factory service to have it working again.
Jerry G.
May 11, 2008 | Toshiba 42HP66 42 in. LCD Television
TV WONT TURN ON
If it's less than a month old, you shouldn't have taken off the back. I subjest taking it back to where you bought it from and get it exchanged or get a refund.
Nov 27, 2007 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
Televison & Video Logo
161 people viewed this question
Top Televison & Video Experts
