Question about Sharp UX B700 Plain Paper Inkjet Fax
White "Stripes" across page
On all my incoming faxes, I've suddenly started getting white stripes across the page (horizontally) where it doesn't print anything. Please help!!! Thank you!
  • Anonymous Dec 12, 2007
    same thing
    Genius:
  • 1,003 Answers
REPLACE PAPER AND THE INK CARTRIDGE
Posted on Jan 23, 2008
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
  1. Open the printer driver setup window
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
    The Custom Settings dialog box opens.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  9. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    The second pattern is printed.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  12. Check the printed pattern
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
    The third pattern is printed.
  15. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
I have a Sony Trinitron KV27V42. When I turn it on, it has horizontal white stripes across the screen. But when I hook it up to a vcr or a dvd player, I don't see any white stripes. What could be the...
Hello
Check its AC input connection for any loose contact. Check it with pluging it on an other plug point in your home. It is a type of interference, and some electronic and electrical equipments in your home may also cause this trouble when it works. Check these please. OK.
Mar 20, 2011 | Televison & Video
Black Stripe on outgoing faxes
If the stripe is a thin line, the scanner glass is dirty, if it is wide stripe you have a bad scanner block. EXPENSIVE
Jul 01, 2010 | Brother IntelliFAX 4100 Laser Fax
Toshiba eStudio 2830c-getting a light line across
Hello sir; Is the stripes allway in same place and you use document feeder to copy, then you have to clean up a piece stripe glass on the plateform, otherwise ,you have to change drum cleaning blade or drum cartridge.
Dec 24, 2009 | Toshiba Office Equipment & Supplies
Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
Dec 03, 2008 | Minolta EP1030/1030F CS/PRO Copier
Blank vertical stripes on incoming faxes
1st. Print a report. If the blank stripes are still there, you must remove the drum and t6oner combination and clean the laser glass located on the bottom of the machine.
If the blank stripes do not appear, then the fault is on the scanner of the sending fax machine.
Feb 25, 2008 | Brother IntelliFAX 2800 Laser Fax
Printing in stripes
Possibly time to replace the printer.
Mar 07, 2017 | Canon Pixma MP500 All-In-One InkJet...
Sharp UX B700 Plain Paper Inkjet Fax Logo
132 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
