I have a Toshiba DR570KU, and I need help changing the record mode from xp to another setting where I can record longer. It was initially set where I could record for several hours, but somehow I changed the settings, and now it only records in xp mode
likha
  • 790 Answers
SOURCE: need help with dvd recorder
checkout the OSD mode in your remote control!
Posted on Oct 07, 2007
likha
  • 790 Answers
SOURCE: problem with dvd recorder
checkout the OSD mode in your remote control, you can adjust the size in you DVD.
SOURCE: sony RDR-HXD770 timer record problem.
See the discussion on the Amazon uk site for this product in silver! it will fix this problem!
Posted on Jun 17, 2008
SOURCE: locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Posted on Oct 01, 2009
SOURCE: set up sony RDR-VX535 recorder to DVD1. now remote does not work.
See the manual on page 22.
The solution is to reset your remote code to DVD1 (default is DVD3).
Press the ENTER button and NUMBER ONE button simultaneously for at least three seconds. Viola, control returns.
Posted on May 23, 2010
I have a toshiba dr570ku/i only get 2 hours recording time
If you have the manual it should give you the instructions under timer recordings. If not you should be able to find the manual on their website.
Oct 30, 2012 | Toshiba DR570 DVD Recorder
Put new harddrive in toshiba satellite Windows xp keeps reloading any ideas
Go into the bios (look for "press xx to enter bios" just after you turn it on xx will be somthing like del, f2 or something)
Change disk access mode to different settings.
Failing that google "Fix master boot record XP"
Oct 03, 2012 | Sony VAIO VGN-NR120E/S Notebook
How to finalize a dvd
Which specific model of DVD recorder do you have? You need to finalize the disc on the unit that wrote the files/movie to disc. For the Toshiba DR570KU, press Setup on the remote. Then enter the DVD menu (use the up/down arrows to navigate and then press Enter). Select Finalize and then press Enter. Highlight Yes when asked to confirm the finalization step and then press Enter again. Wait for the recorder to finish the process (it will take several minutes). Note: you need to leave some space on the disc for the finalization data to be added to it.
You can also set the unit to auto-finalize when the disc is full or a timed recording ends. For the second item, you will not be able to add content to the disc if a short program was recorded unless you use a rewritable DVD. (Then you would will need to unfinalize the disc. See the manual.) This is accessed from the General Settings menu from the Setup button. Go to Recordings and then select the Auto Finalize setting. Select when you want the disc to finalize and then turn ON the feature. Press Setup to exit the menu.
The manual for the DR570 is available under the User's Guide tab here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2805105&rpn=undefined&modelFilter=DR570KU&selCategory=2797338&selFamily=2797342 . Toshiba has the manuals to most of their products here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp .
Please add a comment with the specifics of your recorder for more information. I hope this helps.
Jul 01, 2012 | Toshiba Televison & Video
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
When I turn my Toshiba D-VR4 recorder on, it won't go to DVD
I figured it out with absolutely no help from the manual. To initiate recording, you have to press the timer/set button. After the DVD recorder finishes recording, you have to re-press the timer/set button to take it out of recording mode. I think their book needs to explain that more clearly.
Sep 29, 2009 | Toshiba D-VR4 DVD Recorder/VCR
Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Mar 02, 2009 | Toshiba DR410 DVD Recorder
Blurry video recording
Since the camcorder returns to the auto shutter setting and the auto exposure setting when it's switched into Night Capture mode, I would say that might be your problem.  Change your shutter and exposure settings. To do this, switch to Camera mode, turn the menu dial to the setting you wish to change then press enter.  You may have to play with the settings until you get the desired picture. Remember, faster shutter speeds for faster action (stop action), and longer exposure settings for darker situations. Let me know if you need more help.
Feb 16, 2009 | Samsung Video Cameras
Too fast playback of video cassette
Initially, I am inclined to think that nothing is wrong. It is just most likely that that particular tape was recorded in a different speed other than what your VCR is capable of playing. This is a form of compression wherein a longer recording/playing time is squeezed into the same type/kind of tape. The various settings are SP, LP, EP or even an XP. Pls click here to give you an idea of the recording time/speed at different settings.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 09, 2008 | JVC HR-J461MS VHS VCR
Changing swap file memory
Two possible reasons:
1. Your harddisk where the swap is located no longer have that much free space to allocate for your desired swap size.
2. You have to click on the Set button after you have changed the Initial & Maximum size, OK, OK, OK
Hope this be of some help/idea. Post back how things went or should you need additional information.
Oct 14, 2007 | Computers & Internet
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
