Question about HP PSC 1610 All-In-One InkJet Printer
Error Code 0xc0620004411:lib_micci2.c
My printer will not print. I get the above error code, and sometimes it just continues to say "initiallizing"
  • Anonymous Jan 10, 2009
    me too wtf?
    Genius:
  • 1,913 Answers
Reinstall your driver and also check usb connection cable.
Posted on Jan 03, 2009
Error 09B207 007A0F4F
Switch the Printer OFF and ON again and wait for the initialization. If the Error code continues to appear, switch the Printer OFF. Remove the EIO Card (if installed) and make sure that the Hard Disk Drive is installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the Printer ON again. If the error codes 09Axxx or 09Bxxx appear then replace the Hard Disk Drive. If the Error Code disappeared after removing the EIO Card, then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If the Error Code reappears, then the EIO Card could be faulty. Replace the EIO Card. If Error Code 09Cxxx appears after initialization, then replace the Electronics Module. Once the Error Code has been solved, print an Internal Demo Print to make sure that the Hard Disk Drive is functioning correctly. If the Error Code reappears, then use the above information to troubleshoot the problem.
Dec 22, 2015 | HP DesignJet 1055CM Plus InkJet Plotter...
How to fix OXC1AB0003 error on the P PhotoSmart 2575
Remove the cartridges and do a full reset without them in by removing the wall socket and re-plugging.
More information has been answered in another thread.
Error oxc1ab0003730 Lib micci2 tango
Apr 07, 2015 | HP PhotoSmart 2575 / 2575v / 2575xi InkJet...
My samsung ml-1610 series printer's software is installed but the printer is not installed
my oj 7310 all in one is give me error mesege 0xc0620004 411:lib-micci2.c
Nov 03, 2009 | Samsung ML 1610 Laser Printer
Dell 1700n error light after print job.
double pressing the continue button twice , the printer will give a secondary error code: then check here (link below) : toner is low, with blinking lights = Replacing the Imaging Drum
http://support.dell.com/support/edocs/systems/1700n/en/index.htm
download the manual above and look under Troubleshooting->Maintenance for your printer-> replace imaging drum...
good fortune, please leave rating...
May 11, 2009 | Dell 1700n Laser Printer
I keep getting error 1-2070
Resolution
Check to see if the required files are present:
  • Go to C:\WINDOWS\system32\kodak. Check for 2 folders "kds_aio5000(for AiO 5000 series printers) and kds_aioesp(for ESP series)
  • Depending on printer model, open kds_aio5000 or kds_aioesp.
    • For kds_espaio it should only have the lib folder. It doesn't have the ekaiowia.dll
  • Inside the lib folder it should have cct.ekpgct, hippo.dll. Both for kds_aio5000 and kds_aioesp.
  • If hippo.dll is missing then try the following:
Option 1: 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 2 Option 2: 1. Insert the Home AiO CD. Go to CD rom drive\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 3 Option 3: (manual installation) 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner or on CDROM drive ..\printer\scanner 2. Open the aioscnnr.cab file then look for the missing file(files needed: cct.ekpgct, hippo.dll, and ekaiowia.dll) Extract the files anywhere on to the computer (Desktop is preferable). 3. Copy the cct.ekpgct, and hippo.dll to C:\WINDOWS\system32\kodak\kds_aio5000\lib 4. Copy the ekaiowia.dll to C:\WINDOWS\system32\kodak\kds_aio5000
Apr 12, 2009 | Kodak ESP 5 Printer
Hp 2355 all in one error message
open the rear access door and clean the rollers with a cloth, dam it with little water and unplug the machine and press and hold the ON button for 1 min and release the button and plug in the power cord, it should resolve the issue.
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Scanner error 6 for hp color laserjet 2840
After the hp color laserjet has finnished initiallizing it gives me error code 6
Dec 07, 2008 | HP LaserJet 3050 All-In-One Printer
Sysytem Error 009B002 007A046F
System Error: 09xxxx (Non-Continuable)
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Switch the Printer OFF and ON again and wait for the initialization.
n If the Error code continues to appear, switch the Printer OFF.
n If the Error Code disappeared after removing the EIO Card, then
n If Error Code 09Cxxx appears after initialization, then replace the
Electronics Module
n Once the Error Code has been solved, print an Internal Demo
Nov 21, 2008 | HP DesignJet 1050c InkJet Printer
Unable to init error message and and machine error 4f
i can not print any documents it keeps coming up as Init unable 4f please help ?
Sep 27, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
202 people viewed this question
Seeker5211
Seeker5211
