Question about Garden
The pully on my generator pulls back very hard when trying to start , it only does this when engine go,s to fire up
Let me know if this was helpful
Posted on Oct 30, 2012
Generator wants to start. It fires for a couple of seconds then shuts down.
there will be a oil level control unit on the engine sump that has a habit of failing on a regular basis
test it or replace it.
Jun 22, 2015 | Dewalt DG6000 Heavy Duty 6000 Watt Gas...
I have a Briggs & Stratton 5500 watts generator that I hardly pull the rope for start, begins stuck then its loosen again and again gets too hard to pull, any suggestions please help
If the unit is older it could have heavy carbon in the cylinder heads, it could be a ring sticking and binding, do a compression test. Compression is high or mechanical binding.
Feb 24, 2015 | Briggs Stratton Portable Generator 305cc...
WILL NOT TURN OVER OIL FILL A PULL START
Sounds like you may have oil in the cylinder. This is caused by engine tipping over or maybe the generator fell over on its side, etc. This ends up making it really hard to pull start the engine.
Anyway, try removing the spark plug (make sure the ignition wire is pulled out of the way) and then turn over the engine a few times (5 or 6 times) to get any oil out.
Then replace the spark plug and try again to see if it starts.
Mar 15, 2011 | Coleman Powermate Powermate 5000W...
Pull start cord got pinched. Dumb me took off
Yes you can put the spring back in but it takes patience. Wind the spring inside the pully first. Then install the cord on the outside of the pully. Make sure you wind both in correct direction. You probably should replace the cord while you have it apart. The parts would be listed by the engine brand and model number, not by MTD. Probably a Briggs & Stratton engine? You can go to their web site :www.briggsandstratton.com to get part numbers. Or you can try a place like www.jackssmallengines.com
Jul 18, 2010 | Mtd 22" Yard Machine Push Mower
Trys to fire now and then . It has a weak spark.
start with a daignostic test, simplely remove the airfilter, tiurn the switch on,spray a one second spray of starting fluid into the carb, pull the engine, if it fires then you have identified the problem, bad gas and dirty carb. If it does not fire on starting fluid then you have either a compression problem like a stuck valve or an ignition problem, calling for a new ignition module. Good luck, white back if I can help more?Jim
Dec 19, 2009 | Coleman Powermate Powermate 5000W...
McCulloch 5700, 11 HP Starts easy with 2 pulls and begins running fine. Then it start dying and back fires,revs up and down, back fires. Then will run normal for a few minutes and will start revving up...
Sounds like you may have a wire shorting out. Check all ign wires and make sure one hasnt rubbed through. Maybe take off your front cover and make sure something isnt shorting out your coil contacts. Hope this helps
Nov 02, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Overhaul the engine need Specs.
well you have all electrical parts now you need fuel squirt some fuel in the carb and try start it it will fire for a second thats it get back to me
Sep 14, 2009 | Briggs & Stratton Power Products 5,550...
Lawnmower rope pull start, has rewound back into housing and locked? How can I get it to release so that I can reconnect it to the lawnmower handle?
You will have to take the top off.It has 3 bolts on the sides of the motor.Pull top off,hopefull you just have pull rope out to fix.The rope on the pully has a spring in the bottom of the pully.Do not pull out pully,you will have a hard time gettig it back in.
Aug 29, 2009 | Craftsman Garden
Dirt bike thats hard to start..
needle and seat are worn out in carb, to much fuel is flooding cylinder. remove carb, clean, get new needle and seat, set float. problem goes away. pull your plug after kicking. its probably wet.
When you push, or pull start you evacuate excessive fuel, when engine is warm, easier to start extra fuel burns easier.
Mar 15, 2009 | Yamaha YZ 250 Motorcycles
Serpentine belt came off need to know how it goes back on
this is hard to exsplain without showing you a photo ,but i will try. first get the belt around the engine crankshaft which is the pully closest to the bottom and center of the engine. when standing in front of engine start to lead the belt to the right and connect to power steering pump then up to generator, next thare is going to be a smooth pully not groved like the others to the left,put the smooth side of the belt on bottom of this pully and continue left to the ac/compressor go around ac/compressor andstraight down to the belt tensioner , and then right over to the water pump which has a smooth pully not grooved. remember the smooth pullys will always carry the smooth side of the belt and the grooved pullys the grooved side of belt. the belt tensioner will half to be released by a serpantine belt tensioner tool sold at your local auto parts store. these instructions is for 3.8 liter engine, if you have a 4.6 liter engine it will be different, so repost stating that you have a 4.6 if this dont help
Dec 22, 2008 | 1997 Mercury Cougar XR7
Garden Logo
147 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
