Question about Sanyo EM-C1800 Microwave Oven
Sanyo em-c 1800 sparking inside at top
Sparking
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 27 Answers
That's not good at all....
check to make sure there isn't any food at the top of the microwave, also, if your microwave allows maybe try turning down the wattage when you cook such as cook on medium or Low wattage.
Also, you may need to just get a new microwave.
Posted on Oct 28, 2012
2 Suggested Answers
gopakumarg43
  • 74482 Answers
SOURCE: Hi; i have a sanyo
Hello
Reasons for arcing or sparking are
[1] Materials to be avoided in the oven were used. [2] The oven is operated when empty. [3] Spilled food remain in the cavity.
Use microwave safe cookware only.
Do not operate with oven empty.
Clean cavity with wet towel.
OK.
Posted on Jun 24, 2011
Sparks when cooking
Make sure no metal item (forks-spoons or oven rack) is touching the outer wall of the microwave. That will cause sparks. If all that is OK then there is usually a metal fan type blade in the microwave top called a stirrer blade that may be out of place and rubbing the cavity causing sparks. Try to pin point the spark area so you know where to look for the problem. Sparks usually mean metal is touching metal somewhere.
Mar 29, 2015 | Whirlpool MH7135XE Microwave Oven
Viking vmos200 sparking
If there is spark please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is leaking and sparking to the ground. As you have mentioned it was stored, it is quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Now switch the microwave power on and use a cup of water to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. Replace with same type. If not check the waveguides within the cabin for food particles that can burn and spark, check for rust that can corrode and spark when the ceramic paint has worn out.
If there is heating without any issues, you can use the microwave safely
Click on replacing waveguides: http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Jan 31, 2013 | Viking VMOS200 Microwave Oven
My microwave sparks
Nov 30, 2011 | Microwave Ovens
When I use my microwave, it seems it was spark happening when I use it. I'm afraid to test it again. Please tell me how I should know it's safe to use
2 things cause sparks.... a damaged Waveguide RF window or bare metal inside the cooking area. If you note bare metal you can sand and paint it with an appliance enamel paint. (no lead paint!) Just make sure to only sand the area your painting as any sanding scuffs not painted will hasten a repeat performance of the sparking routine. The RF will bounce off bare metal and cause the sparking. Once PROPERLY painted it no longer sparks.
If it is coming from the area of the Waveguide RF window... Make sure the window is replaced before next use.
Thanks for choosing FixYa,
Kelly
Apr 21, 2011 | Frigidaire Model PLMVZ169GC Microwave Oven
My ge is sparking inside. There's a screw not covered and I covered it and still sparked.
I think the magnetron is leaking with traces of open metal exposed out. It will be better to clean the cabin throughly and make sure that there aren't any exposed parts.
If the sparks are still coming in then remove tthe magnetron and check for signs of spark marks on it , if so it must be replaced.
Make sure that the wiring is intact and there is no foreign particles stuck within the magnetron.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have an Amana ARGS7650ww. The igniters will not spark.
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Aug 20, 2010 | Microwave Ovens
My microwave sparks when I turn it on.
Its called arcing, its either the card needs replacing (in the cabinet)or the the magnetron is sick and make sure its nice and clean in the cabinet
Oct 18, 2009 | Welbilt MR622W Microwave Oven
Sparks
usually sparks come from turning and cooking with nothing inside the microwave..if there is grease or something on the bottom the heat will generate a spark
Mar 22, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Popping and shooting sparks
Hi There!
Check behind the "Wave Guide Cover" on the inside cavity. There may be moisture or food residue behind it. Should be a cover that is plastic or Mica. Really strange that it's sparking being new. Also check that you use plates without gold or silver trimmings (Crockery or porcelein). This will also cause sparking. Remember that microwaves will always go to the first organic source in its path. The wave guide cover, if soiled, is very close to the tip of the Magnetron and will therefor result in arcing. Good Luck, JUS004
Feb 26, 2008 | Frigidaire PLMV169DC Microwave Oven
Sanyo EM-C1800 Microwave Oven Logo
99 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Oscar Netto
Oscar Netto
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
