Question about Asrock N68S Ucc Socket AM2+ GeForce 7025 DDR2 RAID AVL mATX Motherboard
Error beeps my pc running win7 ultimate x86 runs for a short time the beeps 6 ormore times then locks up, it will sometimes unfreeze but locks up yet again ????
  • 105 Answers
It's overheat or critical error problem
try to remove dust from coolers and memory modules
and if it don't work try to change PSU or RAM or CPU
Posted on Oct 28, 2012
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: power on the pc cpu
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working hope this helps also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer
also check the Cmos battery and computer ram make sure they are securely seated
hope this helps
Posted on Jul 22, 2011
Why does my pc beeps 4 times and will not boot up?
Sounds like you mother board is the problem.
Did you drop it, add memory.......
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
Jun 16, 2014 | IBM Computers & Internet
X58 pro e hard to cold start
Three long beeps may signify a keyboard error, and 3 short may refer to memory error. These are best guesses, because MSI uses several BIOS manufactures. Test your RAM one chip at a time to help isolate bad dimm.
Aug 31, 2012 | MSI X58 Pro-E Core i7/ Intel X58/ DDR3/...
Computer freezes / locks up after running a while,
Sounds like it's overheating. Check to make sure your graphics card cooling fan and CPU cooling fan are working. If they are add some case fans. Get a can of compressed air and clean out all the vents and fans. You can also use a vacuum with a hose attachment to clean it.
Jul 21, 2012 | Acer Computers & Internet
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
Toshiba Satellite A205-S4607 Audio Driver on Windows 7 x86
Instructions to Fix Windows Error Code 0x00000017:
Apr 12, 2017 | Toshiba Satellite A205-S4607 Notebook PC
Atari act of war: direct action runtime error?
First uninstall and reinstall the whole game. Then make sure you have the latest patch V1.06. If that does not help here are good instructions for installing AND running the game as administrator and with compatibility mode (if you are running Vista or Win7:
http://www.ataricommunity.com/forums/showthread.php?t=659761
This also has helped to solve a lot of issues:
http://www.ataricommunity.com/forums/showthread.php?t=455721
Apr 18, 2010 | Atari Act of War: Direct Action for...
Im sorry to tell you this mate but the driver needed is not supported by windows 7 its just one of those glitches that new OS's have give it time the driver will come out
Mar 17, 2010 | Toshiba Satellite A205-S4607 Notebook PC
Installed act of war direct action and is tells me
*install patch V1.06
*close all other programs running on the backround
*run the game with with administrator account or with administrator rights
*run the game exe with Windows XP compatibility mode (if you are running Vista/Win7)
*There are a lot of reports that this game will not like more than 3GB of RAM, so limit RAM size to 2GB by editing Win XP (boot.ini) or Vista/Win7 (bcdedit) or by removing some memory sticks
Mar 02, 2009 | Atari Act of War: Direct Action for...
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Asrock N68S Ucc Socket AM2+ GeForce 7025 DDR2 RAID AVL mATX Motherboard Logo
54 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
