Question about Maytag Neptune MAH5500B Front Load Washer
Washer does not drain
Took off drain hose
    Top Expert:
  • Maytag Master
  • 34,836 Answers
The pump may be clogged. Disconnecting the drain hose will not solve the problem, you have to check inside the pump
Posted on Oct 29, 2012
Took apart the washer and dryer and need to put it back together...i have everything except where the clear plastic hose goes
Kristen-follow the hoses-water comes into machine at the water supply valves-hot and cold which go into the tub-then there is a drain pump which is connected to the tub via a hose-the out put of the drain pump is connected to the drain through the back of the machine usually at the bottom and this goes into your houses' drain-follow the hoses and you shall reach laundry success-cheers Denny
Oct 25, 2013 | Frigidaire FEX831CS Top Load Stacked...
My lg washer and dryer wm3431hs isn't draining. I took of the hoses in the back, cleaned the filters and still nothing please help!
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...
Daniel
Jan 10, 2011 | LG WM3431H Washer and Dryer
Whirlpool front load washer wont go into rinse cycle screen flashes F 21
The F21 error on this line of washers is the machines way of saying the water took to long to drain from the tub. This could be a problem with one of the washer parts including the drain pump itself, how the drain hose enters the stand pipe, or maybe even something is stuck somewhere in the drain system and is preventing the water from flowing properly. Not quite an emergency, but it is an indication of a problem and a problem that can lead to something bigger if not looked into.The F21 error on this line of washers is the machines way of saying the water took to long to drain from the tub. This could be a problem with one of the washer parts including the drain pump itself, how the drain hose enters the stand pipe, or maybe even something is stuck somewhere in the drain system and is preventing the water from flowing properly. Not quite an emergency, but it is an indication of a problem and a problem that can lead to something bigger if not looked into.
hope this helps...
Oct 27, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Hoover nextra washing machin3e , not draining
Yes Disconnect drain hose from the rear of washer. You will need to use special pliers that have notches in them to grab the hose clamp or you might need a Screw Driver if the hose clamp is a regular hose clamp. Remove clamp and flush washer hose with a high pressure hose or garden hose. Inspect drain where you took the hose off for any blockage. You might have to do this two or three times.Yet most of the time one time is good enougg. Good Luck!
Aug 28, 2009 | Washing Machines
Water will not drain on neptune MAH3000AWW washer tried different cycles. It started working for a while after we took back off and took things apart but now it won't drain at all.
There are many things could make a dishwasher not drain, here's a list of the most common reasons.
  • a clog or air gap in the drain line, often the problem is where the drain line attaches to the household drain line, if you remove this line you can clear any debris from the hose or hose connection.
  • a defective pump, your dishwasher pump ejects the water.
  • many dishwashers use a drain valve or solenoid, the solenoid can sometimes become stuck or defective solenoid.
  • a defective motor, if the motor is'nt turinig or working the dishwasher won't drain.
Mar 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Jul 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Washer wont drain
Bring the hose down lower than the water level and it will syphon out................Possibly a clogged water pump :remove the pump hoses and clean out the pump.
Nov 08, 2007 | Tecnik TKL9260 Front Load Washer
Kenmore top loading washer not draining correctly
I had a similar problem---repairman took off the drain hose and found a curtain tie back stuck in the hose.(washed it two days before, wondered where it went) We were told that small items often float over the top of the tub and clog up the drain hose--he suggested using a small bag to wash socks, hankies ect. This problem cost us $75 to fix, but we could have done it ourselves. Good Luck Jen
Jun 12, 2007 | Kenmore 22422 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
