Landis & gyr Central Heating Programmer/rwb-xp
Circa 1990s
5 Suggested Answers
XboxModifier
  • 123 Answers
SOURCE: central heating programmer
is the buttons still working, eg, boost, on/off etc? or is the heating not working?
If so the LCD/Control panel may have lost power, this usually a switch/or fuse that may have been accidently powered of or blown
Posted on Feb 20, 2008
  • 251 Answers
SOURCE: We need a wiring diagram for Central heating
http://www.honeywelluk.com/product.aspx?r=pp&p=2470
hope this helps
if it does please vote , if that site dosent allow you in you might have to register with them , or alternatively post your email address and i'll send you the installation guide
Posted on Nov 14, 2009
SOURCE: I need the user manual/instructions for a
I got in touch with Honeywell by email and they sent me the manual on pdf.
Posted on Jan 12, 2010
SOURCE: ideal classic boiler no heating only hot water
Hi I have some boiler problems, I`m the proud owner of an Ideal classic SE12ff. The controls are that of Sunvic select Xl.
The problem is I can only get the hot water to work when the heating is on, I neglected this over the winter but now the summer is apparently fast approaching I am desperatley trying to get this solved. A plumber has done some fault finding with no prevail, have you any suggestions?
Posted on Apr 23, 2010
Landis gyr meter manual
computer software ?
PDF]User Manual - Landis+Gyrwww.landisgyr.eu/product/map/?download=78003
Apr 29, 2017 | Cars & Trucks
I have a gas meter and pay as I go card but the machine will not accept my card , what do I do "?"
Call the card companie and see if you have funds on the card. Sometimes I think I do and then I didn't realize the fees ate it up. Or they could have shut off your card.
Jan 04, 2015 | Siemens Landis & Gyr 536 765
Central heating 7 day programmer has no power to it
That may be a 24V Tstat and there would be a little transformer in the boiler that powers the Tstat. Sometimes those burn out.
Oct 08, 2014 | Water Heaters
Hi, I have a baxi solo boiler WM60/4RS and a Landis & Gyr RWB252 timer but my Honeywell T6160 thermostat has nether been connected, can anybody shed light on the wiring connections please.
The color code for thermostat wiring is as follows.
The "R" terminal is power into the stat from the boiler control transformer. Normally 24 volts. The "Y" terminal is for cooling. Normally left blank for a boiler. The "W" terminal is for heat. This one used to start the heating cycle.The "G" terminal is for fan operation. Probably not used for a boiler. Check the boiler terminal board for these functions and write down the wire color on each one. Match the boiler colors to the right function on the stat. If you need more than this, let me know.
Jan 06, 2014 | Honeywell Programmable Thermostat Heater
Landis staefa rwb9
Check the c/heating pump
Jan 29, 2018 | Water Heaters
How do i reset a landis prepaid meter
You do realise that the itme you are asking about is not a computer motherboard, don't you? It is a heating system controller.
Apr 21, 2013 | Siemens Landis & Gyr 536 765
Ideal classic boiler no heating only hot water when heating is switched to on there is no sound from system but there is when water switched on. the rads upstairs were warming up but not downstairs now...
Hi it sounds like the pump is not working or diverter valve not working check to see if pump is working on ch mode as well as valve , pump could be stuck ,
Apr 12, 2010 | Heating & Cooling
I've a problem with my central heating, I've changed my central heating programmer to a drayton lp522. My heating is constantly on. The only way that I am able to turn it of is with the thermostat when I...
Hi you never mentioned which programmer the LP522 replaced, as the LP522 is a 5/2 day programmer.
you may of wired directly to the heating on terminal on the programmer?
It may of been that you had a basic programmer which was only designed for the system you have installed.If i know what existing programmer was used i may be able to help?
Kindly
Richie
Dec 03, 2008 | Water Heaters
Heating & Cooling Logo
613 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
