Question about Home
Shower water stops by itself
After 10 mintues the water stops and then after about an hour it returns on for 10 mintues again?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 27 Answers
By the model I am assuming this is a shower head?
You may have to try pulling the shower head off to see why it is turning off such as something clogging it up, ect.
Posted on Oct 28, 2012
Water stops flowing
It sounds like the plumbing system has some type of device to prevent someone from using the hot water from a common water heater too fast for the water heater to keep up the temperature.
Aug 31, 2014 | Home
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
I am having 2 issues. Most importantly, my front load washer/dryer is skipping drying time. I typically wash the clothes then put dryer sheets in and use the dry only on low heat option. It starts...
Your two issues may be related. A combo washer / dryer uses a fine spray of cool water to condense moisture out of the air stream while drying. This water is then pumped down the drain. Cold water is also used to fill the softner dispenser. If the inlet screen on the cold water connection to the machine is restricted, those are two of several things which could show up. Turn cold water valve supplying water to machine off. Unscrew cold water fill hose from machine. Remove screen from inside machine, clean, re-install, re-attach cold water fill hose, turn cold water valve back on and see if performace improved.
Mar 02, 2011 | LG WM3431 Front Load Washer / Dryer
After turning water on to 10 year old grohe shower faucet pressure rapidly drops to nearly nothing
If you spin the shower head off there should be a metal screen inside. If it is clear, Soak the shower head in CLR for about 4 hours. After 10 years even the best water supply will leave behind a build up that can plug the tiny holes.
Feb 24, 2011 | Grohe Grohmix Thermostat Valve & Trim -...
Out of nowhere, my 2004 nissan altima bucked.. then stalled after a 3 hour drive on the expressway. after letting my car sit for a about 10 minutes, i turned it back on, successful.. or so i thought, as i...
any check engine lights comeing on it sounds like a intermiting problem that will eventually give the car a tune up plug wires have the injectors cleaned
Nov 29, 2010 | 2005 Nissan Altima
The water comes out very slowly. No pressure.
Check for debris in shower head. Could be calcium or other mineral buildup. Has the water dept. done any recent repairs/upgrades to water meter or mains? Sometimes this can loosen buildup in pipes & send it through the valve itself thus lowering pressure or stopping completely.
Jul 29, 2010 | Moen & One Handle Tub & Shower Faucet
No running water from my shower
Check water lines to shower and make sure that there is no blockage or water cut off to it. Valve itself could be bad also or blockage inside it.
I f it is a tub & shower unit the diverter may be bad or stuck in place restricting water flow. Some are push button on the valve or a pull unit on tub spout to send water to shower head.
Cut water off and remove to inspect for reason not functioning correctly.
Remove shower head to inspect for blockage. The srceen may be stopped up for the shower head. Remove turn water on and see if any flow comes out shower arm.
May 19, 2010 | Home
The single handle fauchet will not stop running water.
Replace cartridge and insure that the C clip is not missing.
Sep 11, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Hours after I take a shower, the showerhead will start dribbing
No, the showerhead is probably OK. My guess is that the head is relatively level, and the design of the nozzle allows water to pool inside. When you take a hot shower and turn the shower off, it begins to cool. As the shower head cools, a slight vacuum is formed, pulling air up into the showerhead. As you reach equilibrium, water is allowed to discharge as a dribble. This continues until the water has all been displaced. The fix for this is to turn the showerhead to the side, allowing the water to drain more quickly, and allow the air in. Try it.
Best regards, --W/D--
Jul 21, 2009 | Moen Showhouse S112BN Waterhill 10...
Water heater not kicking on
Could be the water supply into the heater after the cold supply to the house has frozen up. Sounds like an ice block has moved down the pipe before the heater while the water to the shower was flowing and then got lodged in an elbow blocking the flow.
Jan 16, 2009 | Water Heaters
Home Logo
183 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
