Question about Briggs & Stratton Briggs Stratton 7 kW Auto Standby Generator
The motor starts and runs for approx 30 seconds and then shuts down
Replaced the motors head gasket and reinstalled the motor/generator. After reinstalling, and hooking up all the wires, the propane motor will start and then shut down after about 30 seconds. Oil level is correct. Tried disconnecting both the oil switch and pressure switch and it makes no difference. It is not throwing any codes.
5 Suggested Answers
farfield
  • 462 Answers
SOURCE: Generator won't run
DId you change the oil filter when you changed the oil I am assuming it has one.
If it has a filter some of them have a check valve in side and this valve may not be operating properly.Also you might try rolling it over a few times with the pressure sensor removed and see if oil spurts out the opening. If so then the problem may be the oil pump not building up oil pressure, or the motor may have a board looking for the oil pressure sensor to close (or open depending on how its engineered) and the sensor board is not working properly or not grounded good. Try cleaning the battery cables just in case (assuming it ahs a battery).
Posted on May 08, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Brand new B&S 5000 watts
There really is not much you can do without voiding your warranty. This may be something simple like a connector that vibrated loose inside the control panel. (Alternator to contol panel inter-connect) There could also be a wire lying loose that was not connected. Open the control panel... and look for anything obviously out of place. DO NOT do anything else. After that your stuck with the warranty process of Briggs and Stratton.
http://www.briggsandstratton.com/~/media/PDF/BriggsStratton/Engine_Warranty.ashx
or 1-800-233-3723
When your at a B & S service / repair point... (store front)
Things to note .
1. Tell servicer unit is for PRIVATE USE (There is no warranty for commercial use)
2. Have proof of purchase in hand otherwise they will use the MFG date as the start point of the warranty. Many generators sit in a warehouse or on the shelf long past an implied warranty (date of mfg) Bottom line you need to have your sales slip.
There are several things I could have you do but... as the consumer the only thing you can do is perform an inspection. By opening the control panel you need to tell the servicer the only thing you did was a VISUAL Inspection...... Anything else will void your warranty.
So.. look for any obviously loose parts or or connectors. After that sadly your stuck with dealing with warranty service.
Thanks for choosing FixYa,
Kelly
Posted on Sep 04, 2011
bwolfman2001
SOURCE: I have a Briggs & Stratton 7kW Dual-Mode Backup Generator. It recently started kicking the 30 amp breaker and then the engine shuts off. Sometimes it runs for 2 hours, then shuts off. You can s
check for a broken wire some where
Posted on Jul 09, 2012
  • 6468 Answers
SOURCE: I have a Briggs and Stratton 7KW standby generator. I accidentally spilled some oil on it during a hurricane and cleaned it. However, when I try to start it, it will go on for about 15 seconds and t
sounds more like a fuel problem not oil being spilled on it but check the oil level some have a low oil shut off see if you can keep it running spraying carb cleaner in the air filter that will tell you if it is a fuel problem more so a fuel problem if you left fuel in it for more than 30 days
Posted on Aug 18, 2012
KOHLER SMOKES STARTS UP ONLY HOT OR COLD,NO SMOKE WHEN RUNING
look down inside air cleaner before starting next time , if theres more than a finger full of motor oil in there then your head gaskets are going
May 20, 2014 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Pool Pump Runs Intermittently (~10 seconds on, ~1 minute off)
Need more info. What is the voltage at the pump? What voltage is the pump wired for? Sounds like your pump is shutting down from heat thru a safety. If the voltage is wrong the pump will heat up very quickly and a thermal switch will cut out, it will then cool off and try again. Get the readings at the motor connections NOT the breaker.
Apr 02, 2017 | AO Smith A O Smith Motors Century 1hp 115v...
Basement flooded and got approx 12 inches of water in bottom of dryer let sit for a week to dry before trying when pushing start button will come on but wont continue running unless you hold button in ...
Sorry to say but you will need to replace the motor. After water gets in you can rarely save the motor no matter how long you let it dry.There is an internal over load inside the motor that is cutting out after 30 seconds and once it cools for 15 or 20 minutes then it resets .Hope you found this information helpful and thank you for using Fix ya.
Jun 24, 2011 | Whirlpool Dryers
It runs for a couple of minutes shuts off then restarts 30 seconds later runs a couple of minutes and does this over and over
Most vacuum motors are protected from overheating by a thermal switch that resets after cooling down. Check for blockage in the hose,
power head or a full bag that would block cooling air from cooling the motor.
Tom
Oct 22, 2009 | Tristar Vacuums
Craftsman 6hp 150psi 30gal won't keep running
It sounds like the internal circuit breaker in the motor is heating up and then the breaker trips to shut down the motor. This is the protection so you don't have a fire if the motor burns up. The smell you have is the coils in the motor. Sorry to say that you will need a new motor for this unit. I hope this helps out.
Jan 17, 2009 | Air Tools & Compressors
Briggs & Stratton Briggs  Stratton 7 kW Auto Standby Generator Logo
46 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
