How to reformat a laptop using the F9 function?
I don't know how to do it since it's my first time doing this to a computer and it comes up with 4 steps: 1. Reboot to Windows XP 2. Recover Windows XP to first partition only. 3. Recover Windows XP to entire HD. 4. Recover Windows XP to entire HD with 2 partition Which one is the right one to do?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 27 Answers
So my questions would be are you attempting to restore your PC to factory settings? or put a new Operating System on it?
If you are trying to restore to the way you got it, you probably have a recovery partition on your hard drive. If this is the case you are going to want to restore to your recovery hard drive.
If you are trying to put a new operating system on your PC then you will probably want to recover to the non recovery hard drive.
The other option to use the entire hard drive will give you more space on your PC to use, but will wipe out your recovery partition. Hope this helps.
If this isn't making sense try taking a picture of your partitions and posting up here so we can give you better advice.
Posted on Oct 28, 2012
SOURCE: Computer restore
To avoid problems again like this activate it first, if your not familiar to some techniques it very hard for you to understand what I am gonna tell. The most short term for this is to back up all your files[slave your hard disk to another computer if desktop, if not try to make some ways] and then reformat your computer./ Thats it!
^_^
Posted on Feb 07, 2008
SOURCE: reboot with new hd
Try Checking if your motherboards bios will recognize the hard drive. If not, Then the hard drive is probably damaged.
To access The bios, Most Motherboards open the bios when you press the delete key
If you have two or more hard drives then the settings of the jumpers eg. Slave,Master,Cable Select.
Because they might be conflicting with each other.
I had the same problem, But I tried installing XP Home edition on my secondary hard drive and it works.
But i need to insert my xp home install disc to get it the bios to recognize that windows is installed otherwise it goes " insert system disk and press enter"
Posted on Oct 11, 2008
colliewob
  • 778 Answers
SOURCE: BOOT.INI default=signature (78c2dcdc)disk(0)rdisk(0)partition
I think the hard drive has no operating system on it or the MBR :Master Boot Record" is corrupt.
Try downloading "Hirens Boot CD" and burn to cd and boot from it.
It has a lot of useful Utilities on it for restoring MBR and formatting and partitioning
Posted on Jan 29, 2009
ubelong2matt
  • 67 Answers
SOURCE: Bios Beeps during reboot
According to the information at:
http://www.pchell.com/hardware/beepcodes.shtml
AMI beep codes of 1 long and 3 short are, in fact, correctly identified as memory errors. One thing to note is if this memory is Dual Channel, you can only install the memory in groups of two. You must first fill DIMM slot 1 and 3 before filling DIMM slots 2 and 4.
The below website has much more information about your particular motherboard and there's a note about some JEDEC setting for memory that you might want to watch out for or disable to see if it improves stability.
http://www.msicomputer.com/product/p_spec.asp?model=K9A2_CF-F_V2&class=mb
As for Windows XP 32-bit not recognizing more than 3.5 (at most) memory, this is unavoidable. To see all 8 GB, you would need a 64-bit version of Windows. This is something that cannot be altered by BIOS or memory choices, unfortunately. Feel lucky in the fact that you have XP Pro as XP Home will only recognize up to 2.5GB. You'll never utilize all 8GB unless you upgrade your OS, so keep that in mind!
Posted on Mar 04, 2009
xptareq2000
  • 1447 Answers
SOURCE: Unable to shutdown the computer
it is the problem your computer operating system or motherboard bios setup problem . You restart your pc after restart then press dell key then prevew your bios setup option then choice bios defalt setup then press F10 press Y restart your pc .
Posted on Jul 21, 2009
Don't know HDD #1/SSD #1USER PASSWORD ON MY TOSHIBA
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Oct 03, 2012 | Toshiba Satellite L455S5980 Notebook
How do I wipe my hard drive clean and restore it to the way it was when I purchased it
If you have the original disc drive installed (and the original OS), try pressing F9 repeatedly after turning on the computer. (Sometimes, it can be hard to get the timing right - the button press needs to be seen after the POST and before Windows loads. If you see Windows starting to load, let it finish loading and then shut down the computer and try again.)
This will access the recovery partition and reformat the computer and restore the machine to the factory state. Follow the on-screen directions and make sure that you have saved your personal data elsewhere.
However, if your computer has the ASUS boot booster, you will need to disable this feature to access the recovery program. Try pressing F2 or Delete (depending on your machine) to enter the BIOS with the same timing as the above use of F9. Then find the option to Disable the boot booster. Then press the F9 key on another start up cycle. My ASUS computer doesn't have this feature so I'm not sure where it may be in the BIOS (if on your computer).
Asus offers a WinPE wipe and recovery option for some of their computers that can be put on a USB flash drive. http://vip.asus.com/forum/view.aspx?id=20091019013723218&board_id=20&model=Eee+PC+1005HA&page=1&SLanguage=en-us has the procedure for one of their other models.
I hope this helps.
Aug 29, 2012 | ASUS K501 Laptop 2.2GHz Intel Pentium...
I have an Acer Laptop with Windows Xp.... when i start my computer says |Be_$|Be_$| and i can't use it, what that mean?
LOL, I don't know what that mean!!! Maybe you should just get an operating system disk and reinstall it. You can do a Repair Install so that you don't lose any of your data.
Apr 19, 2012 | Acer Computers & Internet
UNABLE TO REFORMAT DISK
Do you have access to another computer to try reformatting the disk on? Or has your computer been 'acting up' lately? If so, the BSOD is probably just that & it's time to start looking for a new computer. I had this happen to me recently and took my computer in to a reputable repair store in my area that I had used before and they did manage to retrieve MOST of my stored pictures and media. But, I'm sorry to tell you, the computer never worked again. Good Luck!!!
Jan 29, 2012 | Computers & Internet
I WANT TO REBOOT MY NETBOOK
Reboot the computer and as soon as it turns on start tapping F9 repeatedly. Do this immediatly after hitting the power button. If Windows Starts to load - you will need to reboot and retry.
Hitting F9 should take you to the recovery partition option. If you select to run it - it will erase everything on your laptop and set it back to factory defaults.
If you have more questions, consult the manual that you can download here: http://support.asus.com/download.aspx?SLanguage=en&p=20&s=1&m=Eee%20PC%20R101&os=17&hashedid=GhBUCjHj4BRr7ndV
Hope that helps!
Nov 21, 2011 | Computers & Internet
I just uploading the data from my laptop to my micro sd card, it's been loaded but after if we unpluged it from laptop & load it in phone then only one Folder sowing the data & rest are...
Try to reformat your micro sd card using your phone, then plug it into your pc to copy files. Don't forget to properly eject your sd card not just unplugging it. If this doesn't work try reformatting it using your pc then properly eject it.
Jul 02, 2011 | Computers & Internet
I lost my recovery partation and I don't have a recovery cd for an asus seashell eee 1001p, how can I do?
Hi you will need skillful guy to restore your PC Operating system if you had reformatted your hard drive. To restore your O/S without having your recovery CD is to ask from your vendor a copy of it and re-install again. You can do it by having an external DVD driver, change the boot sequence in start up and presto you can reload again your O/S and other applications. Don't forget btw to load the driver in order your PC to work properly.
Jun 21, 2011 | ASUS Eee PC 1001P Netbook
Got a laptop for 55th birthday. No instruction booklet. Help! It's a HP G72. Having trouble with touchpad and don't know how to use any of the other things on computer like notebook, digital...
www.compaq.com and look up the users manual should help you out. don't be afraid to push things you aren't gonna break it the more you play with the pc the better you will become. i also suggest getting a book on how to use laptops maybe that will help too
May 06, 2011 | Compaq Pavilion ZT3280US Notebook
I need to know how to unintall all the data on my WD hard drive and start over again fresh. Can you help me?
Mac OS X
1 Connect the Western Digital My Passport hard drive to the computer. Power on both.??
2 Open "Disk Utility," located in the Utilities sub-folder of the Applications folder.??
3 Select the drive you wish to reformat. Typically, drives appear twice; choose the furthest left.??
4 Click "Erase," and pull down the Format menu. Choose "FAT32." Enter a hard drive name, if desired.??
5 Click "Erase." A confirmation screen will appear, stating that all information on the drive will be lost if erased. Click "Erase." Once completed, the erased drive will function on both Windows and Macintosh systems.??
Windows
1 Download and install the Western Digital FAT32 Formatting Utility.??
2 Connect the Western Digital My Passport hard drive to the computer. Power on both.??
3 Open the FAT32 Formatting Utility and select the desired external hard drive. Ensure that "Restore factory original FAT32 partition" is selected.??
4 Click "Start." A warning message will appear, stating that all data on the drive will be destroyed. Click "OK" to continue. Click "Yes"' to navigate through.?
May 03, 2011 | Computers & Internet
Konica Minolta Dimage Z2 camera will not read any SD card
hi there
you don't say how big the card is, my guess is its bigger than 2 gig which is the maximum allowable size for that camera.
hope this helps
beergut707
Oct 20, 2008 | Konica Minolta DiMAGE Z2 Digital Camera
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
