Question about Microsoft Office Computers & Internet
Blue screen problem in video (blue screen)
  • Microsoft Master
  • 3,606 Answers
Hello blue screen of death means you have a bad driver
somewhere on the system.
Try to boot up in failsafe mode by pressing F8 under restart
Select to boot with network support.
enter the device manager under graphic and see how old
the driver is.
You can try to renew the driver.
What does the bsod tells you ??
there is typical a failure code.
Try also the manufactures home page in seach for drivers.
If it is a ATI you can download a new driver here:
http://support.amd.com/us/gpudownload/windows/Pages/auto_detect.aspx
And NVIDIA:
http://www.nvidia.com/Download/index.aspx?lang=en-us
Good luck
Posted on Oct 29, 2012
Disable the blue "No signal" screen from showing up?
There is no Blue screen disable option on the camera.
Since the blue screen caused by the video heads, try to clean it up by running a cleaning cassette.
The cleaning cassette helps only for minor clogs of the Drum(video heads)
Jan 18, 2015 | Sony Handycam CCD-TRV608 Camcorder
My sanyo 42 inch plasma has a blue screen, i can hear the sound on the tv but screen remains blue. can u help please
Be sure your channel settings are correct and that you have proper orientation of the hook up cables. See if your remote has a video-mute if so turn it off...a video-mute will produce a blue or black screen. To be sure its not the tuner that's enter the menu screen if you can see the menu then the tuner is ok this means the down-stream video is functioning. Be sure to have all your input devices set to the correct output ports. If all check good and still blue screen then the logic section is not processing video codecs and needs servicing.
Oct 18, 2010 | Sanyo 42 in. LCD TV
TV is turned on-only see blue screen that says Video
if only see blue screen indicate no video signal, check the yellow cable.
Apr 13, 2010 | Sanyo DS13204 TV
KP57WV700 - Blue Lines Across The Screen
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Sony KP-57WV700 57" Rear Projection HDTV
The screen is blue. channels come up but no
Are your sure you're on the right channel (3/4) did you try the video inputs? ie. use video out from Satelite to video in on tv and select the video input on the tv
Sep 30, 2009 | Apex Digital AT2002S 20" TV
Blue screen when using VCR function
Hi and welcome to FixYa,
A blue screen is 'video muting', the player is not getting a decent video signal and rather than display distorted / noisy video, it is muted.  Initially, has a video head cleaner been tried on the camcorder?
Good luck and thank you for asking FixYa.
Aug 02, 2009 | Sony Handycam DCR-TRV80 Mini DV Digital...
Tv Model no HTF27R11 SCREEN LUCKED
your problem is in blue video output circuit.
as you are seeing lines with blue  color
those lines are called retrace lines.
please check
  • supply to blue video output ckt.&blue video output transistor.
  • loose crt base or crt base connector.
  • componenrs related to blue video output section
  • blue signal coming to red video output ckt from signal processor.
  • at last but rare cases crt weak.
  • hopr this will help
good luck
Oct 16, 2007 | Haier HTF27R11 27" TV
Blue screen
this problem is due to blue video circuit. 1 Please check supply to blue video ckt. 2 check crt base for loose. 3 check loose contact & parts related to blue cathode. 4 blue signal coming from processor to blue video. 5 processor it self. 6 at last if tv is very old than check crt also.(possibility is rear) hope this will help.
Oct 03, 2007 | Sharp 32C-240 32" TV
Retuning having moved to a new area
blue screen is due to problem in blue video circuit. please check 1 supply to blue video ckt. 2 crt base loose. 3 components in blue video ckt. 4 loose contact in blue cathode ckt in crt base. 5 blue video transistor. 6 signal coming to blue video from signal processor. 7 signal processor ic. good luck.
Sep 29, 2007 | Thomson 14MG135 14" TV
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Computers & Internet Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
