Question about LG DLE2514 Electric Dryer
CHECK FILTER LIGHT IS ON UNTIL I START DRYER THAN GOES OFF
    Top Expert:
  • LG Master
  • 9,472 Answers
The CHECK FILTER light will appear between every cycle, simply as a reminder to clear the lint filter before starting a new load. If the unit runs properly, then this is no cause for concern. If it will not start, then the unit may require service.
Posted on Oct 29, 2012
LG Dryer - Check Filter Blinking Light is on and the filter is clean but my dryer won't come on?
The check filter light is just a reminder. Goes off once dryer starts. Dryer not working has nothing to do with that reminder. Check to see if belt is broken. When it breaks, it stops motor from working. Just take top off and tug on belt.
Dec 01, 2016 | LG Dryers
Gas lg steam dryer DLGX7188RM cleaned filter , vent tubing, unplugged, still check filter light flashing , hit power goes straight to cool down .
the check filter light is just a reminder. it is not connected to a sensor. goes out when you start the next cycle so your issue is not connected to that.
May 30, 2016 | LG Dryers
The clean filter light was flashing but it stopped after I cleaned the vent but still won't heat, Is there another vent/filter in this dryer?
the blinking filter light is just a reminder, not connected to anything. goes out when you start cycle. however, if the dryer overheated then it may have blown the thermistor fuse. check out appliancepartspros.com or repairclinic.com for how to videos and parts.
May 23, 2016 | LG DLG5988 Gas Dryer
CHECK FILTER LIGHT COMES ON UNTIL I START DRYER
Oct 28, 2012 | LG DLE5977 Electric Dryer
Filter light is on. I pull filter - its clean. I put filter back in - filter light goes out. I start dryer. It runs for about 5 seconds and stops
Did anyone come up with a solution to the problem, we are having the same problem, except our dryer keeps running, the filter light goes out, and when the dryer is turn back on the filter light is back on, the filter is clean.
Oct 22, 2010 | Kenmore Elite HE4 Electric Dryer
Unit powers up, check filter light flashes until you turn main control knob to any setting (e.g 'normal'). Press start, unit runs, but no heat. Checked output of vent outside, plenty of cool air is flowing...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 14, 2010 | LG DLG5988 Gas Dryer
Check filter light remains power light blinking
Hi friend,,,
welcome to fixya
try to unplug it for 30 minutes this should reset the control board. and clear any errors it has. and may start working again. let me know how it goes OR
try this to get it in diagnostic test mode have the dryer in standby mode then press and hold more time and less time and then press the power button to get out of this mode you will have to unplug the unit for at least 1 minute
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Dryers
Drum not rotating
If you clean your lint filter after each load faithfully, try removing the dryer vent hose that goes to the outside and inspect it for lint accumulation, water build up, or some other foreign material, as this will restrict air flow and cause your described symptoms. If your are unable to inspect your vent, disconnect it from the back of the dryer and start your dryer to see if it works that way.
May 29, 2008 | LG DLE2532W Electric Dryer
LG DLE2514 Electric Dryer Logo
62 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
