Sherwood AX-4050R Amp - Inputs
None of the inputs work except for EXT in, but that buzzes loudly and has blown the tweeters on my speakers!!!! sounds like an un-grounded turntable x5 . anyone help?????
Gurudristi
  • 98 Answers
SOURCE: Onkyo TX-SR706; Turntable output only from one speaker
Try some troubleshooting to check whether its the turntable or the the receiver.
What happens if you exchange the output cables of the turntable from left to right. Does the problem shift?
Does the sound changes from left to right speaker?
Similarly try on the inputs of the Receiver.. does the problem shift...?
This way you will be able to isolate the problem, whether with the receiver or the turntable....
Let me know, we can trouble shoot it further....
Posted on Mar 08, 2009
  • 4234 Answers
SOURCE: technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Posted on Apr 12, 2009
  • 4234 Answers
SOURCE: Sherwood AX-4050R Amp - faulty RCA inputs
It is rare for the actual input connectors to fail. More likely, either the solder connections need to be re-flowed, or the switching IC is defective. If you can solder, try resoldering the pins of the RCA connectors. Look closely at them and see if the PC board trace is broken. If the resoldering fails to resolve the problem, look for a switching IC with about 28 pins. It may be marked TC9163 or something similar. That will be the audio switching IC. I would change that next.
Dan
Posted on Nov 30, 2009
dunnbiker
  • 8546 Answers
SOURCE: Sherwood RV-4050R compatible with new gear?
The TV is irrelevant.
BD would need HDMI, digital audio or 5.1 analog inputs on the contol receiver. You have none of these.
Posted on Jun 21, 2010
petraman7
  • 1175 Answers
SOURCE: Suddenly after 8 years there is no sound coming
Actually, Denon used a thermal fuse in the primary of the power transformer. Have a tech check the primary winding and see if it's open. if so , have it bypassed
Posted on Aug 19, 2010
Sherwood AX-4103 amp keeps clicking
Hello there.... Check your speaker wires and then if that doesn't do it? try replacing the fuses on the back of the amp.. make sure power is turned off and unplugged. If that doesn't work? Try one speaker at a time ... something is causing the system to short out. Hopefully it is not internally
Apr 21, 2014 | Sherwood Audio Players & Recorders
Sherwood ax 4050r
'Direct' disconnects the EQ normally. Don't trash your amp because of a noisy EQ when you can bypass it.
Mar 05, 2014 | Audio Players & Recorders
I have a Boston Acoustics VR-500 Subwoofer with a problem. As soon as anything is plugged into the line level RCA jacks, the subwoofer produces a loud buzz/hum. I have tried connecting it to the subwoofer...
I'm thinking you have an open shield ground on the RCA input side. Connecting speaker inputs possibly restores the ground. Try connecting the high level inputs then disconnect the remote end of the cables (floating the grounds).
Then get out an ohmmeter and find that open circuitor or bad solder joint between RCA ground and real ground in the speaker's amplifier. Or.... if speaker ground kills the hum and you want to use RCA Line Level input to the sub, just connect one minus speaker output on your source amp to one minus on the sub's amp.
Mar 01, 2011 | Audio Players & Recorders
Jun 19, 2010 | Sherwood RV-4050R
Dan
Nov 25, 2009 | Sherwood Audio Players & Recorders
Will not produce sound through the top end of my speakers,
While this may sound strange, it is not likely the receiver that is the probem, at least at this point. Remove the "tweeters" from the speakers and measure across the two leads. You should read continuity. If not, then the tweeters need to be replaced. I believe that you may have blown the tweeters.
Dan
Feb 06, 2009 | Sherwood RV-7050R Receiver
Audio fuzzy or cuts out
Could have a loose connection in the audio section or a problem with the output IC . Also does this happen on the RF input and your A/V inputs or just one of these. If its the A/V inputs only your having this problem check your cables .
Nov 26, 2007 | RCA HD61LPW165 61" Projection HDTV
Amp powers on, but no sound is produced
a failed volume control potentiometer? it's possible.
Jun 04, 2007 | Sherwood RD-6108 Receiver
69 people viewed this question
 Grubhead
Grubhead
