Question about Toshiba 23DL934G LED/DVD combi SurgeStrip E-Series - surge suppressor F
High Pitched Noise from LED TV whilst in standby
I've just bought a brand new Toshiba flat screen LED TV/DVD combi. As soon as I plugged it into the power source, a high pitched noise started. After about 10 seconds the noise lowered in pitch, but this lower pitched noise continued in standby until the power is switched off. In my opinion the tv is faulty and I plan to return it. Can you offer me an insight into what the fault could be here? Thanks a lot.
snakehead
  • 1074 Answers
SOURCE: High Pitched Noise
most high pitch noise comes from the anode conection on the picture tube thats connected to the flyback anode cap thats mean there is a high voltage leak,to stop the noise you can discharge the high voltage take off the cap and clean with alcohol.if the noise continue.you will have to put some red or clear silicone both the cap and tube stick together leave to dry for about 2 to 4 hrs.this will eliminate the leaking.good luck.
Posted on Jun 17, 2007
Benimur
  • 6966 Answers
SOURCE: Power light comes on, followed by a high pitched whine
Hi, If after trying the TV again later and problem persist, repairs are in order. A high pitched whine is an indication of a fault at the horizontal section of your TV. The horizontal provides the high voltage for the picture tube. Your best bet maybe to seek the services of a qualified professional TV repairman since this involves component level repair, soldering/desoldering, use of soldering iron and VOM (testers) and knowledge of circuitry. Good luck and kind regards.
Posted on Aug 20, 2007
jerryg50
  • 1667 Answers
SOURCE: high-pitched whine
The wining sound is most likely from one of the inductive reactive devices. These can be chokes or tansformers in the scan circuits or the power supply.
There are very high frequencies used in the ultra-sonic range for the switching power supply, and the transition times for the scan amplifiers and high voltage section are in the ultrasonic range. What you are hearing is something that is resonating with the magnetic fields generated by these high frequency devices, and they are making sub harmonic sounds in the audible range.
It is possible that in one of the reactive devices there are some wire turns that are a little loose, or the coil form is not very tight to the core of the device, or one of the near by metal shields is resonating from the magntic field.
There is also the possiblity that the supply voltage to one of the reactive devices is not being properly filtered by a by-pass capacitor and its structure is resonating between the normal power drive and summing with the unfiltered supply to it.
When the set is first turned on it is cold. As it operates its internal temperature will rise. There is expansion and contraction of the various parts. The reactive devices are made with very close tollerance, and their physical characteristics can change enough to allow resonance. If the fault is from a by-pass capacitor, the capacitor may have become thermo sensitive and change its characteristics with temperature.
In the case of a resonating reactive device, sometimes it is possible to fix the problem by re-inforcing the winding to the core if it is accessable. It is not always accessable to do this depending on its design. Then the solution is to change the part. If it is a shield that is resonating, this is usually easier to correct. As for any defective capacitors, these can be easily changed.
It would be best to have a very experienced TV service man look at the situation and spend the time to make a proper evaluation of what the fault actualy is.
I have had this type of problem often. I was always able to find the solution and fix it. Most of the cost of the service was from the time it took to work out the solution more so than the cost of the part, unless it was a major part such as the flyback or the deflection yoke.
Flat panel displays have switching power supplies and are subjected to similiar types of resonation faults with their power supplies.
Jerry G.
Posted on Apr 19, 2008
SOURCE: Toshiba Regza bought 1/28/08 makes squealing noise
It's in the repair shop. I'll write back what the problem was and how much it cost to ship.
Posted on Oct 08, 2009
SOURCE: Toshiba 40RV525U goes into green screen mode when
Try updating the firmware to version 1.05 from this website http://support.toshiba.ca/support/ceg/downloads/all/view.asp?docid=D000020
Posted on Mar 26, 2010
Testimonial: "daubuchon..thanks for the info! That might have done the trick. The problem is much less prevalent now. Excellent!!"
Funai tv. When plugged in, makes ear piercing high pitched buzz that goes away when unplugged. Will not respond to buttons. No picture or power. Already replaced power board. What now??
TV not turning on; making high-pitched sounds - Tom's ...
www.tomshardware.com > Forum > Graphics Cards
Tom's Hardware Guide
Nov 30, 2013 - 7 posts - ‎2 authors
Both of them are refusing to turn on, and make high-pitched sounds when plugged in and unplugged. More about : turning making high pitched ...Missing: ear ‎piercing
Top 136 Complaints and Reviews about Funai TV ' Page 2
www.consumeraffairs.com > Electronics > Televisions
Rating: 1.1 - ‎65 votes
We unplugged the unit and waited 15 - 20 seconds and plugged the unit back in, and it wouldn't ... He heard a loud high-pitched whining which led him to TV in my daughter's room. ... It only makes a humming sound now, no pictures at all.Missing: ear ‎piercing
HELP! what is that high pitched noise when tv is on? - TV - Audio ...
www.tomsguide.com/forum/60895-6-help-high-pitched-noise
Jan 25, 2013 - 3 posts - ‎2 authors
Hello, I hear this constant high pitched noise, almost like ringing, but even ... pitch
Jan 21, 2016 | Funai Televison & Video
Mytcl tv 14175 no power led standby only
Check the power supply board. Also is there a very high pitched noise when it is plugged in. These indicate bad capacitors on the power supply board. The PS is more than likely your problem.
Dec 14, 2015 | Televison & Video
Recently bought a toshiba tv and dvd combi but wont play any dvds
You need to go in the menu and change the region code. yours is not set for amarican made dvd's
Mar 05, 2013 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Darker picture and high pitched sound from back of tv. Also flickers.
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Jul 31, 2012 | Televison & Video
High pitched noise coming from my tv
is the TV a CRT, plasma,LED or LCDCRT is a very old type which consists of a vacuum tube that has an electron gun that shoots energy at the front of the screen where pixels divide the light into 3 colours RED BLUE GREENLCD, LED and plasma are the most modern of which run in high definition. CRTs are very bulky, while the other 3 types are slim and light, if it is a CRT, drop the colours to a lower setting and it should silence it, I had to do this countless times with my computer's monitor as it is a CRT.
Nov 30, 2011 | Toshiba 65HM167 65" Projection Television
Oct 07, 2009 | Toshiba REGZA 47HL167 TV
Sometimes screams a high pitched noise when turned on
the high pitch noise is from the HV. arcing acrss each other.
( the screen comes up at a pop).
I suggest get a better one. ( sorry! no domastic brand).
Oct 27, 2008 | RCA HD52W56 52" Rear Projection HDTV
Toshiba 23DL934G LED/DVD combi SurgeStrip E-Series - surge suppressor F Logo
37 people viewed this question
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Electro Med Services...
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
