S3eemingly 'stalled" as if Paper Jamed ( It is cean & not obstru
In use since 13/08/2004 --Was then using Port >usb 001( Now LPT1 ) Enviorement>>>Windows NT x86 Data Format>RAW Operating System>Windows XP Home +S P 3
On 25 12 2008 I noticed PC UNSTABLE !--Decided to Acquire >Driver Robot ( Blitware.com )-to Update Drivers !---THAT'S IS WHEN BOTH PRINTER & CD/DVD RW Burner Failed to Function!----Spent Christmas until Now>12:50 AM >Sunday 04 01 2001 Reading, Uninstalling , Re Installing Etc & Finally Decided To Uninstal DRIVER ROBOT HQ ( Blitware.com )-& request refund !--Meanwhile, had DRIVER DETECTIVE Since May 2008 & noticed it was Upgrading Drivers for 2009 Already!--So had them Scan , Check for Out dated Drivers & ALL in order!---(TUNA SANDWICH + COFFEE for Christmas Dinner !!!---Pressed On, found I should Uninstall Printer & Port & Search For upgrade on LPT1 & IT WAS INSTALLED & SEEMINLY A DOCUMENT ON "Command Prompt" would surely print !-NOT SO !----Removed Printer to Examine from rear panel IF there was obstruction, No Obstrustion!--Manually revolved "Wheels , rubber coated to draw in paper !--Assembled, Re Connected , placed paper correctly in Tray , & "Sent Notepad Document to it for printing !---Made ALL the usual sounds & seemed as if it was about to draw paper in & begin Printing !--NOT SO.,--"STALLED" WITH ORANGE LIGHT FLASHING, located below GREEN ON BUTTON!--Repeated that function , Swithed off AFTER "DELETING DOCUMENTS TO PRINT By having HP Deskjet 845 c OPEN to allow deleting !!----Have original INSTALLATION DISK BUT AS CD/ DVD RW BURNER UNIT FITTED ABOUT MAY 2008 & NOT USED UNTIL CHANCE AT CHRISTMAS TIME Found Inoperative ( With it Downloaded Windows Media Player Version 9 & found it wont play any dvd or cd --Did trouble shoot, told there were items required , so began Download BUT as My I S P Optusnet Cut Me Off With Just 6 Minutes To Complete The Download , It Failed !---Have Since Made Many Incredimail Screebshots Of My "Journey Throughot The Intricasies Of Internal Workings Of Hard Drive - C P U & Hardware , Using Device Manager & Windows, to Help BUT, in conclusion at this Unreasonable Hour 1:00AM I Suspect that SAMSUNG CD/DVD RW BURNER Unit May Require Assistance First to Get It Going, Because In Your Reply To Me Should You Request That I Insert Printer Disc & Follow The Wizard , Then That Would Fail Too!!----Had Deleted, Uninstalled PRINTER & Windows , When Given The Task Of Searching Throughout The MAIZE , Located & Installed DESKJET 845 c PRINTER !!--Kind Of Two Steps Forward & 3 Backwards, If You Get My Drift?----Hope You Can Wade Through This ,I Dont Wish To CAST IT OUT , It Has Been So DEPENDABLE!!---Thanking You,
Kind Regards, Des.
PS/-If, You Send Me Normal E:mail In Reply Then If You Wish I Could ADD As ATTACHMENTS The Many Screen Shots I Had Taken Of The Many Procedures To Date 1
  • Desmond Ayres
    Desmond Ayres Jan 05, 2009
    05 01 2009 That was best ever advice!--To My surprise the Accumulated Black ink, over 5 Years on Paper Roller Drum Wheels was astonishing !!--It filled the Lint Free Cloth I had water moistened, & My hands also!--Quite amazingly, that was to stop the "Stalling At The START LINE!!---However, after printing perfectly 2 of 4 pages it STOPPED UNEXPECTEDLY !-----I traced that to WINDOWS XP CAUSING PRINTER TO "NOT WAKE UP"------Which has to do with POWER MANAGEMENT & requires One to Enter via Device Manager to reach BUS CONTROLLERS, THEN RIGHT CLICK TO expand & NOTE THE USB ROOT Ports.,---Open & UN CHECK or ( UN TICK)--That then overcomes that problem ----Funnily enough, as I continued to print , with combination of jpg images mixed in with text, to My surprise the locations where pictures Should have been Reproduced in Full, -Simply did as on E:mail sheets ( Which is how iI have "Reproduced perfectly Before the "Stalling at Start!---So, If Same Tech Officer Could Throw Light On That For Me & Steps To Take ( Hope Using Words Alone Are Enough For You , I Do Have Screen Shots I Could Onsend , Simply Put , What Is Now Reproduced Is "BORDER of PHOTO +With TINY in corner What Is "Click On T
  • Desmond Ayres
    Yes time to Promote Technician!-I was amazed at accumulation 5 years Black Ink upon Rollers & moistened Lint free cloth was Saturated , along with Hands!!!-Began printing happily, & IT Stopped Enexpectedly!-Traced to Power Management On USB Ports to be "UNCHECKED"-( XP Cause This !-)--Now prints well BUT when printing photos only does BORDERS ??--Most Grateful to you for timely ,correct HELP!-Is it possible for same Tech to explain why it is that using as I had done for Months, place text & photo's on an E:mail page /form-( Some friends are without Computers, & in that instance I "PRINT the 4 pages & Snail Mail (Simply put>REPRODUCES as if Receiving E"mail, with Border around photo, no Image, just the Mini Tri Colourbox in one corner ( Which IF E:mail, & "CLICKED UPON' Would "OPEN , SHOWING FULL IMAGE!!!---What to do to Effect a Cure WHEN wishing to, (as I had been able to do Before)- PRINT ALL PICTURES FULL SIZE WITH ACCOMPANYING TEXT???--GRATEFUL FOR YOUR SKILL, & PROMPTNESS THANKYOU all,-REGARDS,--Des.
  • 82 Answers
Hi , i am very happy to help you, but you put to much, i am french , and i know pc and verry well , just describe the prob , and what you wont to do, come back to me , we will fix that. yvon chow happy to help !!!
Posted on Jan 03, 2009
    Guru:
  • 449 Answers
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. Step12Turn off the printer. Step3Remove any paper trays. Inspect them for wrinkled or damaged paper. StepOpen any other doors that give access to the printer's paper path and to the toner or ink cartridge. Step35If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. Step46S3eemingly 'stalled If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. Step57266_a2.jpg If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though. Step6Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Step79If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path. If the problems continued try step11Inspect the paper trays to make sure they are not overloaded. To determine if this is the problem, do a test print with only one piece of paper loaded in the paper tray. (If this turns out to be the problem, keep the paper tray half-full in the future.) Step22Check that the type of paper being used falls within the printer manufacturer's recommendations. For example, paper designed for ink-jet printers doesn't necessarily work well in laser printers. High-quality, bonded paper will cause paper jams in some printers; look for bonded paper that is "laser and ink-jet compatible." Step33If someone has recently printed labels on this printer, check to see if a label has come unglued from a sheet and become stuck inside the printer. Step44Check the gears and rollers for stuck shreds of torn paper from previous jams. Turn off the printer before you attempt to remove the bits of paper.
  • Jerry Parmanand Jan 03, 2009
    Tips & Warnings
    • Occasionally cleaning your laser printer rollers with a lint-free cloth and isopropyl alcohol will extend their life and make them less likely to cause jams.
    • If you reuse paper to print on the back side, make sure that the paper is not torn, wrinkled or dog-eared. Tears, wrinkles or bends in paper can cause paper jams.
    Genius:
  • 1,913 Answers
First turn off the printer then remove toner ink cartridr from it check ther eis not any paper jam.
then also connect your usb cable in differ ports of usb. also check yourt usb cable working proper.
also remove sp3 update if it is in your system.
  • 916 Answers
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear access door. Press in the tab on the left of the door, and then pull out the door. Figure 1: Remove the rear access door S3eemingly 'stalled
  3. Gently pull the paper out of the rollers. If printing labels, make sure that a label did not detach from the label sheet while passing through the printer.
  4. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water.
  5. Rotate the rollers with your fingers to clean all the way around. Figure 2: Clean the paper rollers c00246512.jpg
  6. Allow the rollers to dry completely.
  7. Replace the rear access door. Align the pegs on the right side of the door, and then push the door forward until it snaps into place. Figure 3: Replace the rS3eemingly 'stalled" as if Paper Jamed ( It is cea - c00861146.jpgor c00861146.jpg
  8. Reconnect the power cord to the back of the productS3eemingly 'stalled" as if Paper Jamed ( It is cea - c01345237.gif
  9. Press the Power button (c01345237.gif ) to turn on the product.
  10. Load paper in the paper tray.
  11. Try the print job again.
  12. With the product turned on, open the product cover. The carriage might move to the center of the product. AllowS3eemingly 'stalled" as if Paper Jamed ( It is cea - c01553685.gifo that position.
    1. c01553685.gif 1 - Print carriage
    2. Without turning off the product, disconnect the power cord from the back of the product. CAUTION: In the following steps, you move parts by hand. If you do not unplug the power cord, there is a risk of an electrical shock.
    3. Disconnect the power cord from the wall outlet.
    4. Make sure the print cartridges are secure, locked into the carriage, and have not come loose.
    5. Check for any obstructions under or around the carriage that are preventing it from moving.
    6. Make sure the carriage can move freely across the width of the product by firmly pushing the carriage to the left, and then to the right. Clear any obstructions.
    7. Close the product cover.
    8. Reconnect the power cord to the back of the product. S3eemingly 'stalled" as if Paper Jamed ( It is cea - c01345237.gif
    9. Reconnect the power cord to the wall outlet.
    10. Press the Power button (c01345237.gif ) to turn on the product.
  • machadojr_fe Jan 05, 2009
    please when you go to print click properties and make sure the size is fit to page. Let me know if this helps.
Adding a brother printer to a hp2000 with 3 usb ports
USB ports create a virtual prot for USB-based printers, example; USB001, USB002, etc. It will not be LPT1.
May 13, 2014 | Lenovo H430-2558-1CU Desktop PC
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
Where is LPT1 USB port on Lenovo H430 for printer
Few computers use LPT1 connections, most use USB .Use a Printer cable with a USB to laptop. Your printer should have a cable that has a printer connection to a USB laptop connection? What is the Printer?
Dec 13, 2012 | Lenovo H430-2558-1CU Desktop PC
It cant print when ever its directed to print the error message is pending
  • Check if printer is ON;
  • Check the cable (USB, LPT1)
  • Check the paper.
  • Ping the Printer if it's on a LAN
  • Install this freeware: http://www.fantasticfreeware.com/index.php/applications/stalled-printer-repair/ .This gem will clean your stucked Print Jobs, if any.
Mar 15, 2011 | Office Equipment & Supplies
I bought an HP Deskjet F4400 printer for college and it keeps saying the printer is offline. I have a Macbook Pro, so there's no "Control Panel." I looked under "system preferences" but was unable to right...
its likely the printer port that the printer is assiged to. I assume its plugged in via usb. power on the printer, then connect the usb cable. go into the printer properties, look for printer port. do not use LPT1 LPT2 or Com anything. make sure printer port is set to the USB port. Its a mac so it may be tricky to find. Quite often these printers set to LPT1 by default which is incorrect on a USB printer. good luck.
Aug 25, 2010 | Office Equipment & Supplies
Cannot print from outlook express
u did not write which operating system u r using
>>if u go to the printer icon
>>u will find there is tab called "add a printer"
>>click on that >click on add a local printer >select the port for xp it would be usb virtual 001 port >or it is netwok connection select "lpt1">next page left side select hp as a manufacturer>and in the right select 990c>and next>select the printer as your default printer >now try to print from outlook
Dec 12, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Printer installation
Check on Control Panel-Printer Properties-Ports tab.
Make sure that the port selected is USB 001 and not LPT1.
Jul 30, 2009 | Epson LX-300+ II Matrix Printer
Printing from a parallel port to a USB printer
Do a Google search for parallel to usb and you should find all kinds of info. It seems that Belkin makes one. Check it out.
Mar 17, 2009 | Xerox Phaser 8550/DT Thermal Printer
Printing,hp deskjet3420
Hi Malcom,
The HP3420 is connected to your PC through the USB port and not through the LPT1/parallel port.
You have to change the port setting. Go to Start, Printers, right click on HP3420, click on Properties, go to the Ports tab, check/select USB, OK.
Alternately, you may have to re-install the drivers for the HP3420 and allow the program to Search for the printer connection. Clicking on the button Stop Searching will auto install it again to LPT1.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 25, 2007 | Computers & Internet
24 people viewed this question
jasbo
jasbo
