Question about Dell Inspiron dndon023 Notebook
Code 0x8004FF71 want to download this code update
STATUS CODE 4099-4174-1600-0700-C000-000E
Xbox.com has a handy search page to lookup error codes:
http://support.xbox.com/en-US/error-code-lookup
From that page, those is the answer and resolution they give, good luck:
" Error C000-000E occurs when you try to download an update to your Xbox 360 console
Problem
You see the following error when you try to download an update to your Xbox 360 console:
error code xxxx-xxxx-xxxx-xxxx-C000-000E
Update failed.
Note In this error code, the "x" digits vary.
This error message means your console could not download a software update from Xbox Live.
Solutions
To resolve this problem, try the following solutions:
Solution 1: Try installing the update again.
Solution 2: If you're having problems connecting or staying connected to Xbox Live, see Troubleshoot your Xbox Live connection.
Note You can also update your console software by copying the update to a USB flash drive or a disc and then applying it to the console. "
Jun 13, 2014 | Microsoft Xbox 360 Console
Forgot code no emei code 357405040887415Code0592667Fcc id:qfxrm-645
Just try This
1) Download the Nokia PC Suite
2) Download The Nokia Software Updater
3) Connect your phone using data cable
4) Update using Nokia Software updater
it will Reset all Codes and Settings and All your Personal data to Default
Please Note: make Sure you have a previous data Backup
Jun 08, 2011 | Nokia Cell Phones
I want to update it software version via USB cable
Nokia 6300 firmware update
Subject: how to update firmware for Nokia 6300 to the latest official version
1. You need download and install NSU - Nokia Software Updater (http://europe.nokia.com/support/download-software/device-software-update/download#) and run it to ensure that all is ok! (don't forget to switch on and connect Nokia 6300 via USB with PC)
2. You need to download and install NSS (Nemesis Service Suite) (http://www.b-phreaks.co.uk/index.php?main_page=page_2), the latest version of NSS was 1.0.38.15 (select "Virtual USB Device" mode)
3. Close NSU if it's not closed and load NSS then click icon "Scan for new device"
4. Click icon "Phone Info" and button "Scan" inside it
5. If all is ok you'll see some lines with Phone Version, Phone IMEI and so on
6. Click button "Read" and remember your "Product Code"
7. If your want to clean your phone go to tab "Tools" and switch to subtab "Factory Setting", choose option "Full Factory" then press button "Reset" (NOTE!!! all personal data and settings will be cleared!)
8. Return to tab "Phone info" and type in the field "Product Code" the following code 0537621 (or any code from (http://www.expansys-usa.com/ft.aspx?k=96957)) for version 7.21, or code 0557624 (or any code from (http://www.a2phone.com/6300-rm-217-dp20-900-sw-0730exe)) for version 7.30, select option "Enable" then press button "Write"
9. Close NSS, run NSU
10. Now NSU should update firmware to version 7.21/7.30 (or any latter build) (http://europe.nokia.com/support/download-software/device-software-update/can-i-update)
11. Repeat stages 3 - 5
12. Type in the field "Product Code" the code that you remembered before, select option "Enable" then press button "Write"
13. Close NSS
14. Use you clean phone with new firmware!
Mar 17, 2010 | Nokia 6300 Cellular Phone
I usung nokia 6300 and iam dowloding opera .opera not work my nokia 6300 and how to up grade my nokia 6300
hi may be the opera you are downloading is not suitable for your handset its better for you to not download opera
I bought Nokia 6300b RM-222 with firmware version 4.71, but now the latest firmware is 7.30 (or any latter build). But Nokia Software Updater (link) told me that I already had latest firmware and refused to update my phone. Below I described the steps to upgrade Nokia 6300b RM-222 from version 4.71 (or any other version) to version 7.21/7.30 (or any latter build).
13. Close NSS
Mar 15, 2010 | Nokia 6300 Cell Phone
I try to update and get error code 8002f9546 or close to that
The error code 8002f994 means that there are to many people downloading the update. Im not sure if that is the code u got but try waiting until the early morning hours to download
Aug 08, 2009 | Sony Playstation 3 (PS3) Console
PS3 update problems
Hello!!
Ok, no matter how you try to install the firmware it will always write it to the hard drive first before install. Now if it gives you the 800 error while downloading it's your hard drive and it may need to be re-formatted or replaced. If you get an error during installation, then therewas a misplaced piece of code during the download and it needs to be downloaded again.
BTW, the power button default reset is ONLY for the Video output settings.
Hope this helps. Good luck and happy gaming!!
Oct 22, 2008 | Sony Playstation 3 (PS3) Console
Code 28 drivers
how do i fix code 28 for free
Apr 14, 2008 | Microsoft Windows XP Professional
Dell Inspiron dndon023 Notebook Logo
99 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
