I have an Epson Perfection 4490 Photo unit and it is not working with my iMac with O S X 10.4.11 running Intel Core 2 Duo.  Not sure what I am doing wrong.  It used to work on my older mac.
  • 490 Answers
Disconnect the scanner, uninstall the drivers. Restart the comp and connect the scanner with power-on. The comp would respond a new device found. Reinstall correct drivers and your are on!.
S. Mohan
Posted on Jan 04, 2009
My epson perfection scanner doesn't work since i upgraded my iMac to OSX.10.8
Make sure you have installed the scanner drivers bcos sometimes it only installs printer drivers. I suggest you install the scanner drivers again. Make sure the scanner is turned in first b4 computer.
Oct 03, 2017 | Epson Perfection V700 PHOTO Flatbed...
Imac os intel core 2 duo inverter
Pop in your OS X DVD and run a repair install or an archive and install.
Apr 17, 2012 | Apple iMac G5 Desktop
I have a new Epson perfection 4490 photo scanner. I moved and can not find the CD that came with this unit. I never used it and can not find a copy of the CD to download. I would purchase one but live on...
Hi Ray,
You can download the drivers from Epson at this link:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Downloads&oid=58611&prodoid=53540925&category=Products
You need the Scanner Driver and Epson Scan Utility; the one at the top of the page is for Windows 7
Scroll down for Vista & XP version.
Sam
Sep 08, 2010 | Epson Perfection 4490 Film / Flatbed...
Epson problem
Here is the download page
http://www.epson.co.uk/Store/Scanners/Epson-Perfection-4490-Photo/Drivers-Support?supportLandingPage=true
To scan to PC you need to use a prog with twain support the basic one in XP is paint.(start/all progs /accessories/paint/file/from scanner or camera) the scan appears huge but that's just the way paint does it save and open with another prog for printing (eg windows fax and picture viewer) and it wil be printed normal size.
When installing drivers do not connect scanner until told to do so by the install prog.
Sep 16, 2009 | Epson Perfection 4490 Photo Scanner...
Is imac g5 17" lcd compatible with imac intel core duo
Possibly, the newer G5 Imacs feature Intel 2 Core Duo Processers. While older generations, do not support Intel Core Duo or Intel 2 Core Duo Processers.
Jul 09, 2009 | Apple iMac 17" MA199LLA Desktop
Scanner driver for Epson Perfection 4490 Photo 10.5.6 doesn't wk
Epson has a Mac OS 10.5 support page HERE
There is a new beta driver section you may want to try and there are FAQ's for the perfection scanner with Mac OS..
I know it will work with your Mac... I've got the same one and it's working. All the drivers as there as well.
k
Jun 10, 2009 | Epson Perfection 4490 Photo Scanner...
EPSON 1800 PROBLEMS WITH NEW IMAC
While you may have installed it, the generic driver may be selected. Here are all the steps to get you back up.
To remove any previous Epson printer driver files and get a good working install of the latest download for the Intel Duo Core, do the following:
REMOVE FILES
1. Double click on the MAC HARD DRIVE.
2. Double click on the LIBRARY folder.
3. Double click on the PRINTERS folder.
4. Drag the EPSON folder to the trash can.
5. Close any open windows.
6. Double click on the MAC HARD DRIVE.
7. Double click on the LIBRARY folder.
8. Double click on the RECEIPTS folder.
9. Delete any "Epson" receipts. Close back to desktop.
10. Open the OS X "Printer Setup Utility".
11. Select the "Printer Setup Utility" menu at the top of your screen and click "Reset Printing System...". Confirm resetting.
12. Close all open windows and restart your computer.
DOWNLOAD
If you have not done so already, use the following steps to obtain the download for the new Intel Duo Core driver:
1. Go to http://support.epson.com
2. Select Printers then Inkjet then your printer model.
3. Under "Drivers and Downloads" select Macintosh.
4. Download only the driver marked for the Intel Duo Core system.
Printer Driver v3.0aAs
Intel-based Macs with OS X (v10.4.4 or later)
epson11769.dmg - 12.4MB - posted on 02/06/06
Installation instructions:
1. Double-click on the "epson11769.dmg" file and follow prompts to create an "epson11769_r1800_printer_driver_30aas" disk image on your desktop.
2. Open the disk image. Double-click the "SPR1800Series 30a" installer icon to begin the installation.
3. Follow prompts to complete installation. Restart Mac once the install is complete.
Do the following to add the printer once the new downloadable Intel Duo Core driver has been downloaded and installed properly:
1. Connect printer.
2. Open Printer Setup Utility.
3. Click ADD.
4. Ensure you are on the Default Browser window.
5. Highlight printer as it appears under Printer Name.
6. For "Print Using" select "Epson Stylus R1800" if this automatically appears on the list. If this does not appear, select OTHER (not "Epson" - which links you to GIMP drivers, which we don't recommend or support). NOTE: if you are using a firewire connection, the printer name may appear as a letter only - ie "E" for "Epson". This is normal.
7. A new window opens where you can Browse to the hard drive location of:
HD > Library > Printers > Epson > Inkjet Printers
(This location contains all the Intel Duo Core Epson driver plugins, be they resident or downloaded.)
8. Highlight/Select the plugin for your printer model in the Inkjet Printers folder, then click OPEN.
9. Use the up/down arrows at the end of "Print Using" again to (re)select the printer's name, which will now appear at the TOP of the "Print Using" list.
10. Click ADD. The new downloaded driver will now be added on the list.
11. If there are other printers on the list, ensure the Epson is made default before testing.
When you are working with a printer model which supports borderless and/or roll paper printing options, you will be able to select these options in the program you are printing from as you set up your print job.
1. Once you have an image or file open, go to File > Page Setup.
2. For "Format For" select the Epson printer name (rather than "Any Printer").
3. Select the appropriate Paper Size. If your printer supports different layout features, each paper size will have several different options. For example, the 4x6 paper size will have an arrow pointing right which offers choices of 4x6 Borderless, 4x6 Standard-Minimize Margins, etc. Pick the paper type plus layout/margin option you want to use here.
4. Click OK on Page Setup. You are now ready to print.
Aug 17, 2008 | Epson Stylus Photo R1800 InkJet Printer
Pc does not recognize 4490
HI-
Try to replace the usb cable and try to plug it in a different USB port on your computer. Hope it didnt break aything when it fell, try to check the ports from the scanner as well. make sure you are not getting any red light when scanner is turned on. check under device manager for conflicts under imaging devices. If you see a question mark or if the scanner is not listed unde imaging devices, keep me posted so that we can check on your unit. Thanks!!
Jun 18, 2008 | Epson Perfection 4490 Office Flatbed...
71 people viewed this question
k24674
jasbo
jasbo
