Question about Health & Beauty
Hi re the tga eclipse mobility scooter there is a choice in 2 battery packs 1 that comes with the scooter the other is an option of a longer range all I want to know is will the longer range fit in the box that come with the scooter or do I need to buy an other box for the bigger battery and how do I open the battery box
SOURCE: we have lost the instruction manual for a TGA
If you contact TGA 01787 882244 they would be able to provide you with a manual, it is chargable though.
Posted on Jul 19, 2010
SOURCE: mobilty scooter fault
i have a shoprider mobility scooter has soon has i turn on it goes about 5 yards and stops and the alarm comes on i think it has something to do with the brake system could anyone advise me on what it could be thanks
Posted on Sep 21, 2009
gewiz
  • 1263 Answers
SOURCE: my battery pack on my fold n go has a short and
hi, ok now you need to check your wiring within the battery pack ,
If there are two batteries, you need to make sure that negative wire of one battery connects to the positive of the other battery,
now use the postiive and negative battery connections to connect to the scooter , that will give you your 24volts,
battery 1 connects battery 2
== 24Volts
use the + of battery 1 & - of battery 2 to connect to the scooter.
Regards
GeWiz.
Posted on Dec 25, 2009
Testimonial: "Thank you for answering. "
ZJLimited
  • 17970 Answers
SOURCE: my TGA eclipse mobility scooter
Sound like a electrical problem
Keep in mind the new device and its possible that you have warranty for this, you can reach they using the contact details below:
Scooters Mobility Ltd
Suite 3
40 Melton Road
Oakham, Rutland
LE15 6AY
T: 0845 273 9717 (local rate)
F: 01572 801 075
E: info@scooters-mobility.co.uk
Try this before to do something, you could lost the warranty..
Keep us updated.
Posted on Mar 31, 2011
  • 2418 Answers
SOURCE: I HAVE A RASCAL MOBILITY
I do not know of a Scooter graveyard, but I will look for one. I found a site that sells many different types of 24volt battery chargers. If you have a special port on the scooter and you still have your old charger you can cut off the end of the bad charger and wire it onto a new battery charger. Now as with most lead/acid battery's any charger with a built in volt/amp regulator will work.Your old charger spect's are for a 4amp max rating, Any constant 2.5amp or better should recharge your battery's overnight. I am sending you a link to a site called Battery Stuff.com where you can find a 24volt charger for as low as $89.oo, Now I understand this may be a bit out of your range, but a new battery charger for a laptop computer will run about $115.oo. So for a Heavy Duty scooter that is not to bad. Plus it may out last 2 sets of battery's. Now use this site as a reference and maybe you can find one you like local. Hope this helps Fixya up.
Posted on Apr 12, 2011
TGA Mystere mobility scooter. Scooter drives perfectly but drains batteries within 5 minutes of driving. Have tested with brand new batteries but still does the same. Help!
Hi again ring TGA PARTS FOR A PRICE ON CONTROL BOX 0117 329 1740 good luck i think u need to check THE BATTERIES condition buy a BATTERY LOAD TESTER .OF E/BAY COST APROX ,$35 ,.THIS WILL GIVE U A TRUE READING ON THERE CONDITION,,. Cheers
Dec 27, 2016 | Health & Beauty
TGA supersport mobility trike service manual
Hi go to. tgamobility.co.uk. There site has an enquiry page .good luck
Dec 10, 2016 | GoSouthernMD.com EWheels / GT3 Electric...
My 4s tga breeze keeps slowing down when I use it any ideas . Please help
hi, okay what happens to the battery indicator when this happens ?
Some points to note : the brake could be coming back on , check the brake by carefully touching it after use , take care because they can get very hot..if's it hot ,,, then it's not releasing fully or coming back on due to a brake issue, controller issue or simply a bad connection..
1. Battery & the charger.. Batteries may be fully charged however that does not mean they able to contain the load you place on them .
2. Brake...
3. a worn throttle pot... (WigWag, the go forward lever is attached to one )
At Worse a controller fault.
I offer a free controller test service..
Regards
Rob
www.gewizrepairs.co.uk
Nov 09, 2014 | Health & Beauty
Our tga eclipse is constant beeping and flashing 5times.trouble shoot says free wheel mode...have checked this what can be wrong?
There is a micro switch on the brake unit, make sure the freewheel lever is hitting the switch.
Oct 17, 2014 | Health & Beauty
TGA mystere mobility scooter error code 02 battery fault showing without key in ignition
Hi Dont know about Error 02, byt if scooter is less than 1 year old get the people you got it from to fix it under warranty,
Jan 28, 2013 | Health & Beauty
My mobility scooter batteries are put on charge but the charger green light to indicate that they are chaged no longer lights up
hi, now that could be one of three problems,
1. first check the charger ,is it possible to try the charger on another scooter ?
2. The batteries will no longer accept a charge ,this creates a fault condition with the charger. (try these batteries on another scooter if possible).
3. the actual charger plug in, you need to check the pins here , just the outside ones with a electrical meter, no voltage implies a bad connection to the batteries.
Regards
GeWiz
Please rate this reply.
Apr 22, 2010 | RTO Mobil Line Mobility Scooter Chair...
My battery pack on my fold n go has a short and
== 24Volts
Regards
GeWiz.
Oct 29, 2009 | ElectroVoice EV Rider FTCA020 Caddy Fold N...
Scooter battery problem
lots of things come into it driving up steep hills,useing lights,but you can get a larger amp hour battery witch make it last longer
Sep 28, 2008 | Amigo Rd 3 Wheel Scooter with 33AH Battery...
Health & Beauty Logo
102 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
