I have sound on the tv but no picture just the rainbow screen how to fix it also have no remote its a Mitsubishi cs-26ex1
    Genius:
  • Televison & ... Master
  • 2,432 Answers
Are you using a cable box?. tried to reset it.
Posted on Oct 28, 2012
get-it-goin
  • 85 Answers
SOURCE: 42" LG RZ42PX11 Plasma - rainbow lines on whole screen but sound
hi there.its likely that the lower y-drive panel has died.this is a very common problem with this model.the easy way is to remove the panel from the set completely,power it up and you should be greeted with the top half of the picture.this means ic failure,usually the bottom one for some odd reason.not replaceable unless you have the gear,these ics are available from dalbani(nikkai)for those interested.be extra careful with the four ribbon cables when removing/refitting.damage to these writes off the display panel.hope this helps somewhat,regards,steve.
Posted on Feb 27, 2009
premtech
  • 934 Answers
SOURCE: no picture on flat panel tv. has sound
Sounds like the digital control board, 6871qch038a Lg Digital Control Module subs to 6871qch038c. But that's just a first something I would check in this unit. Replace also capacitor C19, 630V big blue square cap very common failure for no video. You might want to shop this one thee are a host of problems with this unit that would certainly get some needed attention if a qualified tech were testing it and looked up the bulletins.
Good Luck!
William Rayburn, CET
Premium Technologies
Posted on Oct 05, 2009
promo7uk
  • 19 Answers
SOURCE: rainbow lines and no picture
NEW YSUS AND BUFFER BOARDS ARE NOW NEEDED THE YSUS IS THE BIG BOARD IN THERE VERY LEFT HAND SIDE ONCE BACK IS OFF BIG BOARD WITH 1 BIG HEATSINK,, THAT AND THE BUFFER BOARD PUSHES INTO THAT WITH TWO BLACK CONNECTION TO THE YSUS REMOVE BOTH BUFFER IS FIDDLEY,,NEED TO REMOVE 4 RIBBON CABLES ATTACHED TO THE SCREEN B4 HAND,,
6871QYH053B IS YSUS MODEL BUFFER U WILL ALSO FIND ON EBAY.
Posted on Jun 26, 2010
vinceisaac
  • 2432 Answers
SOURCE: Have a Mitsubishi TV Model
good day did you mean sir the picture or the channel was lost, have you been tried to re scan the channel using the tv menu or with the use of remote.just let me know if this what you are asking for thanks.
Posted on Aug 16, 2011
SD Tech
  • 14553 Answers
SOURCE: My Tv Is A Panasonic 51cm ctv model CS-21Z88SQ NO SOUND BUT ONLY PICTURES
Look on rear to see if a slide switch for internal/external speakers.
Look in menu to see if has a feature speakers on/off.
Put your ear straight to the speaker to see if hear anything; if nothing heard either bad speaker or audio circuit problem.
Posted on May 25, 2012
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
My son was bouncing a small ball against the screen and then it went to looking like a rainbow. Would this be the picture tube?
He may have caused some type of damage to the picture tube, but usually rainbow effects happen when magnets are present. Perhaps the ball became charged with a large amount of static, which then discharged across the tube, damaging the controlling circuits.
Jun 03, 2010 | Toshiba 36A43 36" TV
Television is dead. won't turn on picture or
There is a fuse in tvs I've had to change one myself
Oct 16, 2009 | Mitsubishi CS-26201 TV
I have a mitsubishi cs-26ex1 tv and the parental code is set but I dont have the original remote or a user manual to reset the code. How can I unlock the tv?
well first lets narrow this down so the tv is already holding a code you will need the old code to re-enter a new 1 okay if the code is known you may be able to set with the menu button goto pc option try to use the channel up and down and volume see if this will help now lost remote may try a universal remote make sure it has the menu option on it ,also when entering code numbers some have over 5 or so codes okay the tv may respond to 1 code but not let you use the menu so try each code also if you cant remember the code its not to good you will have probally no choice to take to tv shop okay good luck shad
May 06, 2009 | Televison & Video
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
I have a 3 year old mitsubishi wd-52526 lcd projector tv that is starting to have some focus/image alignment issues - in general picture is a little out of focus and there are rainbows around things at the...
the differnt guns are out of alignment. Your tv has 3 lcd screens, a red, green and blue one what overlay to form the image. Sometimes they move slightly for what ever reason and that causes the rainbow and out of focus picture. Its something that a trained pro should do but is a cheap fix and won't set you back too much
Oct 20, 2008 | Mitsubishi Televison & Video
VS-50803 50" Mitsubishi No picture problem
Sounds like your picture tube has went out,, or maybe something simple,, to fix,, i would at least let a tv shop check it out ,, worth a chance ,, nothin 2 loose,, good luck
Oct 05, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Mitsubishi cs-26ex1
This sound like the standard Mitshubisi PIP board problem. There are two ways to adress this one is to repair the board, this involves replacing surface mounted capacitor and is about %80.00 sucsessful. The other is to simply bypass this board. this option is the way to go, it involves installing two capacitor on the main board and fixes the main pix but kills the Picture in Picture (PIP) I will send off both these repairs to your E-mail
Feb 13, 2008 | Proton MM2701VT 27" TV
Mitsubishi cs-26ex1
If your set has Picture in Picture, I would say your problem is with the PIP module. if it does not have PIP then the problem is most likly in the video switching or the video processor Printed circuit board. if you know anything about solid stae serviceing, there is a modification I will include here for the PIP as the module is no longer available and has to be jumped out of the curcuit.. Good Luck. Follow the picture and instuctions to the "T" PS please do not forget to rate this thread
Oct 17, 2006 | Mitsubishi CS-27209 27" TV
Televison & Video Logo
Top Televison & Video Experts
