My B&O Beosound 3200 memory system has an error. When I try to activate the "CD MEM" it just stop in the function writing "LOADING"! Meaning that I`m not able to listen to my all my copyed/saved CDs My friend and I bought the same Beosound stereo 3200 at the same time and he has the same problem on his system. Is this a known error and what can be done to solve the problem? Regards Torben
SOURCE: GE 7-5295 CD error
i have the same problem exept that also the eject button is not working or the stop buttton.
Posted on Feb 25, 2008
SOURCE: I have a Bose Wave Music System with add-on 4 cd
I had a similar problem. No discs would play and sometimes they would not eject. I solved my problem with the crevice tool on my vacuum cleaner. I vacuumed out all the openings on the unit, especially the cd slots. This discs now play and eject.
Posted on Feb 14, 2010
SOURCE: Bang & Olufsen Beosound 9000 - CD does not play
gently open cd player clean laser with a cotton bud and wipe all round laser part and lugs at top and bottom of unit
Posted on Mar 29, 2010
  • 3 Answers
SOURCE: The CD player in my Pure Legato 2 system won;t
I have fixed this problem in 2 Legatos. But don't attempt this if you have no experience with electrical equipment.
You need to open the case (4 screws deeply recessed in the back panel, 3 screws securing the speaker terminals and the phono socket block, and the nut and plastic washer holding the aerial socket. Gently ease the rear panel back enough to access the rear of the CD mechanism. Under the CD laser assembly carriage, there is a small trim pot (with a yellow cross-head adjuster screw). I found a small anticlockwise adjustment got the CD player working again. (I assume this trimmer increases the gain of the optical sensor amp.) Secure the rear panel before powering on again to test. It may require a little trial and error to recover the full functionality of the CD.
Good luck.
Posted on May 30, 2010
SOURCE: Beosound 9000 scratching top cd
You have to look up in the manual which way the two arrows on the underside of the unit are pointing when the CD player is located on the far right. The arrows are screw heads which appear in two holes on the underside. If, for instance, you are playing the unit lying flat on a shelf or table top, if you flip it up and forward to get at the arrows, the two arrows should both be pointing left. If you are mounting it on a wall, it's a different arrow combination. I had the problem you describe and this fixed it for me.
Posted on Jun 02, 2010
Bang and olufsen beosound 3000 does not read cd and loading stops. Can you help? Thanks
I never had like that. But "normally" there may be two reasons: CD fault or control board fault. Sometime main control keeps memorized wrong data and (in my Ouverture) CD unit simply is not responding and not loading - standing still. No way to move on except plugging off the power, press CD start on remote with no power, plug in power and try again. It clears bad data. I suspect it happened few times when I stopped CD player by remote or local main switch off.
Aug 19, 2014 | Bang and Olufsen Beosound 2000 Shelf...
STOP 0X0000008E(0XC0000006,0XF740DFEA,0XF6F0AA14,0X00000000)
The stop is actually a OS error code abbreviated "Stop 0x8E "
"KERNEL_MODE_EXCEPTION_NOT_HANDLED"
In reality it is a BSOD (Blue Screen of Death).
The most likely cause is caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Type the same as the quotation "Stop 0x8E" into Google - it will take you to the error code and give you the meaning.
It's not a computer processor error, at all, but a memory or driver error. Most likely a device which is trying to be used by the OS you are loading but can't load because the device needs a driver or the memory is loose (besides bad memory). Remove the memory and re-seat. Make sure not to touch the contacts with your hands. Take a pencil eraser and clean the contacts.
For a better answer, the next time give the OS version you attempting to load, and the hard drive you are using whether ATA or SATA. The more data the better. Now to test your memory --- download MEMTEST (find it on Google) it's FREE. And run Memtest on a Floppy disk or from a CD. Run the complete ALL tests, It will take many hours, but you can write down the errors (if any) and exchange your memory for new memory under the lifetime warranty that memory maker give. Good luck.
May 10, 2014 | Computers & Internet
I HAVE A BEOSOUND 3200 THAT I HAVE'NT USED FOR YEARS..I WANT TO HOOK IT UP TO MY AMPLIFIER TO PLAY THROUGH THE SPEAKERS CONNECTED TO AMP..HOW DO I HOOK UP TO THE AMP?
take the output from the beosound and place it to the input of the amp and then switch it to the front of the amp. eg. if the put the beosound output into cd, tape, phono, aux or game etc you must highlight it to the front of the amp so the sound can come through.
May 01, 2014 | Audio Players & Recorders
Bang & Olufsen Beosound 3200 CD Door won't open
Could be the PCB9 light and motor control have the problem its on the upper left side of the player.
Feb 25, 2013 | Audio Players & Recorders
How do I clear my info so I can sell the machine
  1. SYSTEM= (Firmware ID) - Press [BACKSPACE] to initiate the destructive
    memory test.
  2. MEMORY TEST MEM WILL BE LOST PRESS FUNC IF OK - Three prompts are displayed to warn you that a destructive memory test has been initiated, and to inform you that the contents of the SRAM will be lost if you proceed with the test.
  3. Press [FUNC/ENTER] to proceed with the test. To end the memory test and return to the System Prompt prompt, press any key on the core keypad other than [FUNC/ENTER].
  4. MEMORY TEST (or) MEMORY -OK- (or) MEMORY ERROR - The memory test runs continuously until you stop the test. During the test, the message displayed on the terminal
    screen alternates between MEMORY TEST and MEMORY -OK-. The message MEMORY -OK- indicates that no memory problems were detected during the previous test.
    NOTE: If a problem is detected during the test, the error message ***BAD RAM*** is displayed. If you see this message, contact your local VeriFone representative for assistance.
  5. To stop the test, press any key while the MEMORY -OK- message is displayed. The message MEMORY ERROR is then displayed to indicate that the contents of the memory were erased during the test.
  6. Press [CLEAR] to return to the System Prompt.
Feb 14, 2011 | VeriFone OMNI 3200 (P092-101-10) Printer
Hello is there a way to connect a sony 52EX700 to a beosound 3200 system? regards Laurent
You can use the aux out or get yourself a beolink cable.
However the 3200 is not surround sound capable it was designed for audiophile CD enthusiasts, My advice is to get a home theatre system and leave the 3200 for those special music moments.
Aug 14, 2010 | Bang and Olufsen Audio Players & Recorders
Bang & Olufsen Beosound 3000 Ouveture CD Problem....Please Help!
Chances are you will need a replacement cd mech assy to fix this problem assuming you have already cleaned the laser lens(cotton bud with ethyl alcohol or isopropanol).dont know of universal remote for b&o but some specialist remote replacement companies do one for beolink1000 which will operate your product.
Feb 15, 2010 | Bang and Olufsen Beosound 4000 Shelf...
Acer 3200 Ferrari !! Urgent
 First I would try a system restore to before the point when you first started getting the blue screen,it could possibly be a driver update conflict.
Mar 25, 2008 | Acer Ferrari 3200 Notebook
47 people viewed this question
 Grubhead
Grubhead
