Question about Baumatic 20 in. BWK1 Gas Cooktop
Flame too low - Baumatic 20 in. BWK1 Gas Cooktop
Why do Jenn-Air cooktop igniters click when the exhaust fan is on med-high and the burners are on low flame setting ? ?
Igniters sense flame temperature, and if the fan cools the temp sensor down, your cooktop thinks the flame has gone out, so it clicks to reignite it.
Sep 02, 2014 | Jenn-Air Cooktops
How to adjust flame on Westinghouse freestyle gas oven
The flame is regulated by the thermostat you don't say if it's too high or too low. Suggest you buy an oven thermometer available for a few dollars at most homeware shops, compare the temperatures then you will see if the thermostat is working or not.
Apr 22, 2014 | Cooktops
No flame on exx low
This is generally due to blocked burner heads due to spills, remove it and clean it thoroughly before going any further.
Apr 01, 2014 | Thermador SGS36GS Gas Cooktop
The flame is too high on my GE Profile gas cooktop
I had the same issue on my jgp975 and sadly I had to purchase a different unit. I use simmer frequently and I made the assumption that low was simmer. Wrong. I believe a true simmer is 450 btu and my unit did not go that low. I had to check the fine print/specs page and on some units the manufacturer had to be called. I did replace with another ge profile that did have the low setting.
Apr 06, 2010 | GE 36 in.JGP970 Gas Cooktop
Kitchenaid 30'' low flame output
It's wasn't the perfect solution but I removed all the burner caps and cleaned each one with a tooth brush. Then using a metal trussing pin, I poked through the flame holes to clean them. Noticed better flame output from both.
Mar 06, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Flame burns too high t0 simmer
if you look closely, down the center of the knob ther should be an adjustment screw to lowert he flame
Jan 26, 2009 | Amana AKS3040 Gas Cooktop
Cant find the set screw to adjust the flame
some arent adjustable any more, did you look down the center of the knob shaft???? most common place for it
Mar 16, 2008 | GE 30 in. JGP990SELSS Gas Cooktop
Low flame from gas cooktop
you can adjust the flames as follows pull a knob and look in the end of the brass peice you will see a small screw first you have to find a screw driver that will fit then with a pair of pliers hold the outer peice with the burner on and turn the screw one way rasies other lowers ideal adj is to turn buner all the way up then fast down if flame goes out to low keep working like that till flame is low but doesnt go out
Dec 30, 2007 | Kenmore 30 in.32232 / 32239 / 32234 Gas...
AEG 5 burner gas hob
there is a bypass screw on each gas valve. adjust so flame is reasonable when each burner is turned to low
Jun 15, 2007 | AEG 34942G-M Gas Cooktop
Flame too low
Most probably dirty jets. If water was spuilled, there is a possibility of rust forming on some parts. Low flames are usually due to inadequate gas supply, due to dirty jets and burners. Often rust forms on the top burners in the little holes, causing slight blockage - clean the holes with a needle properly and check. Oshie
Jul 30, 2006 | Gaggenau 23 in. KG 260 Gas Cooktop
Baumatic 20 in. BWK1 Gas Cooktop Logo
18 people viewed this question
Top Baumatic Cooktops Experts
Paul Carew
Are you a Baumatic Cooktop Expert? Answer questions, earn points and help others
