Question about Dell Inspiron 6400 Notebook
Laptop start AS i just asked u ... my laptop not starting ... only power button LED glows ... i refixed my battery but no results ,,,, can u guide me more.... thank u
    Genius:
  • 1,913 Answers
Open your laptop back side clean your battery from dust also clean dust from laptop slots. pen the ram plate and refix it.
the still got problems remove cmos cell for 15 minutes then refix it.
Posted on Jan 03, 2009
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
Need to fix G62 computer:will not start
"Worked in the past, doesn't work now", That's sort of the definition of a failure. Has the laptop been dropped? What does the laptop when you try to start? Do you see LED"s blink? Fan spins? HHD LED blink? Battery light on? Has the AC jack been damaged due to pulling on the cord? Did you try a cord/charger with the EXACT same power spec? Test the DC volts at the laptop cord plug with a multimeter. Reseat the Memory mods. May be a HDD failure? Post results
Feb 02, 2013 | HP Computers & Internet
Does cq61 laptop works without battery
I would assume that the wire/power supply is more likely to be the problem. Even if the battery is completely shot, most laptops will start if the power cord is plugged into the outlet and the laptop is turned on. You should check on replacing the power supply / power cord. Buy it from a store that takes returns with no questions asked. I've even bought one, tested it in the store, (after asking in advance if I could do so). This is a good idea if you live 40 miles from the place it's purchased.
Feb 21, 2012 | Compaq Presario CQ61-310US Laptop
Monitor does not come on (screen is black) Wife turned off everything was fine now can't get back on. Is there some sort of lock on these units?
dear friend,
please do some activity to conform the problem in your laptop, veryfy while you are pressing the power button after some time, press the num lock or cap luck switch is it working means the light is blowing or not? are able to listen the windows start sound? then connect a external monitor and try to swict the vdo on it? if yes then it is the LCD problem and you need to change the LCD assembly. if no then try the following steps:
1: veryfy your adoptor light is glowing or not? if yes then go to next step, if no then replace the adoptor.
2: remove all the external connection, remove the battery from backsite. remove the power adoptor. press the power button for 2min. then connect the battery, adoptor and try... if no then follow below
3. then try to on the laptop by pressing fn+power on botton. try to refix the ram. is there any LED is glowing or not..........?if no then you need to change the mother board
Jan 19, 2010 | Dell Inspiron 6400 Notebook
Me too
Hi, Please try the following DIY to confirm the part 1.remove the battery and check on adapter mode. 2.If not powering on then check with refixing the battery. 3.if no use then check any LED is glowing,check with taping the num lock and if the LED responds then this is the memory issue otherwise a MB issue.
Jun 12, 2009 | Toshiba Satellite Pro P300 Notebook
Got power but no display
Jun 12, 2009 | Acer Aspire One AOA150-1570 Notebook PC
I have accidently locked my acer 5050. Can you kindly guide me to unlock it. I can't close off the laptop also
hi dear,
try this,
1) press power button longer than usual, it should turn off
2) if above not happens remove batteries and refix them, now try to start, this should work fine
thanks
shaggu
Apr 22, 2009 | Acer Aspire 5050 Notebook
Dell Inspiron 9100 Laptop will not turn on.
4.if no light glows then also this is a MB issue as converter board is on the board itself
Mar 07, 2009 | Dell Computers & Internet
Acer aspire 4520 won't open
open your back side of laptop.refix battery and refix ram. then chek.
Jan 24, 2009 | Acer Aspire One PC Notebook
Dell Inspiron 6400 Notebook Logo
Alun Cox
