Hi, I am trying to extend my bt broadbands coverage, i have two hub3 but cannot extend, i need extra ethernet ports
I have two home hub3, and tp link connectors, but secondary hub has no ethernet ports working
  • 2,878 Answers
Make sure to use the main uplink ports. If not try a crossover cable.
Posted on Nov 01, 2012
5 Suggested Answers
suisboy
  • 175 Answers
SOURCE: ASOUNDX AL1600-D 16-Port 10/100Mbps Ethernet Switching Hub adapter
only thing you need to get a 3.3v adapter. your hub will work when to turn it on.
i guess it uses 5mA.
Posted on Jan 04, 2008
SOURCE: Power supply of wisecom 8 port fast ethernet hub
12 volt AC 1500mA wall transformer
Posted on May 05, 2010
samuelseno
  • 103 Answers
SOURCE: Linksys NH1005 V2.2 Ethernet 10/100
Hello!
I will just illustrate on how to configure or to set the correct IP addressing;
Assuming that we will manually put IP address on each computer:
PC1:
IP Address: 192.168.1.13
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
Preffered DNS server: 192.168.1.1
***note that 192.168.1.1 is the IP Address that your ISP gives to you, so on the other computer (see below)
PC2:
IP Address: 192.168.1.18
Hope I was able to help.
Posted on Oct 09, 2010
  • 97 Answers
SOURCE: 1 connected ethernet cable from
If your trying to use this to share an internet connection.. sorry to say but it's not going to happen. The hub that you purchased will not handle the DHCP settings that need to be processed to share an internet connection.
Best advice... go back to Best Buy and smack the agent that sold you this and get a router instead. :D That's what you're needing to share your connection.
Posted on Oct 23, 2010
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
Associate wireless router to my home hub
If your Home Hub is a BT type internet hub, then you can connect the WAN port to the Ethernet port on the Hub.
This means it will go through two routers. One in the Hub and another in the Edimax. The Edimax needs to be configured as a bridge, because you need to keep within the same address range as the BT router. The Edimax DHCP allocation of IP addresses need to be disabled. This is not on the web site.
EDIMAX Technology Official Website Wireless Routers 300Mbps Wireless...
Mar 02, 2015 | Edimax Network Br-6428ns Wireless N 300m...
I want to connect to BT broadband using my TP-Link TD-WD8901G routerg
Sounds like you need to change the TP link router for a wireless Access Point or a range extender.
Who knows what goofing around BT does with their equipment.
Mar 20, 2014 | TP-LINK TL-WR642G Router
I cannot get ethernet connection from BT hub 3.0 on my dell inspiron 5160
try connecting through an ethernet cable. see what happens. Install the appropriate modem driver and network driver from support site.
post your comments if solved/not solved
Hope this helps
Dec 22, 2012 | Dell Inspiron 5160 Notebook
I cannot conNECT my new netgear router to sky broadband model number DGND3300 range max dualband
Do not connect routers to routers. You only need one router. Extra sockets are added by connecting what is known as a switch. This takes 1 ethernet port from your router and extends it to however many ports the switch has (5, 8,12, 20 etc). If necessary, you can add another switch to one output of the first - giving even more ports.
Apr 29, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
How can I install or connect my d link to the internet line and my computer
I assume you have a broadband connection which you are directly to your computer.
In that case please connect the broadband ethernet cable to one of your switch port.
Get a new CAT5 or CAT6 ethernet straight cable and connect one end to any free port of the DES-1008D 8-Port Ethernet Switch and other end to your Computer.
No configuration needed to be done on DES-1008D 8-Port Ethernet Switch
Best Regards
Nov 20, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
BT ADSL prob: ATM OAM F5 segment ping - OAM F4 FAIL
are you using the router through a BT line? if you are BT will be able to sort this problem for you by sending the router an update that it sounds like it needs
hope this helps
Nov 20, 2008 | Computers & Internet
Xbox360 connection
Yes, you are able to connect your 360 using a hardwired connection. In fact, it is even faster that way!
Your BT Home Hub has two ethernet jacks on it, for use with whatever devices you wish to connect to the internet (in this case, your 360). Simply plug your 360's ethernet cable into the jack, and voila! You can now access Live. However, if you wish to host games over live, you may need to open up certain ports for Live to use.
The ports are listed at: http://support.microsoft.com/kb/908874
A manual for using and setting up your BT Home Hub is at:
http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=16536
Near the bottom of the page is a link for the PDF version of the manual.
Jan 01, 2008 | Video Game Consoles & Games
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
