Question about Ferrari High Back Booster
I wash the carseat ,but could not fit the belt back
Straps have been washe and need to know how to putr back together
Hi
The harness straps should not be removed from the carseat shell due to the safety implications of them being re-fitted incorrectly. The carseat would need to be sent to the engineers for re-fitting the harness. What country are you in and we can direct you to the relevant customer care team to discuss this with.
Feb 18, 2012 | Maxi-Cosi Axiss Reflection Booster Car...
PIERRE CARDIN BABY CARRIER
Hi
Due to the safety implications of the carseat harness being incorrectly fitted if the harness has been completely removed from the carseat shell it would need to be sent to engineers for them to re-fit the harness. What country are you in we can direct you to the appropriate customer care team to arrange this.
Feb 02, 2012 | Maxi-Cosi Cabrio Red Flame Reflection...
How to put saftey 1st straps back on after wash
Hi
Due to the safety implications of a carseat harness being incorrectly fitted they should never be removed. To replace them the carseat would need to come in for our engineers to do.
What country are you in I can advise of who to contact?
Dec 08, 2011 | Safety 1st Baby Gear
I took the maxi-cosi straps of to wash and now do not know how to put them back.
Due to the safety implications of the harness being incorrectly fitted the harness should never be removed. To get the harness back in the carseat safely the carseat would need to come to the engineers for them to carry out this work. Please call the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 to discuss.
Oct 22, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
TOOK THE STRAPS OFF TO WASH THEM AND AM NOT SURE HOW THEY GO BACK ON
Good Evening
Have you removed the harness from the carseat? This is unfortunately not something you should do even to clean them, as if they are re-fitted incorrectly it can cause safety implications.
Please contact our customer service department on 01284 413141 (Mon - Fri, 8:30 am to 4:30 pm) to book in the carseat for chargeable repair by our engineers. Standard charge is £50 and this includes full safety checks following the repair and courier delivery of the carseat back to your address. In addition you will need to make arrangements and cover costs for courier delivery of the product into the engineers.
Jan 17, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a maxi cosi cabriofix car seat and I have washed the cover but I'm having trouble re-fitting the straps. I've looked at the website for them and everywhere on the net but no luck with instructions...
Good Evening
The harness should not be removed from the carseat. Incorrect re-fitting of the harness may cause safety implications so the carseat does need to be returned to our engineers for full inspection and repair work required.
Please contact our customer service department on 01284 413141 (Mon - Fri, 8:30 am to 4:30 pm) to book it in for this. Standard charge is £50 and will include courier delivery of the product back to your address. In addition you will need to make arrangements and cover costs for the carseat to be sent to our engineers.
Jan 06, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
I took the car seat cover off to wash but now I can't seem to work the straps out - can't find the manual can you help in any way?
hi
this is a similar carseat but I'm sure that this manual should give you the right idea of how they go back in
http://www.chicco.com/Portals/0/Products/Pdf/Istruzioni_Key1%20X-Plus%2063251________.pdf
most carseat now have this fitting
Oct 19, 2010 | Chicco Shuttle Infant Car Seat
How to fit a maxi cosi cabrio car seat - note it is the old style not the new cabriofix
To fit the Cabrio (with seat belts only), follow these steps:
Note that you will have three metallic looking blue seatbelt hooks (made of plastic) on the Cabrio. One is at the back to carseat (directly behind the childs head) and also there is one either side of the child (when seated in the carseat), these hooks are used to slip the seat belt into and therefore secure the seat.
Placing the carseat facing the rear windscreen of the car - if this is in the front seat, then ensure that your airbag is disabled if you have one. If this is not possible, then DO NOT use the front seat.
Ensure that the carseat handle is clicked into the 'carrying' position, upright.
Taking the seatbelt in your hands, slip the lapbelt through the two blue hooks which are either side of baby and then click the seatbelt into the buckle. Pull firmly so it's nice and taut, hold onto the carseat when you are pulling the seatbelt.
Whilst taking the slack with one hand, take the shoulder seatbelt and loop through the third blue hook (located on the back of the carseat) and again pull firmly whilst holding onto the carseat.
When you attempt this, practice without the baby in as this is much easier to do.
Finally, check that the buckle of your seatbelt is not resting too high or on an angle of the cabrios plastic shell, as this is considered dangerous and is called 'buckle crunch', for more information on this, please see the link below, which explains with images:
http://www.childcarseats.org.uk/choosing/fitting.htm
I hope this helps.
Oct 04, 2009 | Baby Gear
Need instructions to put harness in carseat back together
my mom has an eddie bauer carseat for my daughter and washed it how do you put it back together
May 24, 2009 | Eddie Bauer Baby Gear
Put harness belt back on baby car seat
22880-mtta is an Eddie Bauer carseat. Go to http://www.eddiebauer.djgusa.com/usa/eng/Instructions
Enter the model number 22880-MTTA, and date of manufacture.
Nov 11, 2008 | Baby Gear
Ferrari High Back Booster Logo
Top Ferrari Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Ferrari Baby Gear Expert? Answer questions, earn points and help others
