Suddenly my receiver writes no signal why??? By the way all my cables are plugged in I've checked them
    Genius:
  • Televison & ... Master
  • 2,432 Answers
Are you using a cable box?. tried to reset it.
Posted on Oct 28, 2012
I have a Pioneer VSX D412 S receiver with my Pioneer surround sound system The system SUDDENLY STOPPED RECEIVING SOUND SIGNAL FROM MY HD TV
  1. Turn the TV and receiver off and back on. This is called "power cycling" the devices.
  2. Check the menu settings to make certain the TV is still sending a sound signal out to the receiver.
  3. Disconnect the cable, blow both ends out, reconnect, and see if the cable was partially disconnected or has dust or lint interfering with the connections.
  4. Change the cable for another cable that you know to be working.
  5. Use a different source for the TV: DVD, Cable, different channel, etc.
  6. Connect the receiver to another TV.
Dec 16, 2015 | Pioneer Audio Players & Recorders
How do I get a signal from my Jack OA8200 digital tv antenna.
The signal meter should show you available TV transmitters. If you have received a signal at this location before and you definitely are sure it is powered up the antenna is defective. Check for anything that appears loose or broken. If the meter indicates a signal check the cable that goes to the TV.
Oct 28, 2014 | Jack OA-8000 Digital TV Antenna
Sirius truck antenna stopped working
The truck antennas can go bad. It could be the cable though. You can replace either part at www.tss-radio.com
May 20, 2012 | Sirius Satellite Radio Receiver
Loud static noise coming front right speaker on home theater system. I've removed all cables and all speaker wires except that one and still get the noise. I've tried plugging the unit into another...
Make certain you have not started some kind of test signal going by looking in the the user manual, if not by all means send it back. Phone or E-Mail the makers helpline first they should sort any problems and confirm you have set it up right.
Jul 04, 2011 | Audio Players & Recorders
Onkyo receiver TX SR 605 saying no signal input from cable when everything appears to be plugged in correctly and powered on and it was working 10 minutes ago. All other connetions (Apple TV, dvd player)...
Hello, I am sorry about your issue. Please plug the cable box into a known good HDMI port on the receiver. Confirm that there are no issues with the cable or plugs. Thank you, CB
May 30, 2017 | Onkyo TX-SR605 Receiver
I am hooking the system to a yamaha stereo receiver and i need to know what jacks to hook it to out or in 3 wire or just 2 because of no video just audio red white yellow the stereo reciever just has ...
Let me write some basic things about audio and video signals and cables. Stereo audio has two channels, left and right, usually red and white (or black) jacks. You plug in audio cables. Video signals in old receivers are marked in yellow. If your receiver does not have video (yellow) input, usually located above the two audio inputs, you will not be able to watch any video signal through the receiver. The receiver will only play the sound of dvd, since its left and right audio channels are properly connected. Just aux and phono inputs are not enough. Hope this may help.
Sep 07, 2010 | Audio Players & Recorders
Error message on Syncmaster- check signal cable
sounds like it might be a graphics card. if u have an old graphics or vidio card, open the case and remove your card then install the old one. if it works now youll know your card is bad. If u have an old video card and an open pci slot install it and move the monitor cable to the old video card plugin. if it works now same thing your graphics card is bad. to know which card to remove just remember which one the monitor is plugged into.
Jul 29, 2009 | Samsung SyncMaster 940B Monitor
The right Channel is not working
hello if you are sure that you check everything, speaker,cables input signal.
if this pionner suddenly stops playing in one channel the most probable is in protection not burned so it needs service at repair shop.saludos
Jan 17, 2009 | Pioneer VSX-D811S Receiver
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Sony a/v reciever not sending video to tv.....
I don´t know if I´ve understood, but the best way to "pass" video signals to TV through receivers is using a stereo VCR, where you plug in any antenna. Then you connect VCR´s audio and video channels to the receiver. Turning on all equipment, select video1 source. You will hear sound through the system and watch video signal on TV. Hope this may help.
May 22, 2008 | Sony A/V Receiver
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
