Question about Linksys Wireless-G WRT54G Router
How can i see my 2 cpu in my network?
I have a 2 cpu connected on a router both are wired but the problem is i cannot see 2 cpu icons in my network.
    Genius:
  • 1,913 Answers
First configure your routwer to dhcp enabled.then set in your 2 cpu lan proeprties as ip auto
Posted on Jan 03, 2009
How do Connect two computers - one hard wired and the other WIFI
to connect a computer with a hard wired connection just use an ethernet cable and wireless you should see available connections when you click on network icon bottom right of screen then click on your router name and enter password if required.
Jul 28, 2012 | Linksys Computers & Internet
Trying to connect wirelessly to 2 wire. I get limited access icon
Hi groveland1,
I see that you are having issue with your Internet Connection, Limited or no connectivity is a possible issue with your network key / security key on the router and your laptop.
1. Try and check the network key in your router.
2. Check your network settings in the Laptop and see if the security settings in your Laptop is the same as the security/network key in your Router.
3. If possible recreate your wireless connection in windows for a fresh connection from your Laptop to your Router.
4. Change your Network Key in the Router and in your Laptop see if it will connect in-case you may have forgotten you old Network Key.
Hope this helps.
Apr 04, 2011 | 2wire (1000-400108-001) Router
I have installed, set up, and created my router's name, password, and key, but im still having trouble connecting to the internet. The little icon that looks like the earth is glowing orange, and the only...
Use the network setup wizard to connect to your network, and the internet. Unless you did this already.
You can get the wizard from Control Panel, Network ... , Connect to a Network. If wired you won't need key, it's for wireless only.
Yo did not say what OS, so info is a little generic.
Hope this helps.
Jan 26, 2011 | D-Link DIR-615 Wireless Router
Hi just installed router on my laptop, works fine but my desktop can't find it,why
Is your desktop wired or wireless.
If it wired then check the wired connection and make sure that you have proper light on the router. Suppose your computer is connected to the port 2 on the router, then you have port 2 light on the router.
If your computer is wireless then try to search for the wireless network and check if you can see the wireless network.
If you have windows XP, then try to use windows XP utility to connect to the network.
Fort windows Vista and 7 , you will find icon in the bottom right hand corner. Use that icon to connect to the network.
Click Here for step by step instructions
Mar 07, 2010 | NetGear DGN2000-100NAS Router
I have di-524 d-link wireless router, my router not giving me wireless connections
If you connect the computer to the router with the cable , does it work?
If yes then the wired connection is working.
What is the Operating system on the laptop or the wireless computer ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that you have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here for step by step instructions on how to connect to the wireless network and troubleshooting steps
Jan 12, 2010 | D-Link AirPlus DI-524 Wireless Router
Pleasssssssssse help : on router G624T
What is the Operating system on the laptop ?
Check the wireless settings of the router first . Make sure that yopu have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Jan 11, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I have recently purchased the wire/wireless
Click Here
Jan 05, 2010 | Edimax Computers & Internet
My laptop finds wireless router but will not connect to internet
Hi there. You may need to connect to the wireless network manually. What is the operating system running on your computer? If XP, you may follow these. (This is also applicable in other operating system, it may just vary a little) Right click the monitor icon showing on the system tray near the clock. Point the mouse in the icon and it will display the name if it is wireless network connection or network connection. Right click the icon and look for view available wireless network. If it is not showing, look for network connection. Right click and select "open network connection". Right click wireless network connection and select "view available wireless network" . Look for the wireless network you're trying to access or have connection.Highlight and click connect. If encrypted, you need to supply the pass key or security key twice and hit connect. It should allow you now to go online wirelessly. Please remember these, you should be able to go online wired. Make sure that there are other wireless computer connected to the wireless network you're connecting with and can go online wirelessly.
Hope this help :)
May 16, 2009 | Dynamode (R-ADSL-C4-W) Wireless Router
Wired internet working through netgear... wireless access denied
You must determine the wireless security of your router;
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
a. Click on the Wireless Settings under Setup.
b. take note of the SSID
c. if your using WEP...the network key would be on the key 1.
d. If WPA-PSK TKIP is in use just type in a new key with a minimum of 8 characters on the passphrase box. Please remember it.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Apr 06, 2009 | NetGear WGR614 54Mbps Wireless Router...
No wired connection
Firstly dissable your wireless adapter, as the router will try to allocate the same ip address to your pc twice, and this is not allowed. You need to check that the wired network card is set to obtain an ip address automatically, go to control panel>network connections right click on the network card icon>properties in the TCP/IP click properties again. restart pc, type 192.168.0.1 in your web browser and you should be able to get into the routers settings.
Sep 21, 2007 | D-Link DI 514 Wireless Router (DI-514)
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
