No sound coming from my toshiba tv, I've tried: changing channels, turning off and on, mute/unmute and even tried plugging headphones in and don't get any sound out of them :-(
  • yann Oct 28, 2012
    have you verify if the wire is good pluged on the TV and on the device?
    Top Expert:
  • Televison & ... Master
  • 44,148 Answers
During initial setup, could you have turned off the internal speakers?
Posted on Oct 29, 2012
  • 4 Answers
SOURCE: Samsung LE26R Digital Frozen
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Posted on Jun 10, 2008
SOURCE: Headphone Jack on Envision LCD TV
just bought a coby tf-tv2617 our cable company uses a unilersal remote ur2-cbl-cv02 where can i find the code to make them work
Posted on Dec 26, 2008
  • 10 Answers
SOURCE: Toshiba TV 32AV502U - closed captioning
if you have satalite or a cable box the settings need to be changed in them for CC
Posted on Jan 08, 2009
SOURCE: Toshiba 42HP95 Plasma tv
toshiba plasma 42hp95 tv will not turn on red led lights blinking
Posted on Feb 23, 2009
  • 308 Answers
SOURCE: I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
Posted on Mar 26, 2010
No sound tcl 40F S3800
when headphones are plugged in a conection is broken to stop sound coming from speakers try plugging in and out jack plug for headphones a few times
Jan 02, 2017 | Televison & Video
I am having problems with our daughter's tv. The volume isnt working now even though the picture is fine?
Have you looked at the headphone jack? Sometimes a set is left plugged in and sound wil not come out of speakers.
Also, look at cable box. It can sometimes have a separate volume control.
last, if you plug in a set of headphones and you hear sound, pick up a pair of inexpensive powered speakers and use those.
Jul 10, 2014 | Bush 5693D 24" TV
The Sound has stopped working on my telly
if you have sound from the headphone jack the sound circuit is good--audio headphone jack when inserted cuts off internal speakers--it could be 3 days old and have a problem with the jack.
Jun 07, 2012 | Televison & Video
Volume Stopping Instantly
A few things to consider: if mute on the set is not on what about the box if you are using one?
Speakers could be switched off in the set.
There could be a internal / external speaker switch(not common but possible)
Sound on the set could be muted or turned real low or off.
if the image you see on the screen is there--either it is from the set or a box if one is used.
only a few things other than the sound circuit being bad will cause this--very few sets with actual no sound problems are around.
Apr 03, 2012 | Mitsubishi Televison & Video
I have a Sharp LC37D43U TV that has no audio. The volume indicator shows can be moved up or down but no sound comes through the speakers. The picture works fine. I have nothing else connected to the TV....
It appears you ve discovered the sound task levers required to adjustment properties. Your Tv can still move levers even when the volume is set to mute. Select the unmute button before any voice or audio would be reactivated. Assuming that seting the TV on mute has predominant integrety over the volume functions where not unmuting usually with the same button on the remote would not achieve accessibility to the volume functions. refer to the TV user guide for diagnostic audios. Good luck
Jan 09, 2011 | Sharp Televison & Video
Why speaker is not working ?
first off, make sure everythings plugged in right
speakers plugged into audio out or headphone out on back of computer, power is on, and both speakers are plugged in, then check the muting, if its muted un mute...
if its not muted
try muting then unmuting, i sometimes have that problem...
if all else fails, try turning off your computer then waiting 5 mins, and turning it on, if sound works, then great, if not try a set of headphones you are positive work, plug them into each plug theyll fit in on the front and back, or sides of your computer, if not, chances are you have a broken soundcard...
or a software conflict, did you install anything lately, try uninstalling...
Jan 06, 2010 | Audio Players & Recorders
No audio
went into setup, tv and kept hitting the mute then unmute it finally took. Not sure what was wrong with it since I had already done that several times. The two audio outputs on the side of the tv do not work like it says in the manual for surround sound. Its definitely a cheap tv.
Jun 21, 2009 | Olevia 227-S11 27 in. LCD TV
No sound on Toshiba 32ZD16G 32
Hiii...
Have you check the ic audio ?
I havent any idea.....he,,,he...
T^hak;s
[Vrya]
Feb 23, 2008 | Televison & Video
TV was Fine last night, this morning there is picture, but no sound
Since the you were vacuuming behind the set before this happened, I'm going to assume that you unplugged an input. Check the wiring, not just on the back of the set, but, on the back of the peripherals (DVD, Satelite, cable box, etc.) If wires are connected, then, take a component, such as a VCR or cable box and hook it up to the RF connector (AKA the cable connector) and run it on channel 3 or 4. If you have sound, then, you have a configuration problem and need to rewire your set. Hope this helps.
Mar 17, 2007 | Philips 27PT5441 27" TV
Televison & Video Logo
76 people viewed this question
Top Televison & Video Experts
