Water not taking soap out of hopper
I checked water inlet and its fine. The water is ciming in very slowly so it not taking the soap out of hopper.
    Top Expert:
  • Washing Mach... Master
  • 44,200 Answers
I have to take a plastic piece out of the hopper when using laundry powder and put the plastic piece in when using liquid detergent
Posted on Oct 29, 2012
  • 135 Answers
SOURCE: LG WM2277HS - water backing up into soap dispenser
The pipe from the soap dispenser to the tub is quite large, it seems as if the water isn't getting out of the dispenser quick enough. Pull the whole dispenser out of the machine. There is a release clip at the back of the cup with the tray fully open. Clean out all soap residue and scum. Sometimes there is also a spot or setting for liquid or powder detergent. Adjust accordingly. Reassemble and try it again.
Posted on Apr 08, 2008
rpbuice
  • 161 Answers
SOURCE: Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Posted on Jan 08, 2009
  • 1294 Answers
SOURCE: Won't take in water
Plug off the mains. Unscrew the top, you will find the valve wher the water comes in. Shut off faucet in wall. Unscrew hoses to change valve. Note which hose goes where.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Mar 23, 2009
  • 1075 Answers
SOURCE: FQ106D1 Main washsoap dispenser always has soap in
remove dispenser drawer and give it a good clean.adrian,,,,
Posted on Jul 07, 2010
  • 3 Answers
SOURCE: whirlpool - hot inlet hose shaking badly when filling water
check to see if the screen is clogged were water hooks up to back of michine
Posted on May 11, 2012
Dishwasher slowly fills after cycle
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Apr 11, 2015 | Whirlpool Dishwashers
Fill time to long check water supply
if it takes too long to fill the tank in the machine, check the inlet valve on the bottom. there is a small filter basket just inside. pull it out and remove any debris. if it's taking to long to dispense, delime the dispense valves behind the steel plate behind the hoppers. make sure you unplug the machine and drain the tank first
Oct 14, 2014 | Bunn O-Matic 37000.0020 Hot Beverage...
The "Check Inlet" is indicating on the wash cycle. The hose to the machine is fine, and the flow in the pre-wash is normal. The problem is that the water dribbles out of the inlet holes into the soap...
Check if there is a filter on the water inlet hose which could be dirty..Remove fill hose hold over sink/bucket check water flowing fleely if so then fit new solenoid Water valve...Good luck
Oct 13, 2013 | Miele Novotronic Premier 500 Front Load...
Cold water fills very slowly
Possible the INPUT FILTER of the COLD water is clogged or the INLET valve is faulty. check the power from the board.
Jan 02, 2013 | Roper RAS8445KQ Top Load Washer
Dishwasher is not washing
Possibly inlet hose line is blocked with crud from your water source. Please confirm by turning off water under sink, disconnecting hose under dishwasher and, WITH HOSE IN AN OLD MILK BOTTLE, slowly turn on water under sink to verify water flow. If ok, water inlet selenoid is blocked and needs to cleared (with compressed air). Alternatively, input seleniod is burned out and needs to be replaced.
Jan 05, 2012 | Whirlpool Dishwashers
Water is pouring out of where the soap dispenser is. Can anyone help?
its pouring out because the dispenser is getting clogged in somewhere and not letting the water to the drain pump so its pouring from the soap dispenser. Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly , open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
Jul 09, 2009 | Kenmore 43142 Front Load Washer
Lg wahing machine WM2077CW a little bit of water enters cycle slowly, and i don't see soap nor water
Hi, Turn the faucets off at the wall and remove the inlet hoses. Look inside the inlet valve and see if the screens inside the valve are plugged.
I hope this helps
Vic
May 30, 2009 | Washing Machines
He2 front loading washing machine leak at the soap dispenser regi
Hi dlypooh, thought I would post the solution here as well for anybody who needs to do a search in the future...
If water goes down slowly (re: dlypooh), open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
Hope that helps!
Jan 13, 2009 | Kenmore HE2 Plus Front Load Washer
GE Nautilus Soap does not dissolve
What is happening, is that your dishes are washing dry. Start the dishwasher and slowly turn the timer till it starts to fill. Let it go and see how they are after
Jun 20, 2008 | GE Nautilus 24" Built-in Dishwasher
Apr 08, 2008 | LG WM-1485FHD Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
