Question about JVC Televison & Video
When turning on my tv it starts with repeated beeping comes on then go's off then comes on again and this can go on for five minutes or so before finally coming on and staying on
    Top Expert:
  • JVC Master
  • 35,737 Answers
The power supply is failing, that's why it is trying repeatedly to start
Posted on Oct 29, 2012
SOURCE: does not turn on
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked. We did that for about 2 weeks. Then one day nothing, no matter how long I left it unplugged.
My tv is 18mos. old out of warranty and Polaroid refuses to do anything about. I am extremely upset because I know that this is a manufacturing defect.
This may or may not work for other Polaroid models I have no idea. Here is a picture of my info.
Anyway here is how i fixed my set.
Total parts cost $5.12
This has worked for me, I am no technician so I can't say that it will work for you. Click here for information on caps. Or here
If you try this it is at your own risk!
Defective Parts:2 CapXon 1000uf 10v caps.
Replaced Parts:2 Off brand 1000uf 16v caps. (the closest match my local supplier had.)
Once unplugged and flipped over I removed these three screws to access the control box.
With the cover off I removed 3 more screws and again carefully pryed up on the control box cover to expose the inside.
4f3d408.jpg Circled is the location of the bad caps. (This is an after picture. I didn't take any pictures of the caps still on the board.)
Press your index finger over the tops of the 2 caps and feel for a bulge. Good caps should be sunken in. Bad caps ballooned.
b10c4c4.jpg These are mine removed
1822746.jpg In order to de-solder your caps you must unplug all connectors and remove the 4 screws holding down the board. Be very careful!, and only touch the sides of the board. Wear an anti-static band also.
1b2e11a.jpg Once removed pull of the plastic shield underneath the board. Be careful and save it, YOU MUST PUT IT BACK.
Carefully de-solder the old caps. Replace with new caps.
Note the polarity This is very important! On the board look for the + sign. That is your positive. The longer lead should go here. Take your time and verify This step.
CLICK HERE FOR CAPACITOR POLARITY
(sorry no pics on the cap removal and install I wasn't positive that this would work so I didn't think about taking any.)
Reverse the procedure to put your set back together.
Now plug it up and hope it works for another year!
Curse Polaroid and vow to never buy anything from them again!
b87cf86.jpg It works again
Posted on Apr 13, 2009
  • 1039 Answers
SOURCE: my tv takes like ten minutes untill it's turning on,why?
Replace any swollen capacitors in power supply.
Posted on Apr 25, 2009
  • 36 Answers
SOURCE: TV TURNS ON HUMMING SOUND FOR ABOUT FIVE MINUTES AND GOES AWAY
go in audio section and select mono instead of stereo or sap
Posted on Sep 18, 2009
  • 130 Answers
SOURCE: Turn on the TV & it stays black - no picture
hi
seems like you have power suply board problem
there may be a couple of capacitor that needs to be replace and eventualy it will no longer start
Posted on Sep 29, 2010
eagle338
  • 4889 Answers
SOURCE: when I turn on my tv the green light gomes on and
The 5 blinks error code means that the lamp driver is faulty. How good are your electronics/soldering skills?
Posted on Dec 10, 2010
How to program a bcm on a 2000 buick century
You can program it with or without a scan tool
Without a scan tool.This procedure will take 30 minutes.So make sure battery is fully charged 1.Turn the ignition switch off.2. Turn the ignition switch all the way from the off to the start position , then leave it in the on position. Note: The engine will not crank,3. The security light will come on and stay on for at least 10 minutes. 4. Turn the ignition switch off for five seconds. 5.repeat steps 2,3 and 4 again for a second time. 6. Repeat steps 2,3 and 4 again for a third time. 7. Turn the ignition switch off. 8. Turn the ignition switch all the way to the start position .The engine should now start. 9. Check BCM for any codes
Mar 06, 2012 | Cars & Trucks
Microwave starts beeping, four times then displays SE
Sounds as if it may be getting hot look at the back and under the unit there will be a grid of sorts sometimes at the back and//or the bottom or side/s of the machine check to see if this is free of dust etc if not clean and try again remember microwaves can give a nasty bite//please switch off and unplug first..
Dec 29, 2009 | Microwave Ovens
Glove box beeps
does the air bag light prove out when the key is turned on?
Nov 25, 2008 | 1995 Ford Crown Victoria
LG 42LT75 DVR Demo (HDD Playback)
Hi. I had the same problem. It may be fixed by pressing the volume down and menu buttons on the tv-set and hold for five seconds. Then you can use the remote to turn DVR demo off.
Cheers
Nov 17, 2007 | Televison & Video
Packard Bell error signals
here is a list of packard bell beep codes with meanings
http://www.uktsupport.co.uk/pb/mb/phnxcode.htm
Hope it helps you
Nov 13, 2007 | Packard Bell Easy One Silver 2101 Notebook
Televison & Video Logo
106 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
